Retrieve a CIFS server
Retrieves a CIFS server to view its current configuration and settings within your network environment. This enables you to monitor and manage CIFS services effectively.
HTTP method and endpoint
GET /protocols/cifs/services/{svm.uuid}
Introduced in
ONTAP 9.6
Related ONTAP commands
vserver cifs server show -
vserver cifs server options show -
vserver cifs server security show
Learn more
svm.uuid |
string |
path |
True |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
ad_domain |
auth-style |
string |
Authentication type. |
auth_user_type |
string |
Specifies the type of user who can access the SMB Volume. The default is domain_user. In the case of a hybrid-user, ONTAP won't contact on-premise ADDS.
authentication_method |
string |
Specifies the authentication method. The available values are:
azure_cloud_region |
string |
Specifies the azure cloud location of the tenant in case of hybrid-user authentication |
client_id |
string |
Application client ID of the deployed Azure application with appropriate access to an AKV or EntraId. |
comment |
string |
A descriptive text comment for the CIFS server. SMB clients can see the CIFS server comment when browsing servers on the network. If there is a space in the comment, you must enclose the entire string in quotation marks. |
default_unix_user |
string |
Specifies the UNIX user to which any authenticated CIFS user is mapped to, if the normal user mapping rules fails. |
enabled |
boolean |
Specifies if the CIFS service is administratively enabled. |
group_policy_object_enabled |
boolean |
If set to true, group policies will be applied to the SVM. |
key_vault_uri |
string |
URI of the deployed AKV that is used by ONTAP for storing keys.
metric |
Performance numbers, such as IOPS latency and throughput, for SVM protocols. |
name |
string |
The name of the CIFS server. |
netbios |
oauth_host |
string |
Open authorization server host name. |
options |
proxy_host |
string |
Proxy host. |
proxy_port |
integer |
Proxy port. |
proxy_type |
string |
Proxy type. |
proxy_username |
string |
Proxy username. |
security |
statistics |
These are raw performance numbers, such as IOPS latency and throughput for SVM protocols. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster. |
svm |
tenant_id |
string |
Directory (tenant) ID of the deployed Azure application with appropriate access to an AKV or EntraId. |
timeout |
integer |
AKV connection timeout, in seconds. The allowed range is between 0 to 30 seconds. |
verify_host |
boolean |
Verify the identity of the AKV host name. By default, verify_host is set to true. |
workgroup |
string |
The workgroup name. |
"href": "/api/resourcelink"
"ad_domain": {
"default_site": "string",
"fqdn": "example.com",
"organizational_unit": "string"
"auth-style": "domain",
"auth_user_type": "string",
"authentication_method": "string",
"azure_cloud_region": "string",
"client_id": "e959d1b5-5a63-4284-9268-851e30e3eceb",
"comment": "This CIFS Server Belongs to CS Department",
"default_unix_user": "string",
"key_vault_uri": "https://kmip-akv-keyvault.vault.azure.net/",
"metric": {
"duration": "PT15S",
"iops": {
"read": 200,
"total": 1000,
"write": 100
"latency": {
"read": 200,
"total": 1000,
"write": 100
"status": "ok",
"throughput": {
"read": 200,
"total": 1000,
"write": 100
"timestamp": "2017-01-25 11:20:13 +0000"
"name": "CIFS1",
"netbios": {
"aliases": [
"ALIAS_1",
"ALIAS_2",
"ALIAS_3"
"wins_servers": [
"10.224.65.20",
"10.224.65.21"
"oauth_host": "login.microsoftonline.com",
"options": {
"max_connections_per_session": 32,
"max_lifs_per_session": 256,
"max_opens_same_file_per_tree": 1000,
"max_same_tree_connect_per_session": 5000,
"max_same_user_sessions_per_connection": 2500,
"max_watches_set_per_tree": 500,
"null_user_windows_name": "string",
"smb_credits": 128,
"widelink_reparse_versions": [
"smb1"
"proxy_host": "proxy.eng.com",
"proxy_port": 1234,
"proxy_type": "string",
"proxy_username": "proxyuser",
"security": {
"advertised_kdc_encryptions": [
"string"
"lm_compatibility_level": "string",
"restrict_anonymous": "string",
"session_security": "string"
"statistics": {
"iops_raw": {
"read": 200,
"total": 1000,
"write": 100
"latency_raw": {
"read": 200,
"total": 1000,
"write": 100
"status": "ok",
"throughput_raw": {
"read": 200,
"total": 1000,
"write": 100
"svm": {
"name": "svm1",
"tenant_id": "c9f32fcb-4ab7-40fe-af1b-1850d46cfbbe",
"timeout": 25,
"workgroup": "workgrp1"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
ad_domain
default_site |
string |
The default site used by LIFs that do not have a site membership. |
fqdn |
string |
The fully qualified domain name of the Windows Active Directory to which this CIFS server belongs. A CIFS server appears as a member of Windows server object in the Active Directory store. POST and PATCH only. |
organizational_unit |
string |
Specifies the organizational unit within the Active Directory domain to associate with the CIFS server. POST and PATCH only. |
iops
other |
integer |
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on. |
read |
integer |
Performance metric for read I/O operations. |
total |
integer |
Performance metric aggregated over all types of I/O operations. |
write |
integer |
Performance metric for write I/O operations. |
latency
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput
read |
integer |
total |
integer |
write |
integer |
metric
_links |
duration |
string |
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations: |
iops |
The rate of I/O operations observed at the storage object. |
latency |
The round trip latency in microseconds observed at the storage object. |
status |
string |
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput |
The rate of throughput bytes per second observed at the storage object. |
timestamp |
string |
The timestamp of the performance data. |
cifs_netbios
aliases |
array[string] |
enabled |
boolean |
Specifies whether NetBios name service (NBNS) is enabled for the CIFS. If this service is enabled, the CIFS server will start sending the broadcast for name registration. |
wins_servers |
array[string] |
cifs_service_options
admin_to_root_mapping |
boolean |
Specifies whether or not Administrator can be mapped to the UNIX user "root". |
advanced_sparse_file |
boolean |
