Retrieve network Ethernet switch ports
Retrieve detailed port information for Ethernet switches used in cluster or storage networks. This API provides port status and configuration details through GET requests, supporting field filters to customize the results.
Overview
This API can be used to get the port information for an ethernet switch used in a cluster or storage networks. This API supports GET only. The GET operation returns a list of ports with status and configuration information.
Retrieving the ports for ethernet switches
The following example retrieves the ethernet switch ports for all the ethernet switches used for cluster and/or storage networks. Note that if the fields=* parameter is not specified, the fields identity.number, statistics, and mac_address are not returned. Filters can be added on the fields to limit the results.
# The API:
GET /network/ethernet/switch/ports
# The call:
curl -X GET "https://<mgmt-ip>/api/network/ethernet/switch/ports?fields=*" -H "accept: application/hal+json" -H "Content-Type: application/hal+json"
# The response: (abbreviated output due to length, shows a port connected to a node, a port with no remote connection and a port connected to shelf)
"records": [
"switch": {
"name": "RTP-CS01-510R11(FOC22092K12)",
"href": "/api/network/ethernet/switches/RTP-CS01-510R11(FOC22092K12)"
"identity": {
"name": "Ethernet1/1",
"index": 436207616,
"number": 1,
"type": "ethernetcsmacd"
"mtu": 9216,
"duplex_type": "full_duplex",
"speed": 100000,
"configured": "up",
"state": "up",
"isl": false,
"vpc_peer_link": false,
"statistics": {
"timestamp": "2024-11-08T19:51:12+00:00",
"receive_raw": {
"packets": 1616467751,
"errors": 0,
"discards": 0
"transmit_raw": {
"packets": 206717534,
"errors": 0,
"discards": 0
"remote_port": {
"mtu": 9000,
"name": "e3a",
"functional_roles": [
"cluster",
"ha"
"device": {
"discovered_name": "stiA400-311",
"node": {
"name": "stiA400-311",
"uuid": "54c0f036-8a3a-11ea-893d-00a098fd726d",
"href": "/api/cluster/nodes/54c0f036-8a3a-11ea-893d-00a098fd726d"
"mac_address": "00:be:75:ae:2a:d4",
"vlan_id": [
1,
17,
18
"roles": [
"type": "cluster",
"zone": 1
"href": "/api/network/ethernet/switch/ports/RTP-CS01-510R11%28FOC22092K12%29/Ethernet1%2F1/436207616"
"switch": {
"identity": {
"name": "Ethernet1/11",
"index": 436212736,
"number": 11,
"mtu": 9216,
"duplex_type": "unknown",
"speed": 100000,
"configured": "up",
"state": "down",
"isl": false,
"statistics": {
"receive_raw": {
"packets": 0,
"errors": 0,
"discards": 0
"transmit_raw": {
"packets": 0,
"errors": 0,
"discards": 0
"mac_address": "00be75ae2afc",
"vlan_id": [
1,
17,
18
"roles": [
"type": "cluster",
"zone": 1
"href": "/api/network/ethernet/switch/ports/RTP-CS01-510R11%28FOC22092K12%29/Ethernet1%2F11/436212736"
"switch": {
"name": "RTP-SS01-510R10(FOC22170DFR)",
"href": "/api/network/ethernet/switches/RTP-SS01-510R10(FOC22170DFR)"
"identity": {
"name": "Ethernet1/10",
"index": 436212224,
"number": 10,
"mtu": 9216,
"speed": 100000,
"configured": "up",
"state": "up",
"isl": false,
"statistics": {
"receive_raw": {
"packets": 332013844,
"errors": 0,
"discards": 0
"transmit_raw": {
"packets": 2429595607,
"errors": 0,
"discards": 0
"remote_port": {
"mtu": 9000,
"name": "e0a",
"storage_shelf"
"device": {
"discovered_name": "1.1",
"shelf": {
"name": "1.1",
"module": "B",
"uid": "12439000444923584512",
"href": "/api/storage/shelves/12439000444923584512"
"mac_address": "00fcbaead548",
"vlan_id": [
1,
30
"roles": [
"type": "storage",
"zone": 1
"href": "/api/network/ethernet/switch/ports/RTP-SS01-510R10%28FOC22170DFR%29/Ethernet1%2F10/436212224"
"num_records": 138,
"href": "/api/network/ethernet/switch/ports?fields=*"
Retrieving a ports on an ethernet switch
# The API:
GET /network/ethernet/switch/ports/{switch.name}/{identity.name}/{identity.index}
# The call:
curl -X GET "https://<mgmt-ip>/api/network/ethernet/switch/ports/RTP-SS02-510R10%28FOC22131U6T%29/Ethernet1%2F9/436211712" -H "accept: application/hal+json" -H "Content-Type: application/hal+json"
# The response:
"switch": {
"name": "RTP-SS02-510R10(FOC22131U6T)",
"href": "/api/network/ethernet/switches/RTP-SS02-510R10(FOC22131U6T)"
"identity": {
"name": "Ethernet1/9",
"index": 436211712,
"number": 9,
"mtu": 9216,
"speed": 100000,
"configured": "up",
"state": "up",
"isl": false,
"statistics": {
"receive_raw": {
"packets": 4012559315,
"errors": 0,
"discards": 0
"transmit_raw": {
"packets": 337898026,
"errors": 0,
"discards": 0
"remote_port": {
"mtu": 9000,
"name": "e0a",
"storage_shelf"
"device": {
# cSpell:disable-next-line
"discovered_name": "SHFFG1234567890:A",
"shelf": {
"name": "1.1",
"module": "A",
"mac_address": "00fcbaea7228",
"vlan_id": [
1,
30
"roles": [
"type": "storage",
"zone": 1
"href": "/api/network/ethernet/switch/ports/RTP-SS02-510R10%28FOC22131U6T%29/Ethernet1%2F9/436211712"
