Create an application container
POST /application/containers
Introduced In: 9.17
Creates one or more of the following:
New NAS FlexVol or FlexGroup volumes (with or without S3 buckets)
Access policies for NFS, CIFS, and S3
FlexCache volumes
Required properties
svm.uuidorsvm.name- Existing SVM in which to create the container. -
volumes
Naming Conventions
Volume
volumes[].name, if specified
suffixed by "_#" where "#" is a system generated unique number, if provisioning_options.count is provided
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
svm |
The SVM in which the container is located. |
volumes |
array[volumes] |
A list of NAS volumes to provision. |
Example request
"svm": {
"name": "svm1",
"volumes": [
"comment": "string",
"encryption": {
"enabled": 1
"exclude_aggregates": [
"name": "aggr1",
"flexcache": {
"origins": [
"svm": {
"name": "svm1",
"volume": {
"name": "volume1",
"guarantee": {
"type": "volume"
"name": "vol_cs_dept",
"nas": {
"cifs": {
"shares": [
"acls": [
"permission": "string",
"type": "string",
"user_or_group": "ENGDOMAIN\\ad_user"
"comment": "HR Department Share",
"dir_umask": 18,
"file_umask": 18,
"name": "HR_SHARE",
"offline_files": "string",
"unix_symlink": "string",
"vscan_profile": "string"
"export_policy": {
"id": 0,
"name": "string",
"rules": [
"anonymous_user": "string",
"chown_mode": "string",
"clients": [
"match": "0.0.0.0/0"
"ntfs_unix_security": "string",
"protocols": [
"string"
"ro_rule": [
"string"
"rw_rule": [
"string"
"superuser": [
"string"
"junction_parent": {
"name": "vs1_root",
"uuid": "75c9cfb0-3eb4-11eb-9fb4-005056bb088a"
"path": "/user/my_volume",
"security_style": "string",
"unix_permissions": 493
"qos": {
"policy": {
"name": "performance",
"s3_bucket": {
"name": "bucket1",
"nas_path": "/",
"policy": {
"statements": [
"actions": [
"GetObject",
"PutObject",
"DeleteObject",
"ListBucket"
"conditions": [
"delimiters": [
"if_match": [
"true"
"max_keys": [
1000
"operator": "ip_address",
"prefixes": [
"pref"
"source_ips": [
"1.1.1.1",
"1.2.2.0/24"
"usernames": [
"user1"
"effect": "allow",
"principals": [
"user1",
"group/grp1",
"nasgroup/group1"
"resources": [
"bucket1",
"bucket1/*"
"sid": "Full_Access_To_User1!"
"smas_protection": "string",
"snaplock": {
"append_mode_enabled": "",
"autocommit_period": "P30M",
"retention": {
"default": "P30Y",
"maximum": "P30Y",
"minimum": "P30Y"
"type": "enterprise"
"snapshot_policy": {
"name": "default",
"space": {
"size": 1073741824
"storage_service": {
"name": "string"
"tiering": {
"control": "string",
"object_stores": [
"name": "string"
"policy": "string"
"type": "string"
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
13109173 |
Failed to access cluster capabilities. |
53412079 |
Effective Cluster Version not supported for the request. |
53412080 |
CIFS shares name already exists. |
53412083 |
This operation is not supported for FlexVol or FlexCache volumes. |
53412085 |
FlexGroup or FlexCache volumes cannot be created because SVM is part of a SnapMirror active sync NAS relationship. |
53412086 |
Failed to determine the SnapMirror active sync NAS relationship for the SVM. |
53412088 |
Specifying this field requires an effective cluster version of 9.19.1 or later. |
href |
string |
_links
svm
name |
string |
uuid |
string |
encryption
enabled |
boolean |
Creates an encrypted or unencrypted volume. For POST requests, when set to 'true', a new key is generated and used to encrypt the specified volume. The underlying SVM must be configured with the key manager. When set to 'false', the volume created will be unencrypted. |
exclude_aggregates
Aggregate
name |
string |
uuid |
string |
svm
name |
string |
uuid |
string |
volume
name |
string |
The name of the volume. This field cannot be specified in a PATCH method. |
uuid |
string |
container_volume_flexcache_relationship
svm |
volume |
writeback
enabled |
boolean |
Indicates whether or not writeback is enabled for the FlexCache volume. Writeback is a storage method where data is first written to the FlexCache volume and then written to the origin of a FlexCache volume. |
flexcache
The FlexCache origin volume.
