Update SnapLock audit logs
Updates SnapLock audit logs to modify the audit log volume, adjust its attributes, or archive existing audit log files. This is useful for managing audit trail data and ensuring compliance with data retention policies.
HTTP method and endpoint
PATCH /storage/snaplock/audit-logs/{svm.uuid}
Introduced in
ONTAP 9.7
Usage notes
Updates one of the following:
the attributes of the audit log volume present, or
archive the current audit log files
Related ONTAP commands
snaplock log modify
Learn more
svm.uuid |
string |
path |
True |
SVM UUID |
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
log_archive |
log_volume |
Example request
"log_archive": {
"base_name": "string",
"expiry_time": "2058-06-04 19:00:00 +0000",
"path": "/snaplock_log/system_logs/20180822_005947_GMT-present",
"size": 20000
"log_volume": {
"max_log_size": 20971520,
"retention_period": "P30M",
"volume": {
"name": "volume1",
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response codes
| Error code | Description |
14090344 |
If log_volume is specified, then log_archive must not be specified |
14090345 |
If log_archive.base_name is specified, then log_archive.archive must also be specified |
14090346 |
Internal Error. Wait a few minutes, then try the command again |
href |
string |
_links
log_archive
archive |
boolean |
Archive the specified SnapLock log file for the given base_name, and create a new log file. If base_name is not mentioned, archive all log files. |
base_name |
string |
Base name of log file |
expiry_time |
string |
Expiry time of the log file in date-time format. Value '9999-12-31T00:00:00Z' indicates infinite expiry time. |
path |
string |
Absolute path of the log file in the volume |
size |
integer |
Size of the log file in bytes |
snaplock_log_file
archive |
boolean |
base_name |
string |
expiry_time |
string |
path |
string |
size |
integer |
volume
name |
string |
The name of the volume. |
uuid |
string |
snaplock_log_volume
max_log_size |
integer |
Maximum size of log file in bytes |
retention_period |
string |
Specifies the default log record retention period. The retention period value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, minutes and seconds. A period specified for years, months and days is represented in the ISO-8601 format as "P |
volume |
svm
name |
string |
The name of the SVM. |
uuid |
string |
snaplock_log
log_archive |
log_volume |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
