Add nested initiator groups to an initiator group
Adds nested initiator groups to an existing initiator group. Use this to organize and manage access controls within your storage environment.
HTTP method and endpoint
POST /protocols/san/igroups/{igroup.uuid}/igroups
Introduced in
ONTAP 9.9
Usage notes
Adds one or more nested initiator groups to an initiator group. A single nested initiator group can be added by directly specifying the name or UUID. Multiple nested initiator groups can be added by specifying the names or UUIDs in the records array. Nested initiator groups cannot be added to an initiator group that already directly contains initiators.
Required properties
nameand/oruuidorrecords- Nested initiator groups to add to the initiator group.
Related ONTAP commands
lun igroup add
Learn more
igroup.uuid |
string |
path |
True |
The unique identifier of the parent initiator group. |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
igroup |
name |
string |
The name of the initiator group. |
records |
array[records] |
An array of initiator groups specified to add multiple nested initiator groups to an initiator group in a single API call. Not allowed when the |
uuid |
string |
The unique identifier of the initiator group. |
Example request
"igroup": {
"name": "igroup1",
"records": [
"name": "igroup1",
Status: 201, Created
num_records |
integer |
Number of records. |
records |
array[igroup_nested] |
"records": [
"igroup": {
"name": "igroup1",
"records": [
"name": "igroup1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5374735 |
An attempt was made to add a child igroup that would exceed the maximum allowable depth. |
5374736 |
A supplied child initiator group already exists in the parent initiator group's hierarchy. |
5374737 |
A supplied child initiator group already exists in another initiator group's hierarchy. |
5374739 |
A supplied child initiator group has an operating system type that differs from the parent initiator group. |
5374740 |
A supplied child initiator group has an protocol that differs from the parent initiator group. |
5374741 |
A supplied child initiator group is already owned by a different child in the initiator group's hierarchy. |
5374742 |
A supplied child initiator group contains an initiator that is already owned by another initiator group in the hierarchy. |
5374852 |
The initiator group specified in the URI does not exist. |
href |
string |
_links
igroup
uuid |
string |
records
name |
string |
uuid |
string |
igroup_nested
igroup |
name |
string |
records |
array[records] |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
