REST API reference
Retrieve keystore configuration details with the specified UUID
Retrieves the details of a specific keystore configuration using its UUID. This is useful when you need to view the configuration settings of a particular keystore in your system.
HTTP method and endpoint
GET /security/key-stores/{uuid}
Introduced in
ONTAP 9.14
Usage notes
Retrieves details of the keystore configuration with the specified UUID.
  • security key-manager keystore show
uuid
string
path
True
Keystore configuration UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
configuration
configuration
Security keystore object reference.
enabled
boolean
Indicates whether the configuration is enabled.
is_svm_kek
boolean
Indicates whether the keystore is SVM-KEK based.
location
string
Indicates whether the keystore is onboard or external. * 'onboard' - Onboard Key Database * 'external' - External Key Database, including KMIP and Cloud Key Management Systems
scope
string
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster".
state
string
State of the keystore: * 'active' - The key manager is active and serving new and existing keys. * 'mixed' - The key manager has a mixed configuration. New keys can't be created. * 'svm_kek_rekey' - An SVM key encryption key (KEK) rekey is in progress. New keys can't be created. * 'blocked' - The key manager is blocked and cannot serve new and existing keys. * 'switching' - Switching the enabled key manager keystore configuration. Some operations are blocked. * 'initializing' - The key manager is being initialized. All operations are blocked. * 'disabling' - The key manager is being disabled. All operations are blocked.
svm
svm
type
string
Type of keystore that is configured: * 'okm' - Onboard Key Manager * 'kmip' - External Key Manager * 'akv' - Azure Key Vault Key Management Service * 'gcp' - Google Cloud Platform Key Management Service * 'aws' - Amazon Web Service Key Management Service * 'ikp' - IBM Key Protect Key Management Service * 'barbican' - Barbican Key Management Service
uuid
string
  "configuration": {
        "href": "/api/resourcelink"
    "name": "default",
    "uuid": "1cd8a442-86d1-11e0-ae1c-123478563434"
  "location": "string",
  "scope": "string",
  "state": "string",
  "svm": {
    "name": "svm1",
  "type": "string",
  "uuid": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
65539523
Internal error. The keymanager_config table is missing.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
configuration
_links
_links
name
string
Name of the configuration.
uuid
string
Keystore UUID.
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
