Retrieve initiators
Retrieves initiators to access information about the initiator configuration and details within your storage environment.
HTTP method and endpoint
GET /protocols/san/initiators
Introduced in
ONTAP 9.14
Related ONTAP commands
lun igroup initiator show
Learn more
comment |
string |
query |
False |
Filter by comment
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
name |
string |
query |
False |
Filter by name |
protocol |
string |
query |
False |
Filter by protocol |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
The number of records in the response. |
records |
array[initiator] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"comment": "My initiator comment.",
"name": "iqn.2018-02.com.netapp.iscsi:name1",
"protocol": "iscsi",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
svm
The SVM for which the initiator properties are configured.
_links |
name |
string |
uuid |
string |
initiator
An initiator is a Fibre Channel (FC) world wide port name (WWPN), an iSCSI Qualified Name (IQN), or an iSCSI EUI (Extended Unique Identifier) that identifies a host endpoint. Initiators are collected into initiator groups (igroups) used to control which hosts can access specific LUNs. Initiators are also discovered as they log in to SAN network LIFs.
ONTAP supports configuration for an initiator. Configured properties apply to all uses of the initiator within an SVM. Although the same initiator may interact with multiple SVMs of a cluster, ONTAP treats initiator configuration as an SVM-scoped activity. For example, a comment may be set for an initiator in a specific SVM. The comment value applies to all uses of the initiator in the SVM including use in multiple initiator groups. But a different comment value may be specified for the same initiator in a different SVM.
comment |
string |
A user-specified comment. |
name |
string |
The name of the initiator. |
protocol |
string |
The protocol of the initiator. |
svm |
The SVM for which the initiator properties are configured. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
