Create an FC interface
POST /network/fc/interfaces
Creates an FC interface.
Required properties
svm.uuidorsvm.name- Existing SVM in which to create the FC interface. -
name- Name of the FC interface. -
location.port.uuidor bothlocation.port.nameandlocation.port.node.name- FC port on which to create the FC interface. -
data_protocol- Data protocol for the FC interface.
Default property values
If not specified in POST, the following default property values are assigned.
enabled- true
Related ONTAP commands
network interface create
Learn more
return_records |
boolean |
query |
False |
The default is false. If set to true, the records are returned. |
Request Body
| Name | Type | Description |
_links |
comment |
string |
A user configurable comment. Optional in POST; valid in PATCH. To clear a prior comment, set the property to an empty string in PATCH. |
data_protocol |
string |
The data protocol for which the FC interface is configured. Required in POST. |
enabled |
boolean |
The administrative state of the FC interface. The FC interface can be disabled to block all FC communication with the SVM through this interface. Optional in POST and PATCH; defaults to true (enabled) in POST. |
location |
The location of the FC interface is defined by the location of its port. An FC port is identified by its UUID, or a combination of its node name and port name. Either the UUID or the node name and port name are required for POST. To move an interface, supply either the UUID or the node name and port name in a PATCH. |
name |
string |
The name of the FC interface. Required in POST; optional in PATCH. |
port_address |
string |
The port address of the FC interface. Each FC port in an FC switched fabric has its own unique FC port address for routing purposes. The FC port address is assigned by a switch in the fabric when that port logs in to the fabric. This property refers to the address given by a switch to the FC interface when the SVM performs a port login (PLOGI). This is useful for obtaining statistics and diagnostic information from FC switches. This is a hexadecimal encoded numeric value. |
state |
string |
The current operational state of the FC interface. The state is set to down if the interface is not enabled. If the node hosting the port is down or unavailable, no state value is returned. |
svm |
uuid |
string |
The unique identifier of the FC interface. Required in the URL. |
wwnn |
string |
The world wide node name (WWNN) of the FC interface SVM. The WWNN is generated by ONTAP when Fibre Channel Protocol or the NVMe service is created for the FC interface SVM.
wwpn |
string |
The world wide port name (WWPN) of the FC interface. The WWPN is generated by ONTAP when the FC interface is created.
Example request
"href": "/api/resourcelink"
"comment": "string",
"data_protocol": "string",
"location": {
"node": {
"name": "node1",
"port": {
"name": "0a",
"node": {
"name": "node1"
"name": "lif1",
"port_address": "5060F",
"state": "string",
"svm": {
"name": "svm1",
"uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
"wwnn": "20:00:00:50:56:b4:13:01",
"wwpn": "20:00:00:50:56:b4:13:a8"
Status: 201, Created
_links |
num_records |
integer |
Number of records. |
records |
array[fc_interface] |
"next": {
"records": [
"location": {
"node": {
"name": "node1",
"port": {
"name": "0a",
"node": {
"name": "node1"
"name": "lif1",
"state": "string",
"svm": {
"name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1966140 |
An interface with the same name already exists. |
1966217 |
The specified port is not valid on the node provided. |
2621462 |
The supplied SVM does not exist. |
2621706 |
The specified |
2621707 |
No SVM was specified. Either |
5373966 |
A Fibre Channel interface with the fcp protocol cannot be created in an SVM that is configured for NVMe. |
5374102 |
The specified Fibre Channel interface cannot be created because the Fibre Channel adapter is down. Bring the adapter up and try again. |
5374871 |
The Fibre Channel port identified by the specified UUID does not refer to the same port as that identified by the specified node name and/or port name. |
5374872 |
If either |
5374873 |
The Fibre Channel port must be specified using either |
72089652 |
An NVMe service must be created before creating a Fibre Channel interface using the NVMe over FC data protocol. |
72089672 |
The specified Fibre Channel port does not support the NVMe over FC data protocol. |
72089900 |
A Fibre Channel interface with the fc_nvme protocol cannot be created in an SVM that is configured for a SAN protocol. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
node
_links |
name |
string |
uuid |
string |
node
The node on which the FC port is located.
name |
string |
The name of the node on which the FC port is located. |
fc_port_reference
An FC port is the physical port of an FC adapter on a cluster node that can be connected to an FC network.
_links |
name |
string |
The name of the FC port. |
node |
The node on which the FC port is located. |
uuid |
string |
The unique identifier of the FC port. |
location
node |
port |
An FC port is the physical port of an FC adapter on a cluster node that can be connected to an FC network. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
fc_interface
A Fibre Channel (FC) interface is the logical endpoint for FC network connections to an SVM. An FC interface provides FC access to storage within the interface SVM using either Fibre Channel Protocol or NVMe over Fibre Channel (NVMe/FC).
An FC interface is created on an FC port which is located on a cluster node. The FC port must be specified to identify the location of the interface for a POST or PATCH operation that relocates an interface. You can identify the port by supplying either the node and port names or the port UUID.
_links |
comment |
string |
data_protocol |
string |
enabled |
boolean |
location |
name |
string |
port_address |
string |
state |
string |
svm |
uuid |
string |
wwnn |
string |
wwpn |
string |
_links
next |
self |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
