REST API reference
Retrieve the IPsec and IKE security associations for the ONTAP cluster network
Retrieves the IPsec and IKE security associations for your ONTAP cluster network to monitor and manage secure communications.
HTTP method and endpoint
GET /security/cluster-network/ipsec/associations
Introduced in
ONTAP 9.19
Usage notes
Retrieves the IPsec and IKE (Internet Key Exchange) security associations for cluster network.
  • security cluster-network ipsec show-ipsecsa
  • security cluster-network ipsec show-ikesa
type
string
query
False
Filter by type
policy_name
string
query
False
Filter by policy_name
ipsec.outbound.security_parameter_index
string
query
False
Filter by ipsec.outbound.security_parameter_index
ipsec.outbound.bytes
integer
query
False
Filter by ipsec.outbound.bytes
ipsec.outbound.offload_packets
integer
query
False
Filter by ipsec.outbound.offload_packets
ipsec.outbound.packets
integer
query
False
Filter by ipsec.outbound.packets
ipsec.outbound.offload_bytes
integer
query
False
Filter by ipsec.outbound.offload_bytes
ipsec.action
string
query
False
Filter by ipsec.action
ipsec.state
string
query
False
Filter by ipsec.state
ipsec.inbound.bytes
integer
query
False
Filter by ipsec.inbound.bytes
ipsec.inbound.security_parameter_index
string
query
False
Filter by ipsec.inbound.security_parameter_index
ipsec.inbound.offload_packets
integer
query
False
Filter by ipsec.inbound.offload_packets
ipsec.inbound.packets
integer
query
False
Filter by ipsec.inbound.packets
ipsec.inbound.offload_bytes
integer
query
False
Filter by ipsec.inbound.offload_bytes
cipher_suite
string
query
False
Filter by cipher_suite
scope
string
query
False
Filter by scope
remote_address
string
query
False
Filter by remote_address
local_address
string
query
False
Filter by local_address
ike.authentication
string
query
False
Filter by ike.authentication
ike.version
integer
query
False
Filter by ike.version
ike.state
string
query
False
Filter by ike.state
ike.responder_security_parameter_index
string
query
False
Filter by ike.responder_security_parameter_index
ike.initiator_security_parameter_index
string
query
False
Filter by ike.initiator_security_parameter_index
ike.is_initiator
boolean
query
False
Filter by ike.is_initiator
uuid
string
query
False
Filter by uuid
lifetime
integer
query
False
Filter by lifetime
node.name
string
query
False
Filter by node.name
node.uuid
string
query
False
Filter by node.uuid
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
error
error
num_records
integer
Number of records
records
array[records]
    "next": {
      "href": "/api/resourcelink"
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "message": "entry doesn't exist"
  "num_records": 1,
  "records": [
      "cipher_suite": "string",
      "ike": {
        "authentication": "string",
        "initiator_security_parameter_index": "string",
        "responder_security_parameter_index": "string",
        "state": "string"
      "ipsec": {
        "action": "string",
        "inbound": {
          "security_parameter_index": "string"
        "outbound": {
        "state": "string"
      "local_address": "string",
      "node": {
        "name": "node1",
      "policy_name": "string",
      "remote_address": "string",
      "scope": "string",
      "type": "string",
      "uuid": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
ike
Objects containing parameters specific to IKE (Internet Key Exchange) security association for cluster network.
authentication
string
Authentication method for internet key exchange protocol.
string
Initiator's security parameter index for the IKE security association.
is_initiator
boolean
Indicates whether or not IKE has been initiated by this node.
string
Responder's security parameter index for the IKE security association.
state
string
State of the IKE connection.
version
integer
Internet key exchange protocol version.
inbound
Status for inbound parameters for the IPsec security association.
bytes
integer
Number of inbound bytes for the IPsec security association.
offload_bytes
integer
Number of inbound bytes processed by offload for the IPsec security association.
offload_packets
integer
Number of inbound packets processed by offload for the IPsec security association.
packets
integer
Number of inbound packets for the IPsec security association.
string
Inbound security parameter index for the IPSec security association.
outbound
Status for outbound parameters for the IPsec security association.
bytes
integer
Number of outbound bytes for the IPsec security association.
offload_bytes
integer
Number of outbound bytes processed by offload for the IPsec security association.
offload_packets
integer
Number of outbound packets processed by offload for the IPsec security association.
packets
integer
Number of outbound packets for the IPsec security association.
string
Outbound security parameter index for the IPSec security association.
ipsec
Objects containing parameters specific to IPsec security association for cluster network.
action
string
Action for the IPsec security association.
inbound
inbound
outbound
outbound
state
string
State of the IPsec security association.
self
node
Node with the security association.
_links
_links
name
string
uuid
string
records
Security association object for IPsec security association and IKE (Internet Key Exchange) security association for cluster network.
cipher_suite
string
Cipher suite for the security association.
ike
ike
ipsec
ipsec
lifetime
integer
Lifetime for the security association in seconds.
local_address
string
Local address of the security association.
node
node
policy_name
string
Policy name for the security association.
remote_address
string
Remote address of the security association.
scope
string
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster".
type
string
Type of security association, it can be IPsec or IKE (Internet Key Exchange).
uuid
string
Unique identifier of the security association.
returned_error
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
