Retrieve username, role, and permissions information for the logged-in ONTAP user
Retrieves the username, role, and permissions information for the currently logged-in ONTAP user to understand your access level and capabilities.
HTTP method and endpoint
GET /security/login/whoami
Introduced in
ONTAP 9.19
Usage notes
Retrieves the username, role, and permissions information for the logged-in user.
Related ONTAP commands
security login whoami
Status: 200, Ok
| Name | Type | Description |
_links |
privileges |
array[whoami_privileges] |
List of privileges |
roles |
array[string] |
Role name or names |
username |
string |
User name |
"href": "/api/resourcelink"
"privileges": [
"access": "all",
"path": "security login",
"query": "-username 'tom'"
"roles": [
"string"
"username": "tom"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
whoami_privileges
access |
string |
Access level for the REST endpoint or command/command directory path. If it denotes the access level for a command/command directory path, the only supported enum values are 'none','readonly' and 'all'. |
path |
string |
Either of REST URI/endpoint OR command/command directory path. |
query |
string |
Query |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
