REST API reference
Update key managers
Updates a key manager to modify key management configurations for onboard or external key managers. Use this endpoint when you need to synchronize key manager keys or adjust certificate validation settings.
HTTP method and endpoint
PATCH /security/key-managers/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Note: When validate_certificates is set, the API returns a 202 status code for successful creation of the job, otherwise an error is returned.
Required properties (when patching the Onboard Key Manager)
  • onboard.existing_passphrase - Cluster-wide passphrase. Required only when synchronizing the passphrase of the Onboard Key Manager.
  • synchronize - Synchronizes missing Onboard Key Manager keys on any node in the cluster. Required only when synchronizing the Onboard Key Manager keys in a local cluster.
Required properties (when patching an external key manager)
  • external.client_certificate or external.server_ca_certificates - Client certificate or Server CA certificate. Required when modifying an external key manager.
Optional parameters (when patching an external key manager):
  • validate_certificates - Validate certificates by testing the connection to the KMIP server using them. This flag is set to "false" by default.
  • security key-manager external modify
  • security key-manager onboard sync
  • security key-manager onboard update-passphrase
uuid
string
path
True
Key manager UUID
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
enabled
boolean
Indicates whether the configuration is enabled.
external
external
Configures external key management
is_default_data_at_rest_encryption_disabled
boolean
Indicates whether default data-at-rest encryption is disabled in the cluster. This field is deprecated in ONTAP 9.8 and later. Use the "software_data_encryption.disabled_by_default" of /api/security endpoint.
  • Default value: 1
  • Introduced in: 9.7
  • x-ntap-readModify: true
  • x-nullable: true
onboard
onboard
Configures onboard key management. After configuring onboard key management, save the encrypted configuration data in a safe location so that you can use it if you need to perform a manual recovery operation.
uuid
string
Example request
  "external": {
    "client_certificate": {
      "name": "string",
    "server_ca_certificates": [
        "name": "string",
  "onboard": {
    "existing_passphrase": "The cluster password of length 32-256 ASCII characters.",
    "key_backup": "'--------------------------BEGIN BACKUP-------------------------- TmV0QXBwIEtleSBCbG9iAAEAAAAEAAAAcAEAAAAAAAAxBFWWAAAAACEAAAAAAAAA QAAAAAAAAABzDyyVAAAAALI5Jsjvy6gUxnT78KoDKXHYb6sSeraM00quOULY6BeV n6dMFxuErCD1lbERaOQZSuaYy1p8oQHtTEfGMLZM4TYiAAAAAAAAACgAAAAAAAAA 3WTh7gAAAAAAAAAAAAAAAAIAAAAAAAgAZJEIWvdeHr5RCAvHGclo+wAAAAAAAAAA IgAAAAAAAAAoAAAAAAAAAEOTcR0AAAAAAAAAAAAAAAACAAAAAAAJAGr3tJA/LRzU QRHwv+1aWvAAAAAAAAAAACQAAAAAAAAAgAAAAAAAAADV1Vd/AAAAAMFM9Q229Bhp mDaTSdqku5DCd8wG+fOZSr4bx4JT5WHvV/r5gJnXDQQAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABOZXRBcHAgS2V5IEJsb2IA AQAAAAMAAAAYAQAAAAAAALgePkcAAAAAIgAAAAAAAAAoAAAAAAAAAEOTcR0AAAAA AAAAAAAAAAACAAAAAAAJAGr3tJA/LRzUQRHwv+1aWvAAAAAAAAAAACIAAAAAAAAA KAAAAAAAAACIlCHZAAAAAAAAAAAAAAAAAgAAAAAAAQCafcabsxRXMM7gxhLRrzxh AAAAAAAAAAAkAAAAAAAAAIAAAAAAAAAA2JjQBQAAAACt4IqXcNpVggahl0axLsN4 yQjnNVKWY7mANB29O42hI7b70DTGCTaVAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAE5ldEFwcCBLZXkgQmxvYgABAAAAAwAAABgBAAAAAAAA 7sbaoQAAAAAiAAAAAAAAACgAAAAAAAAAQ5NxHQAAAAAAAAAAAAAAAAIAAAAAAAkA ave0kD8tHNRBEfC/7Vpa8AAAAAAAAAAAIgAAAAAAAAAoAAAAAAAAALOHfWkAAAAA AAAAAAAAAAACAAAAAAABAMoI9UxrHOGthQm/CB+EHdAAAAAAAAAAACQAAAAAAAAA gAAAAAAAAACnMmUtAAAAAGVk8AtPzENFgsGdsFvnmucmYrlQCsFew0HDSFKaZqK6 W8IEVzBAhPoAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA ---------------------------END BACKUP---------------------------'",
    "passphrase": "The cluster password of length 32-256 ASCII characters."
