REST API reference
List directories with the most I/O activity
Retrieves a list of directories that have the highest I/O activity. This helps you identify which directories are most active in terms of input and output operations.
HTTP method and endpoint
GET /svm/svms/{svm.uuid}/top-metrics/directories
Introduced in
ONTAP 9.11
Usage notes
Retrieves a list of directories with the most I/O activity.
svm.uuid
string
path
True
SVM UUID
top_metric
string
query
False
I/O activity type
  • Default value: 1
  • enum: ["iops.read", "iops.write", "throughput.read", "throughput.write"]
max_records_per_svm
integer
query
False
Max records per svm.
total_throughput.read
integer
query
False
Filter by total_throughput.read
  • Introduced in: 9.19
total_throughput.write
integer
query
False
Filter by total_throughput.write
total_throughput.error.lower_bound
integer
query
False
Filter by total_throughput.error.lower_bound
total_throughput.error.upper_bound
integer
query
False
Filter by total_throughput.error.upper_bound
volume.name
string
query
False
Filter by volume.name
volume.uuid
string
query
False
Filter by volume.uuid
path
string
query
False
Filter by path
total_ops.read
integer
query
False
Filter by total_ops.read
total_ops.error.lower_bound
integer
query
False
Filter by total_ops.error.lower_bound
total_ops.error.upper_bound
integer
query
False
Filter by total_ops.error.upper_bound
total_ops.write
integer
query
False
Filter by total_ops.write
junction-path
string
query
False
Filter by junction-path
throughput.write
integer
query
False
Filter by throughput.write
integer
query
False
Filter by throughput.error.lower_bound
integer
query
False
Filter by throughput.error.upper_bound
throughput.read
integer
query
False
Filter by throughput.read
iops.read
integer
query
False
Filter by iops.read
iops.write
integer
query
False
Filter by iops.write
iops.error.lower_bound
integer
query
False
Filter by iops.error.lower_bound
iops.error.upper_bound
integer
query
False
Filter by iops.error.upper_bound
svm.name
string
query
False
Filter by svm.name
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
excluded_volumes
array[top_metrics_svm_directory_excluded_volume]
List of volumes that are not included in the SVM activity tracking REST API.
notice
notice
Optional field that indicates why no records are returned by the SVM activity tracking REST API.
num_records
integer
Number of records.
observation_window
observation_window
The time window over which metrics are aggregated.
partial_response_reason
Indicates that the metric report provides partial data.
records
array[top_metrics_svm_directory]
    "next": {
      "href": "/api/resourcelink"
  "excluded_volumes": [
      "reason": {
        "code": "111411",
        "message": "The volume is offline."
      "volume": {
        "name": "volume1",
  "notice": {
    "code": "111411207",
    "message": "No read/write traffic on svm."
  "num_records": 1,
  "observation_window": {
    "duration": 60,
    "end": "2026-01-11 01:30:00 +0000",
    "start": "2026-01-11 01:29:55 +0000"
  "partial_response_reason": {
    "code": "124518424",
    "message": "The top metrics report contains partial data for read operations because NFSv4 reads using Multi-Processor I/O (MPIO) are not tracked."
  "records": [
        "metadata": {
      "iops": {
        "error": {
          "lower_bound": 34,
          "upper_bound": 54
        "read": 10,
        "write": 5
      "junction-path": "/fv",
      "path": "/vol/fv/dir_abc/dir_123/dir_20",
      "svm": {
        "name": "svm1",
      "throughput": {
        "error": {
          "lower_bound": 34,
          "upper_bound": 54
        "read": 3,
        "write": 20
      "total_ops": {
        "error": {
          "lower_bound": 34,
          "upper_bound": 54
        "read": 1400,
        "write": 400
      "total_throughput": {
        "error": {
          "lower_bound": 34,
          "upper_bound": 54
        "read": 2800,
        "write": 600
      "volume": {
        "name": "volume1",
Status: Default
ONTAP Error Response Codes
Error Code Description
124519405
The activity tracking report for SVM svm.name returned zero records. Check whether the activity tracking enabled volumes belonging to the SVM have read/write traffic. Refer to the REST API documentation for more information on why there might be no records.
124519406
Failed to get the activity tracking report for SVM svm.name. Reason:.
124519407
SVM wildcard queries are not supported for activity tracking reports.
124519408
Activity tracking is not supported on SVM svm.name, because it is configured as a destination for SVM DR.
124519409
Activity tracking is not supported on SVM svm.name, because it is configured as a destination of a MetroCluster SVM relationship and the SVM admin state is stopped.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
reason
code
string
Warning code indicating why the volume is not included in the SVM activity tracking REST API.
message
string
Details why the volume is not included in the SVM activity tracking REST API.
self
volume
_links
_links
name
string
The name of the volume. This field cannot be specified in a PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
List of volumes and their details as to why they are not included in the SVM activity tracking REST API.
reason
reason
volume
volume
notice
code
string
Warning code indicating why no records are returned.
message
string
Details why no records are returned.
observation_window
duration
integer
Duration of the observation window in seconds.
end
string
End timestamp of the observation window in UTC.
start
string
Start timestamp of the observation window in UTC.
code
string
Warning code indicating why partial data was reported.
message
string
A message describing the reason for partial data.
metadata
self
top_metric_value_error_bounds
lower_bound
integer
Lower bound of the nominal value of a metric.
upper_bound
integer
Upper bound of the nominal value of a metric.
iops
error
read
integer
Average number of read operations per second.
write
integer
Average number of write operations per second.
svm
_links
_links
name
string
uuid
string
throughput
error
read
integer
Average number of read bytes received per second.
write
integer
Average number of write bytes received per second.
total_ops
error
read
integer
Total read operations in the observation window.
write
integer
Total write operations in the observation window.
total_throughput
error
read
integer
Total bytes read in the observation window.
write
integer
Total bytes written in the observation window.
Information about a directory's IO activity.
_links
_links
iops
iops
junction-path
string
Junction path of the file.
path
string
Path of the directory.
svm
svm
throughput
throughput
total_ops
total_ops
total_throughput
total_throughput
volume
volume
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
