REST API reference
Retrieve key managers
Retrieves key managers to obtain information about their configuration and status. Use this endpoint when you need details on key management settings or to monitor their operational state.
HTTP method and endpoint
GET /security/key-managers
Introduced in
ONTAP 9.6
Expensive properties
There is an added computational cost to retrieving these properties. They are excluded from default GET results and must be explicitly requested using the fields query parameter. For more details, see Requesting specific fields. Additionally, these fields are unavailable for inactive configurations as they are only relevant to active configurations.
  • status.message
  • status.code
  • To retrieve basic information about a key manager:
  • To retrieve specific fields, including expensive properties:
GET /security/key-managers/?fields=status.code,status.message
  • security key-manager show-key-store
  • security key-manager external show
  • security key-manager external show-status
  • security key-manager onboard show-backup
onboard.key_backup
string
query
False
Filter by onboard.key_backup
  • Introduced in: 9.7
onboard.enabled
boolean
query
False
Filter by onboard.enabled
external.servers.username
string
query
False
Filter by external.servers.username
external.servers.server
string
query
False
Filter by external.servers.server
external.servers.connectivity.cluster_availability
boolean
query
False
Filter by external.servers.connectivity.cluster_availability
external.servers.connectivity.node_states.state
string
query
False
Filter by external.servers.connectivity.node_states.state
  • Introduced in: 9.13
external.servers.connectivity.node_states.node.name
string
query
False
Filter by external.servers.connectivity.node_states.node.name
external.servers.connectivity.node_states.node.uuid
string
query
False
Filter by external.servers.connectivity.node_states.node.uuid
external.servers.secondary_key_servers
string
query
False
Filter by external.servers.secondary_key_servers
  • Introduced in: 9.8
external.servers.timeout
integer
query
False
Filter by external.servers.timeout
  • Max value: 60
  • Min value: 1
external.server_ca_certificates.uuid
string
query
False
Filter by external.server_ca_certificates.uuid
external.server_ca_certificates.name
string
query
False
Filter by external.server_ca_certificates.name
external.client_certificate.uuid
string
query
False
Filter by external.client_certificate.uuid
external.client_certificate.name
string
query
False
Filter by external.client_certificate.name
volume_encryption.message
string
query
False
Filter by volume_encryption.message
volume_encryption.supported
boolean
query
False
Filter by volume_encryption.supported
volume_encryption.code
integer
query
False
Filter by volume_encryption.code
uuid
string
query
False
Filter by uuid
configuration.uuid
string
query
False
Filter by configuration.uuid
  • Introduced in: 9.16
configuration.name
string
query
False
Filter by configuration.name
policy
string
query
False
Filter by policy
  • Introduced in: 9.9
scope
string
query
False
Filter by scope
enabled
boolean
query
False
Filter by enabled
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
status.message
string
query
False
Filter by status.message
status.code
integer
query
False
Filter by status.code
is_default_data_at_rest_encryption_disabled
boolean
query
False
Filter by is_default_data_at_rest_encryption_disabled
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Max value: 120
  • Min value: 0
  • Default value: 15
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[security_key_manager]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "configuration": {
        "name": "default",
        "uuid": "1cd8a442-86d1-11e0-ae1c-123478563434"
      "external": {
        "client_certificate": {
          "name": "string",
        "server_ca_certificates": [
            "name": "string",
        "servers": [
            "connectivity": {
              "node_states": [
                  "node": {
                    "name": "node1",
                  "state": "not_responding"
            "secondary_key_servers": "secondary1.com, 10.2.3.4",
            "server": "keyserver1.com:5698",
            "timeout": 60,
            "username": "admin"
      "onboard": {
        "existing_passphrase": "The cluster password of length 32-256 ASCII characters.",
        "key_backup": "'--------------------------BEGIN BACKUP-------------------------- TmV0QXBwIEtleSBCbG9iAAEAAAAEAAAAcAEAAAAAAAAxBFWWAAAAACEAAAAAAAAA QAAAAAAAAABzDyyVAAAAALI5Jsjvy6gUxnT78KoDKXHYb6sSeraM00quOULY6BeV n6dMFxuErCD1lbERaOQZSuaYy1p8oQHtTEfGMLZM4TYiAAAAAAAAACgAAAAAAAAA 3WTh7gAAAAAAAAAAAAAAAAIAAAAAAAgAZJEIWvdeHr5RCAvHGclo+wAAAAAAAAAA IgAAAAAAAAAoAAAAAAAAAEOTcR0AAAAAAAAAAAAAAAACAAAAAAAJAGr3tJA/LRzU QRHwv+1aWvAAAAAAAAAAACQAAAAAAAAAgAAAAAAAAADV1Vd/AAAAAMFM9Q229Bhp mDaTSdqku5DCd8wG+fOZSr4bx4JT5WHvV/r5gJnXDQQAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABOZXRBcHAgS2V5IEJsb2IA AQAAAAMAAAAYAQAAAAAAALgePkcAAAAAIgAAAAAAAAAoAAAAAAAAAEOTcR0AAAAA AAAAAAAAAAACAAAAAAAJAGr3tJA/LRzUQRHwv+1aWvAAAAAAAAAAACIAAAAAAAAA KAAAAAAAAACIlCHZAAAAAAAAAAAAAAAAAgAAAAAAAQCafcabsxRXMM7gxhLRrzxh AAAAAAAAAAAkAAAAAAAAAIAAAAAAAAAA2JjQBQAAAACt4IqXcNpVggahl0axLsN4 yQjnNVKWY7mANB29O42hI7b70DTGCTaVAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAE5ldEFwcCBLZXkgQmxvYgABAAAAAwAAABgBAAAAAAAA 7sbaoQAAAAAiAAAAAAAAACgAAAAAAAAAQ5NxHQAAAAAAAAAAAAAAAAIAAAAAAAkA ave0kD8tHNRBEfC/7Vpa8AAAAAAAAAAAIgAAAAAAAAAoAAAAAAAAALOHfWkAAAAA AAAAAAAAAAACAAAAAAABAMoI9UxrHOGthQm/CB+EHdAAAAAAAAAAACQAAAAAAAAA gAAAAAAAAACnMmUtAAAAAGVk8AtPzENFgsGdsFvnmucmYrlQCsFew0HDSFKaZqK6 W8IEVzBAhPoAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA ---------------------------END BACKUP---------------------------'",
