Retrieve local group information for a group and SVM
GET /protocols/cifs/local-groups/{svm.uuid}/{sid}
Introduced In: 9.10
Retrieves local group information for the specified group and SVM.
Advanced properties
members
Related ONTAP commands
vserver cifs users-and-groups local-group show -
vserver cifs users-and-groups local-group show-members
Learn more
sid |
string |
path |
True |
Local group SID |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
description |
string |
Description for the local group. |
members |
array[members] |
name |
string |
Local group name. The maximum supported length of a group name is 256 characters. |
sid |
string |
The security ID of the local group which uniquely identifies the group. The group SID is automatically generated in POST and it is retrieved using the GET method. |
svm |
"href": "/api/resourcelink"
"description": "This is a local group",
"members": [
"name": "string"
"name": "SMB_SERVER01\\group",
"sid": "S-1-5-21-256008430-3394229847-3930036330-1001",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
members
name |
string |
Local user, Active Directory user, or Active Directory group which is a member of the specified local group. |
svm
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
