Retrieve an FC fabric zone
GET /network/fc/fabrics/{fabric.name}/zones/{name}
Introduced In: 9.11
Retrieves a zone of the active zoneset of a Fibre Channel fabric.
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
members
Related ONTAP commands
network fcp zone show
Learn more
fabric.name |
string |
path |
True |
The WWN of the primary switch of the Fibre Channel fabric. |
name |
string |
path |
True |
The name of a zone in the active zoneset the Fibre Channel fabric. |
cache.maximum_age |
string |
query |
False |
The maximum age of data in the Fibre Channel fabric cache before it should be refreshed from the fabric. The default is 15 minutes.
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
cache |
Properties of Fibre Chanel fabric cache. |
fabric |
A reference to a Fibre Channel fabric. |
members |
array[members] |
An array of Fibre Channel zone members. |
name |
string |
The name of the Fibre Channel zone. |
"href": "/api/resourcelink"
"cache": {
"age": "PT3M30S",
"update_time": "string"
"fabric": {
"name": "10:00:d1:d2:d3:d4:d5:d6"
"members": [
"name": "10:00:12:34:56:78:9a:bc",
"type": "port_name"
"name": "zone1"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5373982 |
An invalid WWN was specified. The length is incorrect. |
5373983 |
An invalid WWN was specified. The format is incorrect. |
5375053 |
The Fibre Channel fabric specified by name in the request URI was not found in the FC fabric cache. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
cache
age |
string |
The age of the Fibre Channel fabric data cache retrieved. If the FC fabric data cache has not been fully updated for a newly discovered fabric, or a fabric that has been re-discovered after being purged, a value for this property will not be retrieved. The value is in ISO 8601 duration format. |
is_current |
boolean |
A boolean that indicates if the retrieved data is current relative to the |
update_time |
string |
The date and time at which the Fibre Channel fabric data cache retrieved was last updated. If the FC fabric data cache has not been fully updated for a newly discovered fabric, or a fabric that has been re-discovered after being purged, a value for this property will not be retrieved. |
fabric
_links |
name |
string |
The world wide name (WWN) of the primary switch of the Fibre Channel (FC) fabric. This is used as a unique identifier for the FC fabric. |
members
A Fibre Channel zone member.
name |
string |
The identifying property value of the zone member. The format of this value depends on the member type:
# The following types might not report a name:
type |
string |
The type of Fibre Channel zone member. This value should be used to interpret the contents of the |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
