REST API reference
Create an application
Creates an application by selecting a template and specifying required properties such as the name and storage virtual machine (SVM). This process helps you automate best practices and tailor the application to your specific needs by using just one template, ensuring efficient resource configuration.
HTTP method and endpoint
POST /application/applications
Introduced in
ONTAP 9.6
Template properties
The application APIs appear to be complex and long in this documentation because we document every possible template, of which there are currently 14. When creating an application, only a single template is used, so it is best to focus only on the template of interest. Other than the properties for the chosen template, only the name and svm of the application must be provided. The following three sections provided guidelines on using the properties of the templates, but the whole idea behind the templates is to automatically follow the best practices of the given application, so the only way to determine the exact list of required properties and default values is to dig in to the model section of the template. The templates are all top level properties of the application object with names matching the values returned by GET /application/templates .
Required properties
  • svm.uuid or svm.name - The existing SVM in which to create the application.
  • name - The name for the application.
  • <template> - Properties for one template must be provided. In general, the following properties are required, however the naming of these may vary slightly from template to template.
    • name - The generic templates require names for the components of the application. Other templates name the components automatically.
    • size - This generally refers to the size of an application component, which may be spread across multiple underlying storage objects (volumes, LUNs, etc…​).
    • One of the following must be specified:
  • nfs_access or an identifier (name or id) of an existing export-policy.
  • cifs_access
  • igroup_name
    • os_type - All SAN applications require an os_type to be specified in some way. Some templates refer to this as the hypervisor.
  • <template> - The following properties are available in some templates.
    • new_igroups.* - SAN applications can use existing initiator groups or create new ones. When creating new initiator groups, new_igroups.name is required and the other properties may be used to fully specify the new initiator group.
Default property values
If not specified in POST, the follow default property values are assigned. It is recommended that most of these properties be provided explicitly rather than relying upon the defaults. The defaults are intended to make it as easy as possible to provision and connect to an application.
  • template.name - Defaults to match the <template> provided. If specified, the value of this property must match the provided template properties.
  • <template> - The majority of template properties have default values. The defaults may vary from template to template. See the model of each template for complete details. In general the following patterns are common across all template properties. The location of these properties varies from template to template.
    • storage_service.name - value
    • protection_type.local_rpo - hourly (Hourly Snapshot copies)
    • protection_type.remote_rpo - none (Not MetroCluster)
    • new_igroups.os_type - Defaults to match the os_type provided for the application, but may need to be provided explicitly when using virtualization.
Optional components
A common pattern across many templates are objects that are optional, but once any property in the object is specified, other properties within the object become required. Many applications have optional components. For example, provisioning a database without a component to store the logs is supported. If the properties related to the logs are omitted, no storage will be provisioned for logs. But when the additional component is desired, the size is required. Specifying any other property of a component without specifying the size is not supported. In the model of each template, the required components are indicated with a red '*'. When a size property is listed as optional, that means the component itself is optional, and the size should be specified to include that component in the application.
POST body examples
  1. Create a generic SAN application that exposes four LUNs to an existing initiator group, igroup_1.
    "name": "app1",
    "svm": { "name": "svm1" },
    "san": {
      "os_type": "linux",
      "application_components": [
        { "name": "component1", "total_size": "10GB", "lun_count": 4, "igroup_name": "igroup_1" }
  1. Create an SQL application that can be accessed via initiator iqn.2017-01.com.example:foo from a new initiator group, igroup_2.
    "name": "app2",
    "sql_on_san": {
      "db": { "size": "5GB" },
      "log": { "size": "1GB" },
      "temp_db": { "size": "2GB" },
      "igroup_name": "igroup_2",
      "new_igroups": [
        { "name": "igroup_2", "initiators": [ "iqn.2017-01.com.example:foo" ] }
  1. The following body creates the exact same SQL application, but manually provides all the defaults that were excluded from the previous call.
Note The model of a sql_on_san application documents all these default values.
