Update a cluster network security certificate configuration
Updates the certificate configuration for cluster network security on a specified node, ensuring secure communication within your network environment.
HTTP method and endpoint
PATCH /security/cluster-network/certificates/{node.uuid}
Introduced in
ONTAP 9.18
Usage notes
Updates the certificate configuration for cluster network security for a given node.
Required properties
certificate.name- The name of the certificate to assign.
Related ONTAP commands
'security cluster-network certificate modify'
node.uuid |
string |
path |
True |
Node UUID. |
Request Body
| Name | Type | Description |
certificate |
Security certificate object reference |
node |
Example request
"certificate": {
"name": "string",
"node": {
"name": "node1",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
70320128 |
Modifying the cluster network security configuration requires an effective cluster version of ONTAP 9.18.1 or later. |
70320132 |
The cluster has an out of quorum node, wait until all nodes are in quorum before modifying the cluster network security configuration. |
70320137 |
The specified certificate was not found on the admin SVM |
70320138 |
The certificate table is currently in use. Removing a certificate entry is not allowed. |
href |
string |
_links
security_certificate_reference
name |
string |
Certificate name |
uuid |
string |
Certificate UUID |
node_reference
name |
string |
uuid |
string |
security_cluster_network_certificates
Manages the cluster network security certificate configuration.
certificate |
node |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
