Security login messages endpoint overview
Overview
You can use this API to display and manage the login messages configuration. The GET request retrieves all of the login messages in the cluster. GET operations on /security/login/messages/{uuid} retrieve the login messages configuration by UUID. PATCH operations on /security/login/messages/{uuid} update the login messages configuration by UUID.
Retrieving all of the login messages in the cluster
# The API:
/api/security/login/messages
# The call:
curl -X GET "https://<mgmt-ip>/api/security/login/messages?fields=*" -H "accept: application/hal+json"
# The response:
"records": [
"uuid": "2581e5aa-9fe3-11e8-b309-005056bbef18",
"scope": "cluster",
"banner": "*** WARNING: DO NOT PROCEED IF YOU ARE NOT AUTHORIZED! ****\n",
"message": "#### Welcome to Cluster X ####\n",
"show_cluster_message": true,
"href": "/api/security/login/messages/2581e5aa-9fe3-11e8-b309-005056bbef18"
"uuid": "7b1b3715-9ffa-11e8-a5dd-005056bbef18",
"scope": "svm",
"svm": {
"name": "svm1"
"message": "#### Welcome to SVM1 ####\n",
"href": "/api/security/login/messages/7b1b3715-9ffa-11e8-a5dd-005056bbef18"
"uuid": "8ddee11e-a58c-11e8-85e0-005056bbef18",
"scope": "svm",
"svm": {
"name": "svm3"
"banner": "*** WARNING: This system is for the use of authorized users only. ****\n",
"href": "/api/security/login/messages/8ddee11e-a58c-11e8-85e0-005056bbef18"
"uuid": "f7e41c99-9ffa-11e8-a5dd-005056bbef18",
"scope": "svm",
"svm": {
"name": "svm2"
"href": "/api/security/login/messages/f7e41c99-9ffa-11e8-a5dd-005056bbef18"
"num_records": 4,
"href": "/api/security/login/messages?fields=*"
Retrieving the login messages configuration at the cluster scope
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/security/login/messages?scope=cluster&fields=*" -H "accept: application/hal+json"
# The response:
"records": [
"scope": "cluster",
"num_records": 1,
"href": "/api/security/login/messages?scope=cluster&fields=*"
Retrieving the login banner configured at the cluster scope
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/security/login/messages?scope=cluster&fields=banner" -H "accept: application/hal+json"
# The response:
"records": [
"scope": "cluster",
"num_records": 1,
"href": "/api/security/login/messages?scope=cluster&fields=banner"
Retrieving the login messages configuration of a specific SVM
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/security/login/messages?svm.name=svm1&fields=*" -H "accept: application/hal+json"
# The response:
"records": [
"scope": "svm",
"svm": {
"name": "svm1"
"num_records": 1,
"href": "/api/security/login/messages?svm.name=svm1&fields=*"
Retrieving the login messages configuration by UUID, including all fields
# The API:
/api/security/login/messages/{uuid}
# The call:
curl -X GET "https://<mgmt-ip>/api/security/login/messages/7b1b3715-9ffa-11e8-a5dd-005056bbef18?fields=*" -H "accept: application/hal+json"
# The response:
"scope": "svm",
"svm": {
"name": "svm1"
Configuring the login banner in a cluster
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/security/login/messages?scope=cluster" -H "accept: application/hal+json" -H "Content-Type: appplication/json" -d "{ \"banner\": \"You are entering secure area.\" }"
# The response:
"num_records": 1,
"href": "/api/security/login/messages?scope=cluster"
Configuring the message of the day (MOTD) in a cluster
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/security/login/messages?scope=cluster" -H "accept: application/hal+json" -H "Content-Type: appplication/json" -d "{ \"message\": \"Welcome to Cluster X\", \"show_cluster_message\": true }"
# The response:
"num_records": 1,
Clearing the login banner and message of the day (MOTD) in a cluster
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/security/login/messages?scope=cluster" -H "accept: application/hal+json" -H "Content-Type: appplication/json" -d "{ \"banner\": \"\", \"message\": \"\" }"
# The response:
"num_records": 1,
Configuring the login messages for a specific SVM
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/security/login/messages?svm.name=svm1" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "{ \"banner\" : \"AUTHORIZED ACCESS ONLY\", \"message\": \"WELCOME!\" }"
# The response:
"num_records": 1,
"href": "/api/security/login/messages?svm.name=svm1"
Configuring the login messages by UUID
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/security/login/messages/7b1b3715-9ffa-11e8-a5dd-005056bbef18" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "{ \"banner\" : \"AUTHORIZED ACCESS ONLY\", \"message\": \"WELCOME!\" }"
Clearing the login messages configuration by UUID
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/security/login/messages/7b1b3715-9ffa-11e8-a5dd-005056bbef18" -H "accept: application/hal+json" -H "Content-Type: appplication/json" -d "{ \"banner\": \"\", \"message\": \"\" }"
