Retrieve iSCSI services
Retrieves information about iSCSI services to understand their current configurations and operational state. You might use this endpoint when you need detailed insights into your iSCSI setup within your storage environment.
HTTP method and endpoint
GET /protocols/san/iscsi/services
Introduced in
ONTAP 9.6
Usage notes
Retrieves iSCSI services.
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
statistics.* -
metric.*
Related ONTAP commands
vserver iscsi show
Learn more
enabled |
boolean |
query |
False |
Filter by enabled |
statistics.latency_raw.read |
integer |
query |
False |
Filter by statistics.latency_raw.read
statistics.latency_raw.other |
integer |
query |
False |
Filter by statistics.latency_raw.other
statistics.latency_raw.total |
integer |
query |
False |
Filter by statistics.latency_raw.total
statistics.latency_raw.write |
integer |
query |
False |
Filter by statistics.latency_raw.write
statistics.iops_raw.read |
integer |
query |
False |
Filter by statistics.iops_raw.read
statistics.iops_raw.other |
integer |
query |
False |
Filter by statistics.iops_raw.other
statistics.iops_raw.total |
integer |
query |
False |
Filter by statistics.iops_raw.total
statistics.iops_raw.write |
integer |
query |
False |
Filter by statistics.iops_raw.write
statistics.throughput_raw.write |
integer |
query |
False |
Filter by statistics.throughput_raw.write
statistics.throughput_raw.total |
integer |
query |
False |
Filter by statistics.throughput_raw.total
statistics.throughput_raw.read |
integer |
query |
False |
Filter by statistics.throughput_raw.read
statistics.timestamp |
string |
query |
False |
Filter by statistics.timestamp
statistics.status |
string |
query |
False |
Filter by statistics.status
metric.duration |
string |
query |
False |
Filter by metric.duration
metric.latency.read |
integer |
query |
False |
Filter by metric.latency.read
metric.latency.other |
integer |
query |
False |
Filter by metric.latency.other
metric.latency.total |
integer |
query |
False |
Filter by metric.latency.total
metric.latency.write |
integer |
query |
False |
Filter by metric.latency.write
metric.timestamp |
string |
query |
False |
Filter by metric.timestamp
metric.status |
string |
query |
False |
Filter by metric.status
metric.throughput.write |
integer |
query |
False |
Filter by metric.throughput.write
metric.throughput.total |
integer |
query |
False |
Filter by metric.throughput.total
metric.throughput.read |
integer |
query |
False |
Filter by metric.throughput.read
metric.iops.read |
integer |
query |
False |
Filter by metric.iops.read
metric.iops.other |
integer |
query |
False |
Filter by metric.iops.other
metric.iops.total |
integer |
query |
False |
Filter by metric.iops.total
metric.iops.write |
integer |
query |
False |
Filter by metric.iops.write
target.name |
string |
query |
False |
Filter by target.name
target.alias |
string |
query |
False |
Filter by target.alias
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
The number of records in the response. |
records |
array[iscsi_service] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"metric": {
"duration": "PT15S",
"iops": {
"read": 200,
"total": 1000,
"write": 100
"latency": {
"read": 200,
"total": 1000,
"write": 100
"status": "ok",
"throughput": {
"read": 200,
"total": 1000,
"write": 100
"timestamp": "2017-01-25 11:20:13 +0000"
"statistics": {
"iops_raw": {
"read": 200,
"total": 1000,
"write": 100
"latency_raw": {
"read": 200,
"total": 1000,
"write": 100
"status": "ok",
"throughput_raw": {
"read": 200,
"total": 1000,
"write": 100
"svm": {
"name": "svm1",
"target": {
"alias": "svm1",
"name": "iqn.1992-08.com.netapp:sn.574caf71890911e8a6b7005056b4ea79:vs.2"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
iops
other |
integer |
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on. |
read |
integer |
Performance metric for read I/O operations. |
total |
integer |
Performance metric aggregated over all types of I/O operations. |
write |
integer |
Performance metric for write I/O operations. |
latency
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput
read |
integer |
total |
integer |
write |
integer |
metric
Performance numbers, such as IOPS latency and throughput, for SVM protocols.
_links |
duration |
string |
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations: |
iops |
The rate of I/O operations observed at the storage object. |
latency |
The round trip latency in microseconds observed at the storage object. |
status |
string |
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput |
The rate of throughput bytes per second observed at the storage object. |
timestamp |
string |
The timestamp of the performance data. |
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
latency_raw
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
read |
integer |
total |
integer |
write |
integer |
statistics
These are raw performance numbers, such as IOPS latency and throughput for SVM protocols. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
iops_raw |
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time. |
latency_raw |
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation. |
status |
string |
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput_raw |
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time. |
timestamp |
string |
svm
_links |
name |
string |
uuid |
string |
target
alias |
string |
The iSCSI target alias of the iSCSI service. The target alias can contain one (1) to 128 characters and feature any printable character except space (" "). A PATCH request with an empty alias ("") clears the alias. Optional in POST and PATCH. In POST, this defaults to the name of the SVM. |
name |
string |
The iSCSI target name of the iSCSI service. This is generated for the SVM during POST. If required, the target name can be modified using the ONTAP command line.
iscsi_service
An iSCSI service defines the properties of the iSCSI target for an SVM. There can be at most one iSCSI service for an SVM. An SVM's iSCSI service must be created before iSCSI initiators can log in to the SVM.
An iSCSI service is identified by the UUID of its SVM.
_links |
enabled |
boolean |
The administrative state of the iSCSI service. The iSCSI service can be disabled to block all iSCSI connectivity to the SVM. Optional in POST and PATCH. The default setting is true (enabled) in POST. |
metric |
Performance numbers, such as IOPS latency and throughput, for SVM protocols. |
statistics |
These are raw performance numbers, such as IOPS latency and throughput for SVM protocols. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster. |
svm |
target |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