        "synchronize": true
      "policy": "string",
      "scope": "string",
      "status": {
        "code": 346758,
        "message": "This cluster is part of a MetroCluster configuration. Use the REST API POST method security/key_managers/ with the synchronize option and the same passphrase on the partner cluster before proceeding with any key manager operations.  Failure to do so could lead to switchover or switchback failure."
      "svm": {
        "name": "svm1",
      "uuid": "string",
      "volume_encryption": {
        "code": 346758,
        "message": "No platform support for volume encryption in following nodes - node1, node2."
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
configuration
Security keystore object reference.
_links
_links
name
string
Name of the configuration.
uuid
string
Keystore UUID.
client_certificate
Client certificate (name and UUID)
_links
_links
name
string
Certificate name
uuid
string
Certificate UUID
Security certificate object reference
_links
_links
name
string
Certificate name
uuid
string
Certificate UUID
self
node
_links
_links
name
string
uuid
string
key_server_state
The connectivity state of the key server for a specific node.
node
node
state
string
Key server connectivity state
connectivity
This property contains the key server connectivity state of all nodes in the cluster. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
boolean
Set to true when key server connectivity state is available on all nodes of the cluster.
node_states
array[key_server_state]
An array of key server connectivity states for each node.
key_server_readcreate
_links
self_link
connectivity
connectivity
string
A comma delimited string of the secondary key servers associated with the primary key server.
server
string
External key server for key management. If no port is provided, a default port of 5696 is used.
timeout
integer
I/O timeout in seconds for communicating with the key server.
username
string
Username credentials for connecting with the key server.
external
Configures external key management
client_certificate
client_certificate
array[server_ca_certificates]
The array of certificates that are common for all the keyservers per SVM.
servers
array[key_server_readcreate]
The set of external key servers.
onboard
Configures onboard key management. After configuring onboard key management, save the encrypted configuration data in a safe location so that you can use it if you need to perform a manual recovery operation.
enabled
boolean
Is the onboard key manager enabled?
existing_passphrase
string
The cluster-wide passphrase. This is not audited.
key_backup
string
Backup of the onboard key manager's key hierarchy. It is required to save this backup after configuring the onboard key manager to help in the recovery of the cluster in case of catastrophic failures.
status
Optional status information on the current state of the key manager indicating if it is fully setup or requires more action.
code
integer
Code corresponding to the status message. Returns 0 if the setup is complete. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
message
string
Current state of the key manager indicating any additional steps to perform to finish the setup. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
svm
_links
_links
name
string
uuid
string
volume_encryption
Indicates whether volume encryption is supported in the cluster.
code
integer
Code corresponding to the status message. Returns a 0 if volume encryption is supported in all nodes of the cluster.
message
string
Reason for not supporting volume encryption.
supported
boolean
Set to true when volume encryption support is available on all nodes of the cluster.
_links
_links
configuration
configuration
enabled
boolean
Indicates whether the configuration is enabled.
external
external
boolean
Indicates whether default data-at-rest encryption is disabled in the cluster. This field is deprecated in ONTAP 9.8 and later. Use the "software_data_encryption.disabled_by_default" of /api/security endpoint.
  • Default value:
  • x-ntap-readModify: true
  • x-nullable: true
onboard
onboard
policy
string
Security policy associated with the key manager. This value is currently ignored if specified for the onboard key manager.
scope
string
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster".
status
status
svm
svm
uuid
string
volume_encryption
volume_encryption
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
