REST API reference
Add nested initiator groups to an initiator group
Adds nested initiator groups to an existing initiator group. Use this to manage and organize multiple initiator groups within your storage environment.
HTTP method and endpoint
POST /protocols/san/igroups/{igroup.uuid}/igroups
Introduced in
ONTAP 9.9
Usage notes
Adds one or more nested initiator groups to an initiator group. A single nested initiator group can be added by directly specifying the name or UUID. Multiple nested initiator groups can be added by specifying the names or UUIDs in the records array. Nested initiator groups cannot be added to an initiator group that already directly contains initiators.
Required properties
  • name and/or uuid or records - Nested initiator groups to add to the initiator group.
  • lun igroup add
igroup.uuid
string
path
True
The unique identifier of the parent initiator group.
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
igroup
igroup
name
string
The name of the initiator group.
records
array[records]
An array of initiator groups specified to add multiple nested initiator groups to an initiator group in a single API call. Not allowed when the name property is used.
uuid
string
The unique identifier of the initiator group.
Example request
  "igroup": {
  "name": "igroup1",
  "records": [
      "name": "igroup1",
Status: 201, Created
num_records
integer
The number of records in the response.
records
array[igroup_nested]
  "num_records": 1,
  "records": [
      "igroup": {
      "name": "igroup1",
      "records": [
          "name": "igroup1",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
5374735
An attempt was made to add a child igroup that would exceed the maximum allowable depth.
5374736
A supplied child initiator group already exists in the parent initiator group's hierarchy.
5374737
A supplied child initiator group already exists in another initiator group's hierarchy.
5374739
A supplied child initiator group has an operating system type that differs from the parent initiator group.
5374740
A supplied child initiator group has an protocol that differs from the parent initiator group.
5374741
A supplied child initiator group is already owned by a different child in the initiator group's hierarchy.
5374742
A supplied child initiator group contains an initiator that is already owned by another initiator group in the hierarchy.
5374764
An unreplicated initiator group cannot be added as a child of a replicated initiator group.
5374852
The initiator group specified in the URI does not exist.
5374878
The supplied child initiator group does not exist.
string
igroup
uuid
string
records
name
string
uuid
string
igroup_nested
igroup
igroup
name
string
records
array[records]
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
