Retrieve the IPsec policy configurations used for ONTAP cluster network security
Accesses the IPsec policy configurations to understand how they secure the ONTAP cluster network. This helps you ensure the network's security settings are correctly configured and maintained.
HTTP method and endpoint
GET /security/cluster-network/ipsec/policies
Introduced in
ONTAP 9.19
Usage notes
Retrieves the IPsec policy configurations used for cluster network security.
Related ONTAP commands
'security cluster-network ipsec policy show'
action |
string |
query |
False |
Filter by action |
uuid |
string |
query |
False |
Filter by uuid |
certificate.uuid |
string |
query |
False |
Filter by certificate.uuid |
certificate.name |
string |
query |
False |
Filter by certificate.name |
node.name |
string |
query |
False |
Filter by node.name |
node.uuid |
string |
query |
False |
Filter by node.uuid |
local_ip.netmask |
integer |
query |
False |
Filter by local_ip.netmask |
local_ip.address |
string |
query |
False |
Filter by local_ip.address |
authentication_method |
string |
query |
False |
Filter by authentication_method |
name |
string |
query |
False |
Filter by name
remote_ip.address |
string |
query |
False |
Filter by remote_ip.address |
remote_ip.netmask |
integer |
query |
False |
Filter by remote_ip.netmask |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records. |
records |
array[records] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"action": "string",
"authentication_method": "string",
"certificate": {
"name": "string",
"local_ip": {
"address": "192.168.1.1",
"netmask": 24
"name": "policy1",
"node": {
"name": "node1",
"remote_ip": {
"address": "192.168.1.2",
"netmask": 24
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
certificate
Certificate for the IPsec policy.
_links |
name |
string |
Certificate name |
uuid |
string |
Certificate UUID |
local_ip
Local IP endpoint for the IPsec policy.
address |
string |
IPv4 or IPv6 address. |
netmask |
integer |
IPv4 mask length or IPv6 prefix length. |
node_reference
_links |
name |
string |
uuid |
string |
remote_ip
Remote IP endpoint for the IPsec policy.
address |
string |
netmask |
integer |
records
Cluster network security IPsec policy configuration (read-only).
_links |
action |
string |
Action for the IPsec policy. |
string |
Authentication method for the IPsec policy. Must be PKI for cluster security. |
certificate |
Certificate for the IPsec policy. |
local_ip |
Local IP endpoint for the IPsec policy. |
name |
string |
IPsec policy name. |
node |
remote_ip |
Remote IP endpoint for the IPsec policy. |
uuid |
string |
Unique identifier for the IPsec policy. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
