REST API reference
Retrieve historical port performance metrics
Accesses historical performance metrics for a port, helping you analyze past port performance trends and identify potential issues.
HTTP method and endpoint
GET /network/ethernet/ports/{uuid}/metrics
Introduced in
ONTAP 9.8
Usage notes
Retrieves historical performance metrics for a port.
throughput.write
integer
query
False
Filter by throughput.write
throughput.total
integer
query
False
Filter by throughput.total
throughput.read
integer
query
False
Filter by throughput.read
duration
string
query
False
Filter by duration
timestamp
string
query
False
Filter by timestamp
status
string
query
False
Filter by status
uuid
string
path
True
Unique identifier of the port.
interval
string
query
False
The time range for the data. Examples can be 1h, 1d, 1m, 1w, 1y. The period for each time range is as follows:
  • 1h: Metrics over the most recent hour sampled over 15 seconds.
  • 1d: Metrics over the most recent day sampled over 5 minutes.
  • 1w: Metrics over the most recent week sampled over 30 minutes.
  • 1m: Metrics over the most recent month sampled over 2 hours.
  • 1y: Metrics over the most recent year sampled over a day.
  • Default value: 1
  • enum: ["1h", "1d", "1w", "1m", "1y"]
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
order_by
array[string]
query
False
desc] direction. Default direction is 'asc' for ascending.
return_records
boolean
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[records]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "duration": "PT15S",
      "status": "ok",
      "throughput": {
        "read": 200,
        "total": 1000,
        "write": 100
      "timestamp": "2017-01-25 11:20:13 +0000",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
throughput
The rate of throughput bytes per second observed at the interface.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Performance metric for write I/O operations.
records
Throughput performance for the Ethernet port.
_links
_links
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
status
string
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance data.
uuid
string
Port UUID
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