    "name": "app3",
    "template": { "name": "sql_on_san" },
    "sql_on_san": {
      "os_type": "windows_2008",
      "server_cores_count": 8,
      "db": { "size": "5GB", "storage_service": { "name": "value" } },
      "log": { "size": "1GB", "storage_service": { "name": "value" } },
      "temp_db": { "size": "2GB", "storage_service": { "name": "value" } },
      "new_igroups": [
          "name": "igroup_2",
          "protocol": "mixed",
          "os_type": "windows",
          "initiators": [ "iqn.a.new.initiator" ]
      "protection_type": { "local_rpo": "none" }
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
_links
_links
creation_timestamp
string
The time when the application was created.
delete_data
boolean
Should application storage elements be deleted? An application is considered to use storage elements from a shared storage pool. Possible values are 'true' and 'false'. If the value is 'true', the application will be deleted in its entirety. If the value is 'false', the storage elements will be disassociated from the application and preserved. The application will then be deleted.
generation
integer
The generation number of the application. This indicates which features are supported on the application. For example, generation 1 applications do not support Snapshot copies. Support for Snapshot copies was added at generation 2. Any future generation numbers and their feature set will be documented.
maxdata_on_san
maxdata_on_san
MAX Data application using SAN.
mongo_db_on_san
mongo_db_on_san
MongoDB using SAN.
name
string
Application Name. This field is user supplied when the application is created.
nas
nas
A generic NAS application.
nvme
zapp_nvme
An NVME application.
oracle_on_nfs
oracle_on_nfs
Oracle using NFS.
oracle_on_san
oracle_on_san
Oracle using SAN.
oracle_rac_on_nfs
oracle_rac_on_nfs
Oracle RAC using NFS.
oracle_rac_on_san
oracle_rac_on_san
Oracle RAC using SAN.
protection_granularity
string
Protection granularity determines the scope of Snapshot copy operations for the application. Possible values are "application" and "component". If the value is "application", Snapshot copy operations are performed on the entire application. If the value is "component", Snapshot copy operations are performed separately on the application components.
rpo
rpo
s3_bucket
zapp_s3_bucket
A generic S3 bucket application.
san
san
A generic SAN application.
smart_container
boolean
Identifies if this is a smart container or not.
sql_on_san
sql_on_san
Microsoft SQL using SAN.
sql_on_smb
sql_on_smb
Microsoft SQL using SMB.
state
string
The state of the application. For full functionality, applications must be in the online state. Other states indicate that the application is in a transient state and not all operations are supported.
statistics
statistics
svm
svm
template
template
uuid
string
Application UUID. This field is generated when the application is created.
vdi_on_nas
vdi_on_nas
A VDI application using NAS.
vdi_on_san
vdi_on_san
A VDI application using SAN.
vsi_on_nas
vsi_on_nas
A VSI application using NAS.
vsi_on_san
vsi_on_san
A VSI application using SAN.
Example request
  "creation_timestamp": "string",
  "generation": 0,
  "maxdata_on_san": {
    "app_type": "string",
        "file_system": "string",
        "host_management_url": "string",
        "host_name": "string",
        "igroup_name": "string",
        "lun_count": 0,
        "metadata": [
            "key": "string",
            "value": "string"
        "name": "string",
          "local_rpo": "string",
          "remote_rpo": "string"
          "name": "string"
        "tiering": {
          "control": "string",
          "object_stores": [
              "name": "string"
          "policy": "string"
        "total_size": 0
    "metadata": [
        "key": "string",
        "value": "string"
    "new_igroups": [
        "comment": "string",
        "igroups": [
            "name": "string",
            "uuid": "string"
        "initiator_objects": [
            "name": "string"
        "initiators": [
          "string"
        "name": "string",
        "os_type": "string",
        "protocol": "string"
    "ocsm_url": "string",
    "os_type": "string"
  "mongo_db_on_san": {
    "dataset": {
      "size": 0,
        "name": "string"
    "new_igroups": [
        "igroups": [
            "name": "string",
            "uuid": "string"
            "name": "string"
        "initiators": [
          "string"
        "name": "string",
    "primary_igroup_name": "string",
    "secondary_igroups": [