dr_cache |
boolean |
If set to true, a DR cache is created. |
global_file_locking_enabled |
boolean |
Specifies whether a FlexCache volume has global file locking mode enabled. Global file locking mode is a mode where protocol read locking semantics are enforced across all FlexCaches and origins of a FlexCache volume. When global file locking mode is enabled, cache locks are honored when flexcaches are disconnected from the origin. |
origins |
writeback |
guarantee
type |
string |
The type of space guarantee of this volume. |
acls
The permissions that users and groups have on a CIFS share.
permission |
string |
Specifies the access rights that a user or group has on the defined CIFS Share. The following values are allowed:
type |
string |
Specifies the type of the user or group to add to the access control list of a CIFS share. The following values are allowed:
user_or_group |
string |
Specifies the user or group name to add to the access control list of a CIFS share. |
CIFS share is a named access point in a volume. Before users and applications can access data on the CIFS server over SMB, a CIFS share must be created with sufficient share permission. CIFS shares are tied to the CIFS server on the SVM. When a CIFS share is created, ONTAP creates a default ACL for the share with Full Control permissions for Everyone.
access_based_enumeration |
boolean |
Specifies whether all folders inside this share are visible to a user based on that individual user's access right; prevents the display of folders or other shared resources that the user does not have access to. |
acls |
array[acls] |
allow_unencrypted_access |
boolean |
Specifies whether or not the SMB2 clients are allowed to access the encrypted share. |
change_notify |
boolean |
Specifies whether CIFS clients can request for change notifications for directories on this share. |
comment |
string |
Specify the CIFS share descriptions. |
continuously_available |
boolean |
Specifies whether or not the clients connecting to this share can open files in a persistent manner. Files opened in this way are protected from disruptive events, such as, failover and giveback. If the Vscan ONTAP feature is used, it is not supported in continuous availability (CA) shares.
dir_umask |
integer |
Directory mode creation mask to be viewed as an octal number. |
encryption |
boolean |
Specifies whether SMB encryption must be used when accessing this share. Clients that do not support encryption are not able to access this share. |
file_umask |
integer |
File mode creation mask to be viewed as an octal number. |
home_directory |
boolean |
Specifies whether or not the share is a home directory share, where the share and path names are dynamic. ONTAP home directory functionality automatically offer each user a dynamic share to their home directory without creating an individual SMB share for each user. The ONTAP CIFS home directory feature enable us to configure a share that maps to different directories based on the user that connects to it. Instead of creating a separate shares for each user, a single share with a home directory parameters can be created. In a home directory share, ONTAP dynamically generates the share-name and share-path by substituting %w, %u, and %d variables with the corresponding Windows user name, UNIX user name, and domain name, respectively.
name |
string |
Specifies the name of the CIFS share that you want to create. If this is a home directory share then the share name includes the pattern as %w (Windows user name), %u (UNIX user name) and %d (Windows domain name) variables in any combination with this parameter to generate shares dynamically. |
namespace_caching |
boolean |
Specifies whether or not the SMB clients connecting to this share can cache the directory enumeration results returned by the CIFS servers. |
no_strict_security |
boolean |
Specifies whether or not CIFS clients can follow Unix symlinks outside the share boundaries. |
offline_files |
string |
Offline Files The supported values are:
oplocks |
boolean |
Specifies whether opportunistic locks are enabled on this share. "Oplocks" allow clients to lock files and cache content locally, which can increase performance for file operations. |
show_snapshot |
boolean |
Specifies whether or not the snapshots can be viewed and traversed by clients. |
unix_symlink |
string |
Controls the access of UNIX symbolic links to CIFS clients. The supported values are:
vscan_profile |
string |
Vscan File-Operations Profile The supported values are:
cifs
shares |
array[consistency_group_cifs_share] |
self_link
export_clients
match |
string |
Client Match Hostname, IP Address, Netgroup, or Domain. You can specify the match as a string value in any of the following formats:
export_rules
allow_device_creation |
boolean |
Specifies whether or not device creation is allowed. |
allow_nfs_tls_only |
boolean |
Specifies whether to allow NFS access only over TLS connections. |
allow_suid |
boolean |
Specifies whether or not SetUID bits in SETATTR Op is to be honored. |
anonymous_user |
string |
User ID To Which Anonymous Users Are Mapped. |
chown_mode |
string |
Specifies who is authorized to change the ownership mode of a file. |
clients |
array[export_clients] |
Array of client matches |
index |
integer |
Index of the rule within the export policy. |
ntfs_unix_security |
string |
NTFS export UNIX security options. |
protocols |
array[string] |
ro_rule |
array[string] |
Authentication flavors that the read-only access rule governs |
rw_rule |
array[string] |
Authentication flavors that the read/write access rule governs |
superuser |
array[string] |
Authentication flavors that the superuser security type governs |
export_policy
The policy associated with volumes to export them for protocol access.
