Retrieve the IPsec policy configuration for an ONTAP node and policy UUID
Retrieves the IPsec policy configuration for network security on a specified ONTAP node and policy UUID. Use this information to review the current security settings for cluster communications.
HTTP method and endpoint
GET /security/cluster-network/ipsec/policies/{node.uuid}/{uuid}
Introduced in
ONTAP 9.19
Usage notes
Retrieves the IPsec policy configuration for cluster network security for a given node and policy UUID.
Related ONTAP commands
'security cluster-network ipsec policy show'
node.uuid |
string |
path |
True |
Node UUID. |
uuid |
string |
path |
True |
IPsec policy UUID.
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
action |
string |
Action for the IPsec policy. |
authentication_method |
string |
Authentication method for the IPsec policy. Must be PKI for cluster security. |
certificate |
Certificate for the IPsec policy. |
local_ip |
Local IP endpoint for the IPsec policy. |
name |
string |
IPsec policy name. |
node |
remote_ip |
Remote IP endpoint for the IPsec policy. |
uuid |
string |
Unique identifier for the IPsec policy. |
"href": "/api/resourcelink"
"action": "string",
"authentication_method": "string",
"certificate": {
"name": "string",
"local_ip": {
"address": "192.168.1.1",
"netmask": 24
"name": "policy1",
"node": {
"name": "node1",
"remote_ip": {
"address": "192.168.1.2",
"netmask": 24
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
certificate
_links |
name |
string |
Certificate name |
uuid |
string |
Certificate UUID |
local_ip
address |
string |
IPv4 or IPv6 address. |
netmask |
integer |
IPv4 mask length or IPv6 prefix length. |
node_reference
_links |
name |
string |
uuid |
string |
remote_ip
address |
string |
netmask |
integer |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