        "name": "string"
  "name": "string",
  "nas": {
        "export_policy": {
          "name": "string"
        "flexcache": {
          "origin": {
            "component": {
              "name": "string"
            "svm": {
              "name": "string"
        "name": "string",
        "qos": {
          "policy": {
            "name": "string",
            "uuid": "string"
        "share_count": 0,
          "name": "string"
        "tiering": {
          "object_stores": [
              "name": "string"
          "policy": "string"
        "total_size": 0
    "cifs_access": [
        "access": "string",
        "user_or_group": "string"
    "exclude_aggregates": [
        "name": "string",
        "uuid": "string"
    "nfs_access": [
        "access": "string",
        "host": "string"
      "local_policy": "string",
  "nvme": {
    "components": [
        "name": "string",
        "performance": {
            "name": "string"
        "qos": {
          "policy": {
            "name": "string",
            "uuid": "string"
        "subsystem": {
          "hosts": [
              "nqn": "string"
          "name": "string",
          "uuid": "string"
        "tiering": {
          "object_stores": [
              "name": "string"
          "policy": "string"
    "rpo": {
      "local": {
        "name": "string",
        "policy": "string"
  "oracle_on_nfs": {
    "archive_log": {
        "name": "string"
    "db": {
      "size": 0,
        "name": "string"
    "nfs_access": [
        "access": "string",
        "host": "string"
    "ora_home": {
        "name": "string"
    "redo_log": {
      "size": 0,
        "name": "string"
  "oracle_on_san": {
    "archive_log": {
        "name": "string"
    "db": {
      "size": 0,
        "name": "string"
    "new_igroups": [
        "igroups": [
            "name": "string",
            "uuid": "string"
            "name": "string"
        "initiators": [
          "string"
        "name": "string",
    "ora_home": {
        "name": "string"
    "redo_log": {
      "size": 0,
        "name": "string"
  "oracle_rac_on_nfs": {
    "archive_log": {
        "name": "string"
    "db": {
      "size": 0,
        "name": "string"
    "grid_binary": {
        "name": "string"
    "nfs_access": [
        "access": "string",
        "host": "string"
    "ora_home": {
        "name": "string"
    "oracle_crs": {
        "name": "string"
    "redo_log": {
      "size": 0,
        "name": "string"
  "oracle_rac_on_san": {
    "archive_log": {
        "name": "string"
    "db": {
      "size": 0,
        "name": "string"
    "db_sids": [
    "grid_binary": {
        "name": "string"
    "new_igroups": [
        "igroups": [
            "name": "string",
            "uuid": "string"
            "name": "string"
        "initiators": [
          "string"
        "name": "string",
    "ora_home": {
        "name": "string"
    "oracle_crs": {
        "name": "string"
    "redo_log": {
      "size": 0,
        "name": "string"
  "protection_granularity": "string",
  "rpo": {
    "components": [
        "name": "string",
        "rpo": {
          "local": {
            "description": "string",
            "name": "string"
          "remote": {
            "name": "string"
        "uuid": "string"
    "local": {
      "name": "string"
    "remote": {
      "name": "string"
  "s3_bucket": {
        "access_policies": [
            "actions": [
              "string"
            "conditions": [
                "delimiters": [
                  "string"
                "max_keys": [
                  "integer"
                "operator": "string",
                "prefixes": [
                  "string"
                "source_ips": [
                  "string"
                "usernames": [
                  "string"
            "effect": "string",
            "principals": [
              "string"
            "resources": [
              "string"
            "sid": "string"
            "name": "string",
            "uuid": "string"
        "name": "string",
        "qos": {
          "policy": {
            "name": "string",
            "uuid": "string"
        "size": 0,
          "name": "string"
        "uuid": "string"
  "san": {
        "name": "string",
        "qos": {
          "policy": {
            "name": "string",
            "uuid": "string"
          "name": "string"
        "tiering": {
          "object_stores": [
              "name": "string"
          "policy": "string"
        "name": "string",
        "uuid": "string"
    "new_igroups": [
