REST API reference
Update the HA network security configuration
Updates the HA network security configuration to enable or disable protection for NVLog traffic, keeping your data secure during high-availability operations.
HTTP method and endpoint
PATCH /security/ha-network
Introduced in
ONTAP 9.18
Optional properties
  • 'enabled' - Indicates if HA network security for NVLog traffic is enabled.
  • 'security ha-network modify'
enabled
boolean
query
False
Specifies if HA network security is enabled.
Request Body
Name Type Description
enabled
boolean
Indicates if HA network security is enabled.
node.name
node.name
Node name
Example request
  "node.name": {
    "name": "node1",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
70385664
Modifying the HA network security configuration requires an effective HA version of ONTAP 9.18.1 or later.
70385666
Failed to get node information for node "\".
70385667
Failed to enable encryption on node "\".
70385671
Failed to disable encryption on node "\".
70385673
HA network security does not support MetroCluster configurations.
70385677
Failed to modify HA network security because the "enabled" field was not specified.
string
node.name
Node name
name
string
uuid
string
security_ha_network
Manages the HA network security configuration.
enabled
boolean
node.name
node.name
Node name
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
