Retrieve litigations under an SVM
GET /storage/snaplock/litigations
Introduced In: 9.7
Retrieves the list of litigations under an SVM.
Related ONTAP commands
snaplock legal-hold show
Learn more
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of Records |
records |
array[snaplock_litigation_get] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"id": "string",
"name": "lit1",
"operations": [
"id": 16842759
"svm": {
"name": "svm1",
"volume": {
"name": "volume1",
Status: Default
ONTAP Error Response codes
| Error code | Description |
13763280 |
Only a user with security login role "vsadmin-snaplock" is allowed to perform this operation. |
14090346 |
Internal Error. Wait a few minutes, then try the command again |
14090343 |
Invalid field |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
operations
id |
integer |
Operation ID. |
svm
_links |
name |
string |
uuid |
string |
volume
_links |
name |
string |
The name of the volume. This field cannot be specified in a PATCH method. |
uuid |
string |
_links |
id |
string |
Specifies the litigation ID. |
name |
string |
Specifies the legal-hold litigation name. |
operations |
array[operations] |
svm |
volume |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