        "igroups": [
            "name": "string",
            "uuid": "string"
            "name": "string"
        "initiators": [
          "string"
        "name": "string",
  "sql_on_san": {
    "db": {
      "size": 0,
        "name": "string"
    "log": {
      "size": 0,
        "name": "string"
    "new_igroups": [
        "igroups": [
            "name": "string",
            "uuid": "string"
            "name": "string"
        "initiators": [
          "string"
        "name": "string",
    "temp_db": {
        "name": "string"
  "sql_on_smb": {
    "access": {
      "installer": "string",
      "service_account": "string"
    "db": {
      "size": 0,
        "name": "string"
    "log": {
      "size": 0,
        "name": "string"
    "temp_db": {
        "name": "string"
  "state": "string",
  "statistics": {
    "components": [
        "iops": {
          "per_tb": 0,
          "total": 0
        "latency": {
          "average": 0,
          "raw": 0
        "name": "string",
        "snapshot": {
          "reserve": 0,
          "used": 0
        "space": {
          "available": 0,
          "logical_used": 0,
          "provisioned": 0,
          "reserved_unused": 0,
          "savings": 0,
          "used": 0,
          "used_excluding_reserves": 0,
          "used_percent": 0
          "name": "string",
          "uuid": "string"
        "uuid": "string"
    "iops": {
      "per_tb": 0,
      "total": 0
    "latency": {
      "average": 0,
      "raw": 0
    "snapshot": {
      "reserve": 0,
      "used": 0
    "space": {
      "available": 0,
      "logical_used": 0,
      "provisioned": 0,
      "savings": 0,
      "used": 0,
      "used_percent": 0
  "svm": {
    "name": "string",
    "uuid": "string"
  "template": {
    "name": "string",
    "protocol": "string",
    "version": 0
  "uuid": "string",
  "vdi_on_nas": {
    "desktops": {
      "size": 0,
        "name": "string"
    "hyper_v_access": {
    "nfs_access": [
        "access": "string",
        "host": "string"
  "vdi_on_san": {
    "desktops": {
      "size": 0,
        "name": "string"
    "hypervisor": "string",
    "new_igroups": [
        "igroups": [
            "name": "string",
            "uuid": "string"
            "name": "string"
        "initiators": [
          "string"
        "name": "string",
  "vsi_on_nas": {
    "datastore": {
      "size": 0,
        "name": "string"
    "hyper_v_access": {
    "nfs_access": [
        "access": "string",
        "host": "string"
  "vsi_on_san": {
    "datastore": {
      "size": 0,
        "name": "string"
    "new_igroups": [
        "igroups": [
            "name": "string",
            "uuid": "string"
            "name": "string"
        "initiators": [
          "string"
        "name": "string",
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Status: Default, Error
string
metadata
key
string
Key to look up metadata associated with an application component.
value
string
Value associated with the key.
protection_type
local_rpo
string
The local rpo of the application component.
remote_rpo
string
The remote rpo of the application component.
storage_service
name
string
The storage service of the application component.
object_stores
name
string
The name of the object-store to use.
maxdata_on_san_application_components_tiering
tiering
control
string
Storage tiering placement rules for the container(s)
object_stores
array[object_stores]
policy
string
The storage tiering type of the application component.
The list of application components to be created.
file_system
string
Defines the type of file system that will be installed on this application component.
host_management_url
string
The host management URL for this application component.
host_name
string
FQDN of the L2 host that contains the hot tier of this application component.
igroup_name
string
The name of the initiator group through which the contents of this application will be accessed. Modification of this parameter is a disruptive operation. All LUNs in the application component will be unmapped from the current igroup and re-mapped to the new igroup.
lun_count
integer
The number of LUNs in the application component.
metadata
array[metadata]
name
string
The name of the application component.
protection_type
protection_type
storage_service
storage_service
tiering
tiering
total_size
integer
The total size of the application component, split across the member LUNs. Usage: {<integer>[KB|MB|GB|TB|PB]}
metadata
key
string
Key to look up metadata associated with an application.
