REST API reference
Modify an ONTAP LUN map
PATCH /protocols/san/lun-maps/{lun.uuid}/{igroup.uuid}
Introduced In: 9.19
Modifies a LUN map.
  • lun mapping modify
lun.uuid
string
path
True
The unique identifier of the LUN.
igroup.uuid
string
path
True
The unique identifier of the igroup.
Request Body
Name Type Description
igroup
igroup
The initiator group to which the LUN is mapped. Required in POST by supplying either the igroup.uuid, igroup.name, or both.
lun
lun
The LUN to which the initiator group is mapped. Required in POST by supplying either the lun.uuid, lun.name, or both.
replicated
boolean
The replicated property only applies when the initiator group is replicated and the mapped LUN is a member of a SnapMirror Synchronous relationship. When these conditions are met, replicated defaults to true, and maps are replicated. The replicated property can be PATCHed to false to disable this replication for a LUN map. When set to false, the LUN map on the remote cluster is deleted. When set to true, the LUN map on the remote cluster is created. This property is closely related to the local_delete_only query parameter that can be used during DELETE. The properties achieve the same result, with the difference being the cluster where the map is deleted. PATCH the replicated property to false to keep the local map and delete the remote map. DELETE with local_delete_only set to true to delete the local map and keep the remote map.
reporting_nodes
array[reporting_nodes]
The cluster nodes from which network paths to the mapped LUNs are advertised via the SAN protocols as part of the Selective LUN Map (SLM) feature of ONTAP.
When a LUN map is created, the cluster node hosting the LUN and its high availability (HA) partner are set as the default reporting node. In POST, the property additional_reporting_node may be used to add an additional node and its HA partner.
  • readOnly: 1
  • Introduced in: 9.10
Example request
  "igroup": {
    "initiators": [
      "iqn.1998-01.com.corp.iscsi:name1"
    "os_type": "string",
    "protocol": "string"
  "lun": {
    "node": {
      "name": "node1",
      "uuid": "1cf8aa42-8cd1-12e0-a11c-423468563412"
  "reporting_nodes": [
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
5374875
The specified LUN does not exist or is not accessible to the caller.
5374878
The specified initiator group does not exist, is not accessible to the caller, or is not in the same SVM as the specified LUN.
5374922
The specified LUN map does not exist.
string
igroup
initiators
array[string]
The initiators that are members of the initiator group.
os_type
string
The host operating system of the initiator group. All initiators in the group should be hosts of the same operating system.
protocol
string
The protocols supported by the initiator group. This restricts the type of initiators that can be added to the initiator group.
replicated
boolean
This property reports if the initiator group is replicated.
node
The LUN node.
name
string
The name of the LUN's node.
uuid
string
The unique identifier of the LUN node.
smbc
"Properties related to SM-BC replication."
replicated
boolean
This property reports if the LUN is replicated via SM-BC.
lun
node
node
The LUN node.
smbc
smbc
reporting_nodes
A cluster node from which network paths to the LUN are advertised by ONTAP via the SAN protocols.
_links
_links
svm
name
string
uuid
string
lun_map
A LUN map is an association between a LUN and an initiator group. When a LUN is mapped to an initiator group, the initiator group's initiators are granted access to the LUN. The relationship between a LUN and an initiator group is many LUNs to many initiator groups.
igroup
igroup
lun
lun
replicated
boolean
reporting_nodes
  • readOnly: 1
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
