REST API reference
Retrieve the TOTP profile for a user account
Retrieves the TOTP profile configured for a user account, which helps in managing two-factor authentication settings.
HTTP method and endpoint
GET /security/login/totps/{owner.uuid}/{account.name}
Introduced in
ONTAP 9.13
  • security login totp show
owner.uuid
string
path
True
Account owner UUID.
account.name
string
path
True
Account user name.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
account
account_reference
comment
string
Optional comment for the TOTP profile.
enabled
boolean
Status of the TOTP profile.
owner
owner
Owner name and UUID that uniquely identifies the TOTP profile.
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
sha_fingerprint
string
SHA fingerprint for the TOTP secret key.
      "href": "/api/resourcelink"
  "account": {
    "name": "joe.smith"
  "comment": "string",
  "enabled": "",
  "owner": {
    "name": "svm1",
  "scope": "string",
  "sha_fingerprint": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
account_reference
_links
_links
name
string
User account
owner
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
