REST API reference
Update the NDMP node configuration for a node
Updates the NDMP node configuration for a specific node. This helps you manage and customize the node's NDMP settings to suit your data management needs.
HTTP method and endpoint
PATCH /protocols/ndmp/nodes/{node.uuid}
Introduced in
ONTAP 9.7
  • system services ndmp modify
node.uuid
string
path
True
Node UUID
Request Body
Name Type Description
authentication_types
array[string]
NDMP authentication types.
enabled
boolean
Is the NDMP service enabled?
node
node
Storage system node
password
string
NDMP password. This can only be set and cannot be read back.
user
string
NDMP user ID
Example request
  "authentication_types": [
    "plaintext",
    "challenge"
  "enabled": 1,
  "node": {
    "name": "node1",
  "password": "string",
  "user": "ndmp_user"
Status: 200, Ok
array[string]
enabled
boolean
node
node
Storage system node
password
string
user
string
NDMP user ID
    "plaintext",
    "challenge"
  "enabled": 1,
  "node": {
    "name": "node1",
  "user": "ndmp_user"
Status: Default
ONTAP Error Response codes
Error code Description
68812800
The user is required to enable NDMP on a node.
68812801
Node-scoped operations are not allowed in an SVM-scope.
68812802
The UUID is not valid.
string
node
Storage system node
name
string
uuid
string
ndmp_node
array[string]
enabled
boolean
node
node
Storage system node
password
string
user
string
NDMP user ID
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