value
string
igroups
name
string
The name of an igroup to nest within a parent igroup. Mutually exclusive with initiators and initiator_objects.
uuid
string
The UUID of an igroup to nest within a parent igroup Usage: <UUID>
initiator_objects
comment
string
A comment available for use by the administrator.
name
string
The WWPN, IQN, or Alias of the initiator. Mutually exclusive with nested igroups and the initiators array.
maxdata_on_san_new_igroups
The list of initiator groups to create.
comment
string
igroups
array[igroups]
initiator_objects
array[initiator_objects]
initiators
array[string]
name
string
The name of the new initiator group.
os_type
string
The name of the host OS accessing the application. The default value is the host OS that is running the application.
protocol
string
The protocol of the new initiator group.
maxdata_on_san
app_type
string
Type of the application that is being deployed on the L2.
array[maxdata_on_san_application_components]
metadata
array[metadata]
new_igroups
array[maxdata_on_san_new_igroups]
ocsm_url
string
The OnCommand System Manager URL for this application.
os_type
string
The name of the host OS running the application.
storage_service
name
string
The storage service of the database.
dataset
element_count
integer
The number of storage elements (LUNs for SAN) of the database to maintain. Must be an even number between 2 and 16. Odd numbers will be rounded up to the next even number within range.
replication_factor
integer
The number of data bearing members of the replicaset, including 1 primary and at least 1 secondary.
size
integer
The size of the database. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
mongo_db_on_san_new_igroups
comment
string
igroups
array[igroups]
initiator_objects
initiators
array[string]
name
string
os_type
string
protocol
string
protection_type
local_rpo
string
The local RPO of the application.
remote_rpo
string
The remote RPO of the application.
secondary_igroups
name
string
The name of the initiator group for each secondary.
mongo_db_on_san
MongoDB using SAN.
dataset
dataset
new_igroups
array[mongo_db_on_san_new_igroups]
os_type
string
primary_igroup_name
string
The initiator group for the primary.
protection_type
protection_type
secondary_igroups
array[secondary_igroups]
export_policy
id
integer
The ID of an existing NFS export policy.
name
string
The name of an existing NFS export policy.
component
name
string
Name of the source component.
svm
name
string
Name of the source SVM.
origin
component
component
svm
svm
flexcache
dr_cache
boolean
Dr-cache is a FlexCache volume create time option that has the same flexgroup-msid as that of the origin of a FlexCache volume. By default, dr-cache is disabled. The flexgroup-msid of the FlexCache volume does not need to be same as that of the origin of a FlexCache volume.
origin
origin
policy
name
string
The name of an existing QoS policy.
uuid
string
The UUID of an existing QoS policy. Usage: <UUID>
qos
policy
policy
nas_application_components_tiering
application-components.tiering
control
string
object_stores
policy
string
export_policy
export_policy
flexcache
flexcache
name
string
qos
qos
scale_out
boolean
Denotes a Flexgroup.
share_count
integer
The number of shares in the application component.
storage_service
storage_service
tiering
total_size
integer
The total size of the application component, split across the member shares. Usage: {<integer>[KB|MB|GB|TB|PB]}
app_cifs_access
The list of CIFS access controls. You must provide either 'user_or_group' or 'access' to enable CIFS access.
access
string
The CIFS access granted to the user or group.
user_or_group
string
The name of the CIFS user or group that will be granted access.
exclude_aggregates
name
string
The name of the aggregate to exclude. Usage: <aggregate name>
uuid
string
The ID of the aggregate to exclude. Usage: <UUID>
app_nfs_access
The list of NFS access controls. You must provide either 'host' or 'access' to enable NFS access.
access
string
The NFS access granted.
host
string
The name of the NFS entity granted access.
protection_type
local_policy
string
The Snapshot copy policy to apply to each volume in the smart container. This property is only supported for smart containers. Usage: <snapshot policy>
local_rpo
string
remote_rpo
string
nas
array[application_components]
cifs_access
array[app_cifs_access]
exclude_aggregates
array[exclude_aggregates]
nfs_access
array[app_nfs_access]
protection_type
protection_type
performance
storage_service
storage_service
hosts
nqn
string
The host NQN.