id |
integer |
Identifier for the export policy. |
name |
string |
Name of the export policy. |
rules |
array[export_rules] |
The set of rules that govern the export policy. |
junction_parent
name |
string |
The name of the parent volume that contains the junction inode of this volume. The junction parent volume must belong to the same SVM that owns this volume. |
uuid |
string |
Unique identifier for the parent volume. |
nas
The CIFS share policy and export policies for this volume.
cifs |
export_policy |
The policy associated with volumes to export them for protocol access. |
gid |
integer |
The UNIX group ID of the volume. Valid in POST or PATCH. |
junction_parent |
path |
string |
The fully-qualified path in the owning SVM's namespace at which the volume is mounted. The path is case insensitive and must be unique within an SVM's namespace. Path must begin with '/' and must not end with '/'. Only one volume can be mounted at any given junction path. An empty path in POST creates an unmounted volume. An empty path in PATCH deactivates and unmounts the volume. Taking a volume offline or restricted state removes its junction path. This attribute is reported in GET only when the volume is mounted. |
security_style |
string |
Security style associated with the volume. Valid in POST or PATCH. mixed ‐ Mixed-style security ntfs ‐ NTFS/WIndows-style security unified ‐ Unified-style security, unified UNIX, NFS and CIFS permissions unix ‐ UNIX-style security. |
uid |
integer |
The UNIX user ID of the volume. Valid in POST or PATCH. |
unix_permissions |
integer |
UNIX permissions to be viewed as an octal number, consisting of 4 digits derived by adding up bits 4 (read), 2 (write), and 1 (execute). First digit selects the set user ID (4), set group ID (2), and sticky (1) attributes. Second digit selects permission for the owner of the file. Third selects permissions for other users in the same group while the fourth selects permissions for other users not in the group. Valid in POST or PATCH. For security style "mixed" or "unix", the default setting is 0755 in octal (493 in decimal) and for security style "ntfs", the default setting is 0000. In cases where only owner, group, and other permissions are given (as in 755, representing the second, third and fourth digit), the first digit is assumed to be zero. |
policy
The QoS policy
name |
string |
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH. |
uuid |
string |
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH. |
qos
policy |
The QoS policy |
s3_bucket_policy_condition
Information about policy conditions based on various condition operators and condition keys.
delimiters |
array[string] |
An array of delimiters that are compared with the delimiter value specified at the time of execution of an S3-based command, using the condition operator specified. |
if_match |
array[string] |
Controls conditional writes via If-Match header, evaluated with the Null operator; indicates whether the If-Match header is present or not. |
if_none_match |
boolean |
Controls conditional writes via If-None-Match header, evaluated with the Null operator; indicates whether the If-None-Match header is present or not. |
max_keys |
array[integer] |
An array of maximum keys that are allowed or denied to be retrieved using an S3 list operation, based on the condition operator specified. |
object_creation_operation |
boolean |
Controls object creation requests, evaluated with the Bool operator; indicates whether it is an object-creation request or not. |
operator |
string |
Condition operator that is applied to the specified condition key. |
prefixes |
array[string] |
An array of prefixes that are compared with the input prefix value specified at the time of execution of an S3-based command, using the condition operator specified. |
source_ips |
array[string] |
An array of IP address ranges that are compared with the IP address of a source command at the time of execution of an S3-based command, using the condition operator specified. |
usernames |
array[string] |
An array of usernames that a current user in the context is evaluated against using the condition operators. |
statements
Specifies information about a single access permission.
