REST API reference
Retrieve a storage pool specified by the UUID
Accesses a specific storage pool by its UUID to view its configuration details.
HTTP method and endpoint
GET /storage/pools/{uuid}
Introduced in
ONTAP 9.11
Usage notes
Retrieves the storage pool specified by the UUID.
  • storage pool show -storage-pool-uuid
uuid
string
path
True
Storage pool UUID.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
capacity
capacity
health
health
Properties that outline shared storage pool health.
name
string
Storage pool name.
nodes
array[node_reference]
Nodes that can use this storage pool for their aggregates.
storage_type
string
Storage type for the disks used to create the storage pool.
uuid
string
Storage pool UUID.
      "href": "/api/resourcelink"
  "capacity": {
    "disks": [
        "disk": {
          "name": "1.0.1"
        "total_size": 0,
        "usable_size": 0
    "remaining": 0,
    "spare_allocation_units": [
        "available_size": 0,
        "node": {
          "name": "node1",
        "size": 0,
        "syncmirror_pool": "string"
    "total": 0,
    "used_allocation_units": [
        "aggregate": {
          "name": "aggr1",
        "current_usage": 0,
        "node": {
          "name": "node1",
  "health": {
    "state": "string",
    "unhealthy_reason": {
      "arguments": [
          "code": "string",
          "message": "string"
      "code": "4",
      "message": "entry doesn't exist"
  "name": "string",
  "nodes": [
      "name": "node1",
  "storage_type": "string",
  "uuid": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
11206662
There is no storage pool matching the specified UUID or name.
11215856
The specified storage pool is not healthy.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
disk
Reference to the constituent disk object.
_links
_links
name
string
storage_pool_disk
disk
disk
total_size
integer
Raw capacity of the disk, in bytes.
usable_size
integer
Usable capacity of this disk, in bytes.
node
Specifies what node can use this set of allocation units.
_links
_links
name
string
uuid
string
storage_pool_spare_allocation_unit
available_size
integer
The usable capacity of this set of allocation units.
count
integer
The number of spare allocation units on this node.
node
node
size
integer
Size of each allocation unit.
syncmirror_pool
string
The RAID SyncMirror Pool to which this allocation unit is assigned.
aggregate
The aggregate that is using this cache capacity.
_links
_links
name
string
uuid
string
node
The node hosting the aggregate using this set of allocation units.
_links
_links
name
string
uuid
string
storage_pool_used_allocation_unit
aggregate
aggregate
count
integer
The number of allocation units used by this aggregate.
current_usage
integer
The amount of cache space used by this aggregate.
node
node
capacity
disk_count
integer
The number of disks in the storage pool.
disks
array[storage_pool_disk]
Properties of each disk used in the shared storage pool.
remaining
integer
Remaining usable capacity in the flash pool, in bytes.
array[storage_pool_spare_allocation_unit]
Properties of spare allocation units.
total
integer
Total size of the flash pool, in bytes.
array[storage_pool_used_allocation_unit]
Information about the storage pool allocation units participating in the cache tier of an aggregate.
code
string
Argument code
message
string
Message argument
error
Indicates why the storage pool is unhealthy. This property is not returned for healthy storage pools.
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
health
is_healthy
boolean
Indicates whether the storage pool is able to participate in provisioning operations.
state
string
The state of the shared storage pool.
unhealthy_reason
error
node_reference
_links
_links
name
string
uuid
string
returned_error
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