zapp_nvme_components_subsystem
components.subsystem
hosts
array[hosts]
name
string
The name of the subsystem accessing the component. If neither the name nor the UUID is provided, the name defaults to <application-name>_<component-name>, whether that subsystem already exists or not.
os_type
string
The name of the host OS accessing the component. The default value is the host OS that is running the application.
uuid
string
The UUID of an existing subsystem to be granted access to the component. Usage: <UUID>
zapp_nvme_components_tiering
control
string
object_stores
policy
string
components
name
string
namespace_count
integer
The number of namespaces in the component.
os_type
string
performance
performance
qos
qos
subsystem
tiering
total_size
integer
The total size of the component, spread across member namespaces. Usage: {<integer>[KB|MB|GB|TB|PB]}
local
name
string
policy
string
rpo
local
local
zapp_nvme
components
array[components]
os_type
string
rpo
rpo
storage_service
name
string
The storage service of the archive log.
archive_log
size
integer
The size of the archive log. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
db
size
integer
storage_service
storage_service
storage_service
name
string
The storage service of the ORACLE_HOME storage volume.
ora_home
size
integer
The size of the ORACLE_HOME storage volume. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
storage_service
name
string
The storage service of the redo log group.
redo_log
mirrored
boolean
Specifies whether the redo log group should be mirrored.
size
integer
The size of the redo log group. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
oracle_on_nfs
Oracle using NFS.
archive_log
archive_log
db
db
nfs_access
ora_home
ora_home
protection_type
protection_type
redo_log
redo_log
oracle_on_san_new_igroups
comment
string
igroups
array[igroups]
initiator_objects
initiators
array[string]
name
string
os_type
string
protocol
string
oracle_on_san
Oracle using SAN.
archive_log
archive_log
db
db
igroup_name
string
new_igroups
array[oracle_on_san_new_igroups]
ora_home
ora_home
os_type
string
protection_type
protection_type
redo_log
redo_log
storage_service
name
string
The storage service of the Oracle grid binary storage volume.
grid_binary
size
integer
The size of the Oracle grid binary storage volume. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
storage_service
name
string
The storage service of the Oracle CRS volume.
oracle_crs
copies
integer
The number of CRS volumes.
size
integer
The size of the Oracle CRS/voting storage volume. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
oracle_rac_on_nfs
archive_log
archive_log
db
db
grid_binary
grid_binary
nfs_access
ora_home
ora_home
oracle_crs
oracle_crs
protection_type
protection_type
redo_log
redo_log
db_sids
igroup_name
string
oracle_rac_on_san_new_igroups
comment
string
igroups
array[igroups]
initiator_objects
initiators
array[string]
name
string
os_type
string
protocol
string
oracle_rac_on_san
archive_log
archive_log
db
db
db_sids
array[db_sids]
grid_binary
grid_binary
new_igroups
array[oracle_rac_on_san_new_igroups]
ora_home
ora_home
oracle_crs
oracle_crs
os_type
string
protection_type
protection_type
redo_log
redo_log
local
description
string
A detailed description of the local RPO. This will include details about the Snapshot copy schedule.
name
string
The local RPO of the component. This indicates how often component Snapshot copies are automatically created.
remote
description
string
A detailed description of the remote RPO.
name
string
The remote RPO of the component. A remote RPO of zero indicates that the component is synchronously replicated to another cluster.
rpo
local
local
remote
remote
components
name
string
Component Name.
rpo
rpo
uuid
string
Component UUID.
local
description
string
name
string
The local RPO of the application. This indicates how often application Snapshot copies are automatically created.
remote
description
string
name
string
The remote RPO of the application. A remote RPO of zero indicates that the application is synchronously replicated to another cluster.
rpo
components
array[components]
is_supported
boolean
Is RPO supported for this application? Generation 1 applications did not support Snapshot copies or MetroCluster.
local
local
remote
remote
zapp_s3_bucket_application_components_access_policies_conditions
conditions
delimiters
array[string]
max_keys
array[integer]
operator
string
Policy Condition Operator.
