Retrieve the OIDC configuration in the ONTAP cluster
Retrieves the OIDC configuration in the cluster to review the current authentication settings for OIDC integration.
HTTP method and endpoint
GET /security/authentication/cluster/oidc
Introduced in
ONTAP 9.19
Related ONTAP commands
security oidc show
jwks_refresh_interval |
string |
query |
False |
Filter by jwks_refresh_interval |
issuer |
string |
query |
False |
Filter by issuer |
skip_uri_validation |
boolean |
query |
False |
Filter by skip_uri_validation |
end_session_endpoint |
string |
query |
False |
Filter by end_session_endpoint |
client_id |
string |
query |
False |
Filter by client_id |
provider |
string |
query |
False |
Filter by provider |
remote_user_claim |
string |
query |
False |
Filter by remote_user_claim |
access_token_issuer |
string |
query |
False |
Filter by access_token_issuer |
outgoing_proxy |
string |
query |
False |
Filter by outgoing_proxy |
token_endpoint |
string |
query |
False |
Filter by token_endpoint |
client_secret |
string |
query |
False |
Filter by client_secret |
enabled |
boolean |
query |
False |
Filter by enabled |
redirect_ipaddress |
string |
query |
False |
Filter by redirect_ipaddress |
provider_jwks_uri |
string |
query |
False |
Filter by provider_jwks_uri |
authorization_endpoint |
string |
query |
False |
Filter by authorization_endpoint |
client_secret_hash |
string |
query |
False |
Filter by client_secret_hash |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
string |
The issuer value for the access token when it is different from the OpenID Connect issuer. |
string |
The URI of the authorization endpoint for the OpenID Connect provider. |
client_id |
string |
The client ID for the application. |
client_secret |
string |
The client secret for the application. |
string |
The hash of the client secret for the application. |
enabled |
boolean |
Indicates whether the OpenID Connect configuration is enabled. |
string |
The URI of the end session endpoint for the OpenID Connect provider. |
issuer |
string |
The URI of the OpenID Connect provider. |
string |
The refresh interval for the JSON Web Key Set (JWKS), in ISO-8601 format. This can be set to a value from 300 seconds to 2147483647 seconds. |
outgoing_proxy |
string |
Outgoing proxy to access external identity providers (IdPs). If not specified, no proxy is configured. |
provider |
string |
The OpenID Connect provider type. |
provider_jwks_uri |
string |
The URI of the JSON Web Key Set (JWKS) for the OpenID Connect provider. |
string |
The IP address to redirect to after authentication. |
remote_user_claim |
string |
The claim used to identify the remote user. |
boolean |
Indicates whether to skip URI validation. |
token_endpoint |
string |
The URI of the token endpoint for the OpenID Connect provider. |
"href": "/api/resourcelink"
"access_token_issuer": "https://example.netapp.com/adfs/services/trust",
"authorization_endpoint": "https://example.netapp.com/adfs/oauth2/authorize",
"client_id": "1234567890abcdef",
"client_secret": "1234567890abcdef1234567890abcdef",
"client_secret_hash": "1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef",
"enabled": 1,
"end_session_endpoint": "https://example.netapp.com/adfs/oauth2/logout",
"issuer": "https://example.netapp.com/adfs",
"jwks_refresh_interval": "PT2H",
"outgoing_proxy": "https://johndoe:secretpass@proxy.example.com:8080",
"provider": "adfs",
"provider_jwks_uri": "https://example.netapp.com/adfs/discovery/v2.0/keys",
"redirect_ipaddress": "10.10.10.10",
"remote_user_claim": "unique_name",
"skip_uri_validation": "",
"token_endpoint": "https://example.netapp.com/adfs/oauth2/token"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
