Retrieve an IPsec or IKE security association for the ONTAP cluster network
GET /security/cluster-network/ipsec/associations/{uuid}
Introduced In: 9.19
Retrieves a specific IPsec or IKE (Internet Key Exchange) security association for cluster network.
Related ONTAP commands
security cluster-network ipsec show-ipsecsa -
security cluster-network ipsec show-ikesa
uuid |
string |
path |
True |
UUID of IPsec or IKE security association. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
cipher_suite |
string |
Cipher suite for the security association. |
ike |
Objects containing parameters specific to IKE (Internet Key Exchange) security association for cluster network. |
ipsec |
Objects containing parameters specific to IPsec security association for cluster network. |
lifetime |
integer |
Lifetime for the security association in seconds. |
local_address |
string |
Local address of the security association. |
node |
Node with the security association. |
policy_name |
string |
Policy name for the security association. |
remote_address |
string |
Remote address of the security association. |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
type |
string |
Type of security association, it can be IPsec or IKE (Internet Key Exchange). |
uuid |
string |
Unique identifier of the security association. |
"cipher_suite": "string",
"ike": {
"authentication": "string",
"initiator_security_parameter_index": "string",
"responder_security_parameter_index": "string",
"state": "string"
"ipsec": {
"action": "string",
"inbound": {
"security_parameter_index": "string"
"outbound": {
"state": "string"
"local_address": "string",
"node": {
"href": "/api/resourcelink"
"name": "node1",
"policy_name": "string",
"remote_address": "string",
"scope": "string",
"type": "string",
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
ike
authentication |
string |
Authentication method for internet key exchange protocol. |
initiator_security_parameter_index |
string |
Initiator's security parameter index for the IKE security association. |
is_initiator |
boolean |
Indicates whether or not IKE has been initiated by this node. |
responder_security_parameter_index |
string |
Responder's security parameter index for the IKE security association. |
state |
string |
State of the IKE connection. |
version |
integer |
Internet key exchange protocol version. |
inbound
Status for inbound parameters for the IPsec security association.
bytes |
integer |
Number of inbound bytes for the IPsec security association. |
offload_bytes |
integer |
Number of inbound bytes processed by offload for the IPsec security association. |
offload_packets |
integer |
Number of inbound packets processed by offload for the IPsec security association. |
packets |
integer |
Number of inbound packets for the IPsec security association. |
string |
Inbound security parameter index for the IPSec security association. |
outbound
Status for outbound parameters for the IPsec security association.
bytes |
integer |
Number of outbound bytes for the IPsec security association. |
offload_bytes |
integer |
Number of outbound bytes processed by offload for the IPsec security association. |
offload_packets |
integer |
Number of outbound packets processed by offload for the IPsec security association. |
packets |
integer |
Number of outbound packets for the IPsec security association. |
string |
Outbound security parameter index for the IPSec security association. |
ipsec
action |
string |
Action for the IPsec security association. |
inbound |
Status for inbound parameters for the IPsec security association. |
outbound |
Status for outbound parameters for the IPsec security association. |
state |
string |
State of the IPsec security association. |
href |
string |
_links
self |
node
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
