REST API reference
Create an FC interface
Creates an FC interface to establish Fibre Channel connectivity within an existing storage virtual machine (SVM). This operation is essential when you need to configure new connections or expand your storage network capabilities.
HTTP method and endpoint
POST /network/fc/interfaces
Introduced in
ONTAP 9.6
Required properties
  • svm.uuid or svm.name - Existing SVM in which to create the FC interface.
  • name - Name of the FC interface.
  • location.port.uuid or both location.port.name and location.port.node.name - FC port on which to create the FC interface.
  • data_protocol - Data protocol for the FC interface.
Default property values
If not specified in POST, the following default property values are assigned.
  • enabled - true
  • network interface create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
comment
string
A user configurable comment. Optional in POST; valid in PATCH. To clear a prior comment, set the property to an empty string in PATCH.
data_protocol
string
The data protocol for which the FC interface is configured. Required in POST.
enabled
boolean
The administrative state of the FC interface. The FC interface can be disabled to block all FC communication with the SVM through this interface. Optional in POST and PATCH; defaults to true (enabled) in POST.
location
location
The location of the FC interface is defined by the location of its port. An FC port is identified by its UUID, or a combination of its cluster node name and port name. Either the UUID or the cluster node name and port name are required for POST. To move an interface, supply either the port UUID or the cluster node name and port name in a PATCH.
location.node and location.port refer to the current location of the FC interface. This can be different from location.home_node and location.home_port in instances where the FC interface has failed over to its HA partner node. The location.node, location.port, and location.is_home properties are not available for interfaces on the inactive side of a MetroCluster relationship.
name
string
The name of the FC interface. Required in POST; optional in PATCH.
port_address
string
The port address of the FC interface. Each FC port in an FC switched fabric has its own unique FC port address for routing purposes. The FC port address is assigned by a switch in the fabric when that port logs in to the fabric. This property refers to the address given by a switch to the FC interface when the SVM performs a port login (PLOGI).
This is useful for obtaining statistics and diagnostic information from FC switches.
This is a hexadecimal encoded numeric value.
state
string
The current operational state of the FC interface. The state is set to down if the interface is not enabled.
If the cluster node hosting the port is down or unavailable, no state value is returned.
svm
svm
uuid
string
The unique identifier of the FC interface. Required in the URL.
wwnn
string
The world wide node name (WWNN) of the FC interface SVM. The WWNN is generated by ONTAP when Fibre Channel Protocol or the NVMe service is created for the FC interface SVM.
  • example: 20:00:00:50:56:b4:13:01
  • readOnly: 1
  • Introduced in: 9.6
  • x-nullable: true
wwpn
string
The world wide port name (WWPN) of the FC interface. The WWPN is generated by ONTAP when the FC interface is created.
  • example: 20:00:00:50:56:b4:13:a8
  • readOnly: 1
  • x-nullable: true
Example request
  "comment": "string",
  "data_protocol": "string",
  "location": {
    "home_node": {
      "name": "node1",
    "home_port": {
      "name": "0a",
      "node": {
        "name": "node1"
    "node": {
      "name": "node1",
    "port": {
      "name": "0a",
      "node": {
        "name": "node1"
  "name": "fc_lif1",
  "port_address": "5060F",
  "state": "string",
  "svm": {
    "name": "svm1",
  "uuid": "bce9827d-4d8f-60af-c771-6e8e9af2c6f0",
  "wwnn": "20:00:00:50:56:b4:13:01",
  "wwpn": "20:00:00:50:56:b4:13:a8"
Status: 201, Created
num_records
integer
The number of records in the response.
recommend
recommend
Response properties specific to the FC interface placement functionality. See the Interface placement recommendations section of DOC /network/fc/interfaces
records
array[fc_interface]
  "num_records": 1,
  "recommend": {
    "messages": [
        "arguments": [
            "code": "string",
            "message": "string"
        "code": 5375959,
        "message": "Network ports are disabled.",
        "severity": "informational"
  "records": [
      "location": {
        "home_node": {
          "name": "node1",
        "home_port": {
          "name": "0a",
          "node": {
            "name": "node1"
        "node": {
          "name": "node1",
        "port": {
          "name": "0a",
          "node": {
            "name": "node1"
      "name": "fc_lif1",
      "state": "string",
      "svm": {
        "name": "svm1",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
1966140
An interface with the same name already exists.
1966217
The specified port is not valid on the node provided.
2621462
The supplied SVM does not exist.
2621706
The specified svm.uuid and svm.name do not refer to the same SVM.
2621707
No SVM was specified. Either svm.name or svm.uuid must be supplied.
5373966
A Fibre Channel interface with the fcp protocol cannot be created in an SVM that is configured for NVMe.