  "uuid": "string"
Status: 200, Ok
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
65536139
The existing passphrase value provided does not match the configured passphrase.
65536150
The new passphrase is same as old passphrase.
65536404
The passphrase does not match the accepted length.
65536406
The change of passphrase failed.
65536407
The passphrase update failed on some nodes.
65536802
The passphrase does not match the accepted length in common criteria mode.
65536821
The certificate is not installed.
65536828
External key management is not enabled for the SVM.
65536850
New client certificate public or private keys are different from the existing client certificate.
65536852
Failed to query supported KMIP protocol versions.
65536917
Updating an onboard passphrase requires both new and existing cluster passphrase.
65537242
The Onboard Key Manager existing_passphrase must be provided when performing a PATCH/synchronize operation.
65537243
The Onboard Key Manager passphrase must not be provided when performing a PATCH/synchronize operation.
65538120
The key manager policy is not supported on the admin SVM.
65539586
Cannot modify an inactive key manager configuration.
66060338
Failed to establish secure connection for a key management server due to incorrect server_ca certificates.
66060339
Failed to establish secure connection for a key management server due to incorrect client certificates.
66060340
Failed to establish secure connection for a key management server due to Cryptsoft error.
string
configuration
Security keystore object reference.
name
string
Name of the configuration.
uuid
string
Keystore UUID.
client_certificate
Client certificate (name and UUID)
name
string
Certificate name
uuid
string
Certificate UUID
Security certificate object reference
name
string
Certificate name
uuid
string
Certificate UUID
node
name
string
uuid
string
key_server_state
The connectivity state of the key server for a specific node.
node
node
state
string
Key server connectivity state
connectivity
This property contains the key server connectivity state of all nodes in the cluster. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
cluster_availability
boolean
Set to true when key server connectivity state is available on all nodes of the cluster.
node_states
array[key_server_state]
An array of key server connectivity states for each node.
key_server_readcreate
secondary_key_servers
string
A comma delimited string of the secondary key servers associated with the primary key server.
timeout
integer
I/O timeout in seconds for communicating with the key server.
username
string
Username credentials for connecting with the key server.
external
client_certificate
client_certificate
array[server_ca_certificates]
The array of certificates that are common for all the keyservers per SVM.
onboard
enabled
boolean
Is the onboard key manager enabled?
existing_passphrase
string
The cluster-wide passphrase. This is not audited.
key_backup
string
Backup of the onboard key manager's key hierarchy. It is required to save this backup after configuring the onboard key manager to help in the recovery of the cluster in case of catastrophic failures.
passphrase
string
synchronize
boolean
Synchronizes missing onboard keys on any node in the cluster. If a node is added to a cluster that has onboard key management configured, the synchronize operation needs to be performed in a PATCH operation. In a MetroCluster configuration, if onboard key management is enabled on one site, then the synchronize operation needs to be run as a POST operation on the remote site providing the same passphrase.
status
Optional status information on the current state of the key manager indicating if it is fully setup or requires more action.
code
integer
Code corresponding to the status message. Returns 0 if the setup is complete. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
message
string
Current state of the key manager indicating any additional steps to perform to finish the setup. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
svm
name
string
uuid
string
volume_encryption
Indicates whether volume encryption is supported in the cluster.
code
integer
Code corresponding to the status message. Returns a 0 if volume encryption is supported in all nodes of the cluster.
message
string
Reason for not supporting volume encryption.
supported
boolean
Set to true when volume encryption support is available on all nodes of the cluster.
security_key_manager
enabled
boolean
external
external
boolean
  • Default value: 1
  • x-nullable: true
onboard
onboard
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
