REST API reference
Creates an fc interface
  • name - name of the fc interface
  • locationportuuid or both locationportname and locationportnodename - fc port on which to create the fc interface
  • data_protocol - data protocol for the fc interface # default property values if not specified in post, the following default property values are assigned
  • enabled - true # related ontap commands
  • network interface create # learn more
  • [doc /network/fc/interfaces](#docs-networking-network_fc_interfaces)
POST /network/fc/interfaces
Introduced In: 9.6
Creates an FC interface.
Required properties
  • svm.uuid or svm.name - Existing SVM in which to create the FC interface.
  • name - Name of the FC interface.
  • location.port.uuid or both location.port.name and location.port.node.name - FC port on which to create the FC interface.
  • data_protocol - Data protocol for the FC interface.
Default property values
If not specified in POST, the following default property values are assigned.
  • enabled - true
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
comment
string
A user configurable comment. Optional in POST; valid in PATCH. To clear a prior comment, set the property to an empty string in PATCH.
data_protocol
string
The data protocol for which the FC interface is configured. Required in POST.
enabled
boolean
The administrative state of the FC interface. The FC interface can be disabled to block all FC communication with the SVM through this interface. Optional in POST and PATCH; defaults to true (enabled) in POST.
location
location
The location of the FC interface is defined by the location of its port. An FC port is identified by its UUID, or a combination of its node name and port name. Either the UUID or the node name and port name are required for POST. To move an interface, supply either the UUID or the node name and port name in a PATCH.
The location of an FC interface can be set using "location.home_node" and "location.home_port" during a POST or PATCH. "location.node" and "location.port" refer to the current location of the FC interface. This can be different from "location.home_node" and "location.home_port" in instances where the FC interface failed over due to an offline node.
name
string
The name of the FC interface. Required in POST; optional in PATCH.
port_address
string
The port address of the FC interface. Each FC port in an FC switched fabric has its own unique FC port address for routing purposes. The FC port address is assigned by a switch in the fabric when that port logs in to the fabric. This property refers to the address given by a switch to the FC interface when the SVM performs a port login (PLOGI).
This is useful for obtaining statistics and diagnostic information from FC switches.
This is a hexadecimal encoded numeric value.
state
string
The current operational state of the FC interface. The state is set to down if the interface is not enabled.
If the node hosting the port is down or unavailable, no state value is returned.
svm
svm
uuid
string
The unique identifier of the FC interface. Required in the URL.
wwnn
string
The world wide node name (WWNN) of the FC interface SVM. The WWNN is generated by ONTAP when Fibre Channel Protocol or the NVMe service is created for the FC interface SVM.
  • example: 20:00:00:50:56:b4:13:01
  • readOnly: 1
  • Introduced in: 9.6
wwpn
string
The world wide port name (WWPN) of the FC interface. The WWPN is generated by ONTAP when the FC interface is created.
  • example: 20:00:00:50:56:b4:13:a8
  • readOnly: 1
Example request
  "comment": "string",
  "data_protocol": "string",
  "location": {
    "home_node": {
      "name": "node1",
    "home_port": {
      "name": "0a",
      "node": {
        "name": "node1"
    "node": {
      "name": "node1",
    "port": {
      "name": "0a",
      "node": {
        "name": "node1"
  "name": "fc_lif1",
  "port_address": "5060F",
  "state": "string",
  "svm": {
    "name": "svm1",
  "uuid": "bce9827d-4d8f-60af-c771-6e8e9af2c6f0",
  "wwnn": "20:00:00:50:56:b4:13:01",
  "wwpn": "20:00:00:50:56:b4:13:a8"
Status: 201, Created
num_records
integer
Number of records.
records
array[fc_interface]
  "records": [
      "location": {
        "home_node": {
          "name": "node1",
        "home_port": {
          "name": "0a",
          "node": {
            "name": "node1"
        "node": {
          "name": "node1",
        "port": {
          "name": "0a",
          "node": {
            "name": "node1"
      "name": "fc_lif1",
      "state": "string",
      "svm": {
        "name": "svm1",
Status: Default
ONTAP Error Response Codes
Error Code Description
1966140
An interface with the same name already exists.
1966217
The specified port is not valid on the node provided.
2621462
The supplied SVM does not exist.
2621706
The specified svm.uuid and svm.name do not refer to the same SVM.
2621707
No SVM was specified. Either svm.name or svm.uuid must be supplied.
5373966
A Fibre Channel interface with the fcp protocol cannot be created in an SVM that is configured for NVMe.
5374102
The specified Fibre Channel interface cannot be created because the Fibre Channel adapter is down. Bring the adapter up and try again.
5374871
The Fibre Channel port identified by the specified UUID does not refer to the same port as that identified by the specified node name and/or port name.
5374872
If either location.port.node.name or location.port.name is supplied, both properties must be supplied.
5374873
The Fibre Channel port must be specified using either location.port.uuid or location.port.node.name and location.port.name.
72089652
An NVMe service must be created before creating a Fibre Channel interface using the NVMe over FC data protocol.
72089672
The specified Fibre Channel port does not support the NVMe over FC data protocol.
72089900
A Fibre Channel interface with the fc_nvme protocol cannot be created in an SVM that is configured for a SAN protocol.
string
home_node
name
string
uuid
string
node
The node on which the FC port is located.
name
string
The name of the node on which the FC port is located.
fc_port_reference
An FC port is the physical port of an FC adapter on a cluster node that can be connected to an FC network.
name
string
The name of the FC port.
node
node
uuid
string
The unique identifier of the FC port.
node
name
string
uuid
string
location
home_node
home_node
home_port
fc_port_reference
is_home
boolean
Indicates whether or not the FC interface currently resides on the home node.
node
node
port
fc_port_reference
iops
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Peformance metric for write I/O operations.
latency
other
integer
read
integer
total
integer
write
integer
throughput
read
integer
total
integer
write
integer
metric
Performance numbers, such as IOPS latency and throughput
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
iops
iops
latency
latency
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance data.
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other
integer
read
integer
total
integer
write
integer
latency_raw
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation.
other
integer
read
integer
total
integer
write
integer
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
read
integer
total
integer
write
integer
statistics
These are raw performance numbers, such as IOPS latency and throughput. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
iops_raw
iops_raw
latency_raw
latency_raw
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput_raw
throughput_raw
timestamp
string
svm
name
string
The name of the SVM.
uuid
string
fc_interface
A Fibre Channel (FC) interface is the logical endpoint for FC network connections to an SVM. An FC interface provides FC access to storage within the interface SVM using either Fibre Channel Protocol or NVMe over Fibre Channel (NVMe/FC).
An FC interface is created on an FC port which is located on a cluster node. The FC port must be specified to identify the location of the interface for a POST or PATCH operation that relocates an interface. You can identify the port by supplying either the node and port names or the port UUID.
comment
string
data_protocol
string
enabled
boolean
location
location
name
string
port_address
string
state
string
svm
svm
uuid
string
wwnn
string
  • readOnly: 1
wwpn
string
  • readOnly: 1
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