prefixes
array[string]
source_ips
array[string]
usernames
array[string]
The list of S3 objectstore policies to be created.
actions
array[string]
conditions
array[zapp_s3_bucket_application_components_access_policies_conditions]
conditions.
effect
string
Allow or Deny Access.
principals
array[string]
resources
array[string]
sid
string
Statement Identifier Usage: <(size 1..256)>
access_policies
array[zapp_s3_bucket_application_components_access_policies]
capacity_tier
boolean
Prefer lower latency storage under similar media costs.
comment
string
Object Store Server Bucket Description Usage: <(size 1..256)>
exclude_aggregates
name
string
qos
qos
size
integer
The total size of the S3 Bucket, split across the member components. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
uuid
string
Object Store Server Bucket UUID Usage: <UUID>
zapp_s3_bucket
array[zapp_s3_bucket_application_components]
control
string
object_stores
policy
string
igroup_name
string
lun_count
integer
name
string
os_type
string
qos
qos
storage_service
storage_service
tiering
total_size
integer
san_new_igroups
comment
string
igroups
array[igroups]
initiator_objects
initiators
array[string]
name
string
os_type
string
protocol
string
san
exclude_aggregates
new_igroups
array[san_new_igroups]
os_type
string
protection_type
protection_type
storage_service
name
string
The storage service of the DB.
db
size
integer
The size of the DB. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
storage_service
name
string
The storage service of the log DB.
log
size
integer
The size of the log DB. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
sql_on_san_new_igroups
comment
string
igroups
array[igroups]
initiator_objects
initiators
array[string]
name
string
os_type
string
protocol
string
storage_service
name
string
The storage service of the temp DB.
temp_db
size
integer
The size of the temp DB. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
sql_on_san
db
db
igroup_name
string
log
log
new_igroups
array[sql_on_san_new_igroups]
os_type
string
protection_type
protection_type
server_cores_count
integer
The number of server cores for the DB.
temp_db
temp_db
access
installer
string
SQL installer admin user name.
service_account
string
SQL service account user name.
sql_on_smb
access
access
db
db
log
log
protection_type
protection_type
server_cores_count
integer
temp_db
temp_db
iops
per_tb
integer
The number of IOPS per terabyte of logical space currently being used by the application component.
total
integer
The total number of IOPS being used by the application component.
latency
average
integer
The cumulative average response time in microseconds for this component.
raw
integer
The cumulative response time in microseconds for this component.
snapshot
reserve
integer
The amount of space reserved by the system for Snapshot copies.
used
integer
The amount of spacing currently in use by the system to store Snapshot copies.
space
available
integer
The available amount of space left in the application component. Note that this field has limited meaning for SAN applications. Space may be considered used from ONTAP's perspective while the host filesystem still considers it available.
  • readOnly: 1
logical_used
integer
The amount of space that would currently be used if no space saving features were enabled. For example, if compression were the only space saving feature enabled, this field would represent the uncompressed amount of space used.
provisioned
integer
The originally requested amount of space that was provisioned for the application component.
reserved_unused
integer
The amount of space reserved for system features such as Snapshot copies that has not yet been used.
savings
integer
The amount of space saved by all enabled space saving features.
used
integer
The amount of space that is currently being used by the application component. Note that this includes any space reserved by the system for features such as Snapshot copies.
integer
The amount of space that is currently being used, excluding any space that is reserved by the system for features such as Snapshot copies.
used_percent
integer
The percentage of the originally provisioned space that is currently being used by the application component.
storage_service
name
string
The storage service name. AFF systems support the extreme storage service. All other systems only support value.
uuid
string
The storage service UUID.
components
iops
iops
latency
latency
name
string
Component Name.
shared_storage_pool
boolean
An application component is considered to use a shared storage pool if storage elements for for other components reside on the same aggregate as storage elements for this component.
snapshot
snapshot
space
space
statistics_incomplete
boolean
If not all storage elements of the application component are currently available, the returned statistics might only include data from those elements that were available.
storage_service
storage_service
uuid
string
Component UUID.
iops
per_tb
integer
The number of IOPS per terabyte of logical space currently being used by the application.
total
integer
The total number of IOPS being used by the application.
latency
average
integer
The cumulative average response time in microseconds for this application.
raw
integer
The cumulative response time in microseconds for this application.
space
available
integer
The available amount of space left in the application. Note that this field has limited meaning for SAN applications. Space may be considered used from ONTAP's perspective while the host filesystem still considers it available.
