REST API reference
Update the OIDC configuration in the ONTAP cluster
Updates the OIDC configuration in the ONTAP cluster to modify settings as needed for your security requirements.
HTTP method and endpoint
PATCH /security/authentication/cluster/oidc
Introduced in
ONTAP 9.19
Usage notes
Updates the OIDC configuration in the cluster.
Required properties
  • enabled
  • security oidc modify
Request Body
Name Type Description
client_secret_hash
string
The hash of the client secret for the application.
enabled
boolean
Indicates whether the OpenID Connect configuration is enabled.
Example request
  "client_secret_hash": "1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef",
  "enabled": 1,
  "skip_uri_validation": ""
Status: 200, Ok
job
job_link
  "job": {
    "uuid": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
301465616
Failed to enable OIDC feature, web server setup is in progress. Retry after some time.
string
security_oidc
client_secret_hash
string
enabled
boolean
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