5373982
An invalid WWN was specified. The length is incorrect.
5373983
An invalid WWN was specified. The format is incorrect.
5374102
The specified Fibre Channel interface cannot be created because the Fibre Channel adapter is down. Bring the adapter up and try again.
5374871
The Fibre Channel port identified by the specified UUID does not refer to the same port as that identified by the specified node name and/or port name.
5374872
If either location.port.node.name or location.port.name is supplied, both properties must be supplied.
5374873
The Fibre Channel port must be specified using either location.port.uuid or location.port.node.name and location.port.name.
72089652
An NVMe service must be created before creating a Fibre Channel interface using the NVMe over FC data protocol.
72089672
The specified Fibre Channel port does not support the NVMe over FC data protocol.
72089900
A Fibre Channel interface with the fc_nvme protocol cannot be created in an SVM that is configured for a SAN protocol.
72089901
NVMe over Fabrics does not support more than 2 LIFs per node per SVM.
string
home_node
name
string
uuid
string
node
The node on which the FC port is located.
name
string
The name of the node on which the FC port is located.
home_port
An FC port is the physical port of an FC adapter on a cluster node that can be connected to an FC network.
name
string
The name of the FC port.
node
node
uuid
string
The unique identifier of the FC port.
node
name
string
uuid
string
port
name
string
node
node
uuid
string
location
home_node
home_node
home_port
home_port
is_home
boolean
Indicates if the FC interface is currently on its home node.
node
node
port
port
iops
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Peformance metric for write I/O operations.
latency
other
integer
read
integer
total
integer
write
integer
throughput
read
integer
total
integer
write
integer
metric
Performance numbers, such as IOPS latency and throughput
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
iops
iops
latency
latency
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance data.
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other
integer
read
integer
total
integer
write
integer
latency_raw
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation.
other
integer
read
integer
total
integer
write
integer
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
read
integer
total
integer
write
integer
statistics
These are raw performance numbers, such as IOPS latency and throughput. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
iops_raw
iops_raw
latency_raw
latency_raw
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput_raw
throughput_raw
timestamp
string
svm
name
string
uuid
string
fc_interface
A Fibre Channel (FC) interface is the logical endpoint for FC network connections to an SVM. An FC interface provides FC access to storage within the interface SVM using either Fibre Channel Protocol or NVMe over Fibre Channel (NVMe/FC).
An FC interface is created on an FC port which is located on a cluster node. The FC port must be specified to identify the location of the interface for a POST or PATCH operation that relocates an interface. You can identify the port by supplying either the cluster node and port names or the port UUID.
comment
string
data_protocol
string
enabled
boolean
location
location
name
string
port_address
string
state
string
svm
svm
uuid
string
wwnn
string
  • readOnly: 1
  • x-nullable: true
wwpn
string
  • readOnly: 1
  • x-nullable: true
code
string
Argument code
message
string
Message argument
fc_interface_recommend_message
arguments
array[error_arguments]
The message substitution arguments.
code
string
The message code. Possible messages:
Error Code — Description
5375959 — Network ports are disabled.
5375960 — Network ports are enabled, but not reporting a connected FC fabric.
5375961 — The limit for the number of FC network interfaces on a cluster node has been reached.
5375962 — The limit for the number of FC network interfaces on a port has been reached.
5375963 — An HA pair of cluster nodes has a discrepancy in the presence of FC ports.
5375964 — An HA pair of cluster nodes has a discrepancy in support for an FC data protocol.
5375965 — An HA pair of cluster nodes cannot be reached from the same FC fabrics.
5375966 — A cluster node cannot be reached from all of the FC fabrics from which other cluster nodes with FC interfaces in the SVM can be reached.
5375967 — The limit for the number of FC network interfaces on a cluster node has been exceeded.
5375968 — The limit for the number of FC network interfaces on an FC port has been exceeded.
5375969 — The requested number of network interfaces per FC fabric per cluster node has not been achieved.
5375970 — The SVM cannot be reached from all of the FC fabrics to which the cluster is connected.
5375971 — The limit for the number of NVMe network interfaces on a cluster node has been exceeded.
5375972 — The limit for the number of cluster nodes containing NVMe network interfaces for the SVM has been exceeded.
5375973 — The SVM can be reached from a number of FC fabrics other than what is preferred.
message
string
The message text.
severity
string
The severity of the message. Message severities are as follows:
  • error - Messages reporting problems that must be corrected before creating the FC network interfaces.
  • warning - Messages indicating issues that need rectifying in order to achieve an optimal configuration.
  • informational - Messages providing relevant information for consideration.
recommend
messages
array[fc_interface_recommend_message]
Messages describing the results of a FC network interface placement operation or evaluation of caller-proposed locations.
returned_error
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