Specifies whether or not the CIFS server supports the advanced sparse file capabilities. This allows CIFS clients to query the allocated ranges of a file and to write zeroes or free data blocks for ranges of a file. |
backup_symlink_enabled |
boolean |
Specifies whether or not to preserve UNIX symlinks during backup through SMB. |
client_dup_detection_enabled |
boolean |
Specifies whether or not client duplicate session detection is enabled for CIFS. |
client_version_reporting_enabled |
boolean |
Specifies whether or not client version reporting is enabled for CIFS. |
copy_offload |
boolean |
Specifies whether or not to enable the Copy Offload feature. This feature enables direct data transfers within or between compatible storage devices without transferring the data through the host computer. Note that this will also enable/disable the direct copy feature accordingly. |
dac_enabled |
boolean |
Specifies whether or not the Dynamic Access Control (DAC) feature is enabled for the CIFS server. |
export_policy_enabled |
boolean |
Specifies whether or not export policies are enabled for CIFS. |
fake_open |
boolean |
Specifies whether or not fake open support is enabled. This parameter allows you to optimize the open and close requests coming from SMB 2 clients. |
fsctl_trim |
boolean |
Specifies whether or not the trim requests (FSCTL_FILE_LEVEL_TRIM) are supported on the CIFS server. |
junction_reparse |
boolean |
Specifies whether or not the reparse point support is enabled. When enabled the CIFS server exposes junction points to Windows clients as reparse points. This parameter is only active if the client has negotiated use of the SMB 2 or SMB 3 protocol. This parameter is not supported for SVMs with Infinite Volume. |
large_mtu |
boolean |
Specifies whether or not SMB clients can send reads up to 1 MB in size. |
max_connections_per_session |
integer |
Specifies the maximum number of connections allowed per multichannel session. |
max_lifs_per_session |
integer |
Specifies the maximum number of LIFs advertised per multichannel session. |
max_opens_same_file_per_tree |
integer |
Specifies the maximum number of opens on the same file per tree. |
max_same_tree_connect_per_session |
integer |
Specifies the maximum number of same tree connections per session. |
max_same_user_sessions_per_connection |
integer |
Specifies the maximum number of same user sessions per connection. |
max_watches_set_per_tree |
integer |
Specifies the maximum number of watches set per tree. |
multichannel |
boolean |
Specifies whether or not the CIFS server supports Multichannel. |
null_user_windows_name |
string |
Specifies a Windows User or Group name that should be mapped in case of a NULL user value. |
path_component_cache |
boolean |
Specifies whether or not the path component cache is enabled on the CIFS server. |
referral |
boolean |
Specifies whether or not to refer clients to more optimal LIFs. When enabled, it automatically refers clients to a data LIF local to the node which hosts the root of the requested share. |
shadowcopy |
boolean |
Specifies whether or not to enable the Shadowcopy Feature. This feature enables to take share-based backup copies of data that is in a data-consistent state at a specific point in time where the data is accessed over SMB 3.0 shares. |
shadowcopy_dir_depth |
integer |
Specifies the maximum level of subdirectories on which ONTAP should create shadow copies.
smb_credits |
integer |
Specifies the maximum number of outstanding requests on a CIFS connection. |
trusted_domain_enum_search_enabled |
boolean |
Specifies whether or not to enable trusted domain search.
widelink_reparse_versions |
array[string] |
Specifies the CIFS protocol versions for which the widelink is reported as reparse point. |
cifs_service_security
| Name | Type | Description | ||
advertised_kdc_encryptions |
array[string] |
aes_netlogon_enabled |
boolean |
Specifies whether or not an AES session key is enabled for the Netlogon channel. |
encrypt_dc_connection |
boolean |
Specifies whether encryption is required for domain controller connections. |
kdc_encryption |
boolean |
ldap_referral_enabled |
boolean |
Specifies whether or not LDAP referral chasing is enabled for AD LDAP connections. |
lm_compatibility_level |
string |
It is CIFS server minimum security level, also known as the LMCompatibilityLevel. The minimum security level is the minimum level of the security tokens that the CIFS server accepts from SMB clients. The available values are:
restrict_anonymous |
string |
Specifies what level of access an anonymous user is granted. An anonymous user (also known as a "null user") can list or enumerate certain types of system information from Windows hosts on the network, including user names and details, account policies, and share names. Access for the anonymous user can be controlled by specifying one of three access restriction settings. The available values are:
session_security |
string |
Specifies client session security for AD LDAP connections. The available values are:
smb_encryption |
boolean |
Specifies whether encryption is required for incoming CIFS traffic. |
smb_signing |
boolean |
Specifies whether signing is required for incoming CIFS traffic. SMB signing helps to ensure that network traffic between the CIFS server and the client is not compromised. |
try_ldap_channel_binding |
boolean |
Specifies whether or not channel binding is attempted in the case of TLS/LDAPS. |
use_ldaps |
boolean |
Specifies whether or not to use use LDAPS for secure Active Directory LDAP connections by using the TLS/SSL protocols. |
use_start_tls |
boolean |
Specifies whether or not to use SSL/TLS for allowing secure LDAP communication with Active Directory LDAP servers. |
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
latency_raw
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
read |
integer |
total |
integer |
write |
integer |
statistics
iops_raw |
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time. |
latency_raw |
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation. |
status |
string |
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput_raw |
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time. |
timestamp |
string |
svm
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
