Update a WebAuthn global settings for an ONTAP cluster or SVM.
Updates the WebAuthn global settings for a cluster or SVM to modify authentication configurations.
HTTP method and endpoint
PATCH /security/webauthn/global-settings/{owner.uuid}
Introduced in
ONTAP 9.19
Related ONTAP commands
security webauthn modify
owner.uuid |
string |
path |
True |
Cluster or SVM UUID |
Request Body
| Name | Type | Description |
attestation |
string |
Attestation conveyance type. |
owner |
require_rk |
boolean |
Specifies whether the resident key is required. |
resident_key |
string |
Resident key. |
rp_domains |
array[string] |
List of relying party domains |
scope |
string |
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects. |
timeout |
integer |
The timeout interval for the WebAuthn request, in milliseconds. |
user_verification |
string |
User verification. |
Example request
"attestation": "none",
"owner": {
"name": "svm1",
"require_rk": "",
"resident_key": "discouraged",
"rp_domains": [
"example.com"
"scope": "string",
"timeout": 600000,
"user_verification": "discouraged"
Status: 200, Ok
Status: Default, Error
href |
string |
self_link
_links
svm_reference
name |
string |
uuid |
string |
webauthn_global
WebAuthn global settings.
attestation |
string |
owner |
require_rk |
boolean |
resident_key |
string |
Resident key. |
rp_domains |
array[string] |
scope |
string |
timeout |
integer |
user_verification |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
