REST API reference
Retrieve all AWS KMS instances configured for all clusters and SVMs
Retrieves all AWS KMS instances that are configured across your clusters and SVMs, helping you manage and monitor your encryption key sources effectively.
HTTP method and endpoint
GET /security/aws-kms
Introduced in
ONTAP 9.12
Usage notes
Retrieves all AWS KMS instances configured for all clusters and SVMs.
  • security key-manager external aws show
  • security key-manager external aws check
verify
boolean
query
False
Filter by verify
access_key_id
string
query
False
Filter by access_key_id
key_id
string
query
False
Filter by key_id
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
amazon_reachability.code
string
query
False
Filter by amazon_reachability.code
amazon_reachability.reachable
boolean
query
False
Filter by amazon_reachability.reachable
amazon_reachability.message
string
query
False
Filter by amazon_reachability.message
verify_ip
boolean
query
False
Filter by verify_ip
proxy_port
integer
query
False
Filter by proxy_port
encryption_context
string
query
False
Filter by encryption_context
skip_verify
boolean
query
False
Filter by skip_verify
ekmip_reachability.message
string
query
False
Filter by ekmip_reachability.message
ekmip_reachability.node.name
string
query
False
Filter by ekmip_reachability.node.name
ekmip_reachability.node.uuid
string
query
False
Filter by ekmip_reachability.node.uuid
ekmip_reachability.reachable
boolean
query
False
Filter by ekmip_reachability.reachable
ekmip_reachability.code
string
query
False
Filter by ekmip_reachability.code
proxy_host
string
query
False
Filter by proxy_host
verify_host
boolean
query
False
Filter by verify_host
port
integer
query
False
Filter by port
proxy_username
string
query
False
Filter by proxy_username
polling_period
integer
query
False
Filter by polling_period
scope
string
query
False
Filter by scope
state.cluster_state
boolean
query
False
Filter by state.cluster_state
state.message
string
query
False
Filter by state.message
state.code
string
query
False
Filter by state.code
proxy_type
string
query
False
Filter by proxy_type
region
string
query
False
Filter by region
service
string
query
False
Filter by service
uuid
string
query
False
Filter by uuid
default_domain
string
query
False
Filter by default_domain
host
string
query
False
Filter by host
timeout
integer
query
False
Filter by timeout
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[aws_kms]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "access_key_id": "<AWS-ACCESS-KEY-ID>",
      "amazon_reachability": {
        "code": "346758",
        "message": "Amazon KMS is not reachable from all nodes - <reason>."
      "default_domain": "domainName",
      "ekmip_reachability": [
          "code": "346758",
          "message": "embedded KMIP server status unavailable on node.",
          "node": {
            "name": "node1",
      "encryption_context": "aws:fsx:fs-id=fs-0785c8beceb895999",
      "host": "aws-host.host.com",
      "key_id": "kmip-aws",
      "polling_period": 55,
      "port": 443,
      "proxy_host": "proxy.eng.com",
      "proxy_port": 1234,
      "proxy_type": "http",
      "proxy_username": "proxyuser",
      "region": "us-east-1",
      "scope": "string",
      "service": "dynamodb.*.amazonaws.com",
      "skip_verify": "",
      "state": {
        "code": "346758",
        "message": "AWS KMS key protection is unavailable on the following nodes: node1, node2."
      "svm": {
        "name": "svm1",
      "timeout": 20,
      "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
      "verify": "",
      "verify_host": 1,
      "verify_ip": ""
Status: Default
ONTAP Error Response Codes
Error Code Description
65537551
Top-level internal key protection key (KEK) unavailable on one or more nodes.
65537552
Embedded KMIP server status not available.
65537915
The Amazon Web Service Key Management Service is unreachable from one or more nodes.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
amazon_reachability
Indicates whether or not the Amazon KMS is reachable from all nodes in the cluster. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
code
string
Code corresponding to the error message. Returns a 0 if Amazon KMS is reachable from all nodes in the cluster.
message
string
Error message returned when 'reachable' is false.
reachable
boolean
Set to true if the Amazon KMS is reachable from all nodes of the cluster.
node
_links
_links
name
string
uuid
string
ekmip_reachability
Provides the connectivity status for the given SVM on the given node to all EKMIP servers configured on all nodes of the cluster. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
code
string
Code corresponding to the error message. Returns a 0 if a given SVM is able to communicate to the EKMIP servers of all of the nodes in the cluster.
message
string
Error message set when cluster-wide EKMIP server availability from the given SVM and node is false.
node
node
reachable
boolean
Set to true if the given SVM on the given node is able to communicate to all EKMIP servers configured on all nodes in the cluster.
state
Indicates whether or not the Amazon Web Services Key Management Service (AWS KMS) key protection is available cluster-wide.
cluster_state
boolean
Set to true when AWS KMS key protection is available on all nodes of the cluster.
code
string
Code corresponding to the message. Returns a 0 if AWS KMS key protection is available on all nodes of the cluster.
message
string
Error message set when cluster_state is false.
svm
_links
_links
name
string
uuid
string
aws_kms
_links
_links
access_key_id
string
AWS Access Key ID of the user that has appropriate access to AWS KMS.
amazon_reachability
amazon_reachability
default_domain
string
AWS KMS default domain.
ekmip_reachability
array[ekmip_reachability]
encryption_context
string
Additional layer of authentication and logging.
host
string
AWS KMS host's hostname.
key_id
string
AWS Key ID.
polling_period
integer
Polling period in minutes.
port
integer
AWS KMS port.
proxy_host
string
Proxy host.
proxy_port
integer
Proxy port.
proxy_type
string
Proxy type.
proxy_username
string
Proxy username.
region
string
AWS region of the AWS KMS.
scope
string
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster".
service
string
AWS service type.
skip_verify
boolean
Set to true to bypass verification of the user provided access_key_id and secret_access_key. An error will be returned if 'skip_verify' is provided but 'access_key_id' is not.
state
state
svm
svm
timeout
integer
AWS Connection timeout, in seconds.
uuid
string
A unique identifier for the AWS KMS.
verify
boolean
Set to true to verify the AWS KMS host.
verify_host
boolean
Set to true to verify the AWS KMS host's hostname.
verify_ip
boolean
Set to true to verify the AWS KMS host's IP address.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