  • readOnly: 1
  • Introduced in: 9.6
logical_used
integer
provisioned
integer
The originally requested amount of space that was provisioned for the application.
reserved_unused
integer
savings
integer
used
integer
The amount of space that is currently being used by the application. Note that this includes any space reserved by the system for features such as Snapshot copies.
integer
used_percent
integer
The percentage of the originally provisioned space that is currently being used by the application.
statistics
components
array[components]
iops
iops
latency
latency
shared_storage_pool
boolean
An application is considered to use a shared storage pool if storage elements for multiple components reside on the same aggregate.
snapshot
snapshot
space
space
boolean
If not all storage elements of the application are currently available, the returned statistics might only include data from those elements that were available.
svm
name
string
SVM Name. Either the SVM name or UUID must be provided to create an application.
uuid
string
SVM UUID. Either the SVM name or UUID must be provided to create an application.
template
name
string
The name of the template that was used to provision this application.
protocol
string
The protocol access of the template that was used to provision this application.
version
integer
The version of the template that was used to provision this application. The template version changes only if the layout of the application changes over time. For example, redo logs in Oracle RAC templates were updated and provisioned differently in DATA ONTAP 9.3.0 compared to prior releases, so the version number was increased. If layouts change in the future, the changes will be documented along with the corresponding version numbers.
  • readOnly: 1
storage_service
name
string
The storage service of the desktops.
desktops
count
integer
The number of desktops to support.
size
integer
The size of the desktops. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
hyper_v_access
service_account
string
Hyper-V service account.
vdi_on_nas
desktops
desktops
hyper_v_access
hyper_v_access
nfs_access
protection_type
protection_type
vdi_on_san_new_igroups
comment
string
igroups
array[igroups]
initiator_objects
initiators
array[string]
name
string
protocol
string
vdi_on_san
desktops
desktops
hypervisor
string
The name of the hypervisor hosting the application.
igroup_name
string
new_igroups
array[vdi_on_san_new_igroups]
protection_type
protection_type
storage_service
name
string
The storage service of the datastore.
datastore
count
integer
The number of datastores to support.
size
integer
The size of the datastore. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
vsi_on_nas
datastore
datastore
hyper_v_access
hyper_v_access
nfs_access
protection_type
protection_type
vsi_on_san_new_igroups
comment
string
igroups
array[igroups]
initiator_objects
initiators
array[string]
name
string
protocol
string
vsi_on_san
datastore
datastore
hypervisor
string
igroup_name
string
new_igroups
array[vsi_on_san_new_igroups]
protection_type
protection_type
application
Applications
_links
_links
creation_timestamp
string
delete_data
boolean
generation
integer
maxdata_on_san
maxdata_on_san
mongo_db_on_san
mongo_db_on_san
MongoDB using SAN.
name
string
nas
nas
nvme
zapp_nvme
oracle_on_nfs
oracle_on_nfs
Oracle using NFS.
oracle_on_san
oracle_on_san
Oracle using SAN.
oracle_rac_on_nfs
oracle_rac_on_nfs
oracle_rac_on_san
oracle_rac_on_san
string
rpo
rpo
s3_bucket
zapp_s3_bucket
san
san
smart_container
boolean
sql_on_san
sql_on_san
sql_on_smb
sql_on_smb
state
string
statistics
statistics
svm
svm
template
template
uuid
string
vdi_on_nas
vdi_on_nas
vdi_on_san
vdi_on_san
vsi_on_nas
vsi_on_nas
vsi_on_san
vsi_on_san
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
