REST API reference
Retrieve MetroCluster operations
Retrieve recent MetroCluster operations to monitor and analyze the performance and status of your cluster activities. For detailed insights into specific operations, utilize the /cluster/metrocluster/operations/{uuid} endpoint.
Overview
Retrieves a list of recent MetroCluster operations. To view more information about a specific operation, use the /cluster/metrocluster/operations/{uuid} API endpoint.
Retrieves all MetroCluster operations
GET https://<mgmt-ip>/api/cluster/metrocluster/operations?fields=*
  "records": [
          "uuid": "a14ae39f-8d85-11e9-b4a7-00505682dc8b",
          "type": "check",
          "state": "successful",
          "start_time": "2019-06-14T11:15:00-07:00",
          "end_time": "2019-06-14T11:16:08-07:00",
                  "href": "/api/cluster/metrocluster/operations/a14ae39f-8d85-11e9-b4a7-00505682dc8b"
          "uuid": "7058df27-8d85-11e9-bbc9-005056826931",
          "type": "configure",
          "start_time": "2019-06-12T19:46:27-07:00",
          "end_time": "2019-06-12T19:48:17-07:00",
                  "href": "/api/cluster/metrocluster/operations/7058df27-8d85-11e9-bbc9-005056826931"
          "uuid": "7849515d-8d84-11e9-bbc9-005056826931",
          "type": "connect",
          "start_time": "2019-06-12T19:39:30-07:00",
          "end_time": "2019-06-12T19:42:02-07:00",
                  "href": "/api/cluster/metrocluster/operations/7849515d-8d84-11e9-bbc9-005056826931"
          "uuid": "331c79ad-8d84-11e9-b4a7-00505682dc8b",
          "type": "interface_create",
          "start_time": "2019-06-12T19:37:35-07:00",
          "end_time": "2019-06-12T19:37:41-07:00",
                  "href": "/api/cluster/metrocluster/operations/331c79ad-8d84-11e9-b4a7-00505682dc8b"
  "num_records": 4,
          "href": "/api/cluster/metrocluster/operations?fields=%2A"
Retrieves Information about a specific MetroCluster operation
GET https://<mgmt-ip>/api/cluster/metrocluster/operations/0db12274-86fd-11e9-8053-00505682c342
  "uuid": "0db12274-86fd-11e9-8053-00505682c342",
  "name": "check",
  "start_time": "2019-06-06T16:15:01-07:00",
  "end_time": "2019-06-06T16:16:05-07:00",
          "href": "/api/cluster/metrocluster/operations/0db12274-86fd-11e9-8053-00505682c342"