actions |
array[string] |
conditions |
array[s3_bucket_policy_condition] |
Specifies bucket policy conditions. |
effect |
string |
Specifies whether access is allowed or denied when a user requests the specific action. If access (to allow) is not granted explicitly to a resource, access is implicitly denied. Access can also be denied explicitly to a resource, in order to make sure that a user cannot access it, even if a different policy grants access. |
principals |
array[string] |
resources |
array[string] |
sid |
string |
Specifies the statement identifier used to differentiate between statements. The SID length can range from 1 to 256 characters. |
policy
A policy is an object associated with a bucket. It defines resource (bucket, folder, or object) permissions. These policies are evaluated when an S3 user makes a request by executing a specific command. The user must be part of the principal (user or group) specified in the policy. Permissions in the policies determine whether the request is allowed or denied.
statements |
array[statements] |
Specifies the bucket access policy statement. |
s3_bucket
The S3 bucket
name |
string |
Specifies the name of the bucket. Bucket name is a string that can only contain the following combination of ASCII-range alphanumeric characters 0-9, a-z, ".", and "-". |
nas_path |
string |
Specifies the NAS path that corresponds with the NAS bucket. |
policy |
A policy is an object associated with a bucket. It defines resource (bucket, folder, or object) permissions. These policies are evaluated when an S3 user makes a request by executing a specific command. The user must be part of the principal (user or group) specified in the policy. Permissions in the policies determine whether the request is allowed or denied. |
retention
default |
string |
Specifies the default retention period that is applied to files while committing them to the WORM state without an associated retention period. The retention value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, and minutes. A duration specified for years, months, and days is represented in the ISO-8601 format as "P |
maximum |
string |
Specifies the maximum allowed retention period for files committed to the WORM state on the volume. The retention value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, and minutes. A duration specified for years, months, and days is represented in the ISO-8601 format as "P |
minimum |
string |
Specifies the minimum allowed retention period for files committed to the WORM state on the volume. The retention value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, and minutes. A duration specified for years, month,s and days is represented in the ISO-8601 format as "P |
snaplock
append_mode_enabled |
boolean |
Specifies if the volume append mode is enabled or disabled. When it is enabled, all the files created with write permissions on the volume are, by default, WORM appendable files. The user can append the data to a WORM appendable file but cannot modify the existing contents of the file nor delete the file until it expires. |
autocommit_period |
string |
Specifies the autocommit period for SnapLock volume. All files which are not modified for a period greater than the autocommit period of the volume are committed to the WORM state. The autocommit period value represents a duration and must be specified in the ISO-8601 duration format. The autocommit period can be in years, months, days, hours, and minutes. A period specified for years, months, and days is represented in the ISO-8601 format as "P |
retention |
type |
string |
The SnapLock type of the volume. compliance ‐ A SnapLock Compliance(SLC) volume provides the highest level of WORM protection and an administrator cannot destroy a SLC volume if it contains unexpired WORM files. enterprise ‐ An administrator can delete a SnapLock Enterprise(SLE) volume. non_snaplock ‐ Indicates the volume is non-snaplock. |
snapshot_policy
This is a reference to the snapshot policy.
name |
string |
uuid |
string |
snapshot
reserve_percent |
integer |
The space that has been set aside as a reserve for snapshot usage, in percent. |
space
size |
integer |
The total provisioned size of the container, in bytes. |
snapshot |
storage_service
Determines the placement of the volume that is to be provisioned.
name |
string |
Storage service name. If not specified, the default value is the most performant for the platform. |
object_stores
name |
string |
The name of the object store to use. Used for placement. |
tiering
control |
string |
Storage tiering placement rules for the object. |
object_stores |
array[object_stores] |
Object stores to use. Used for placement. |
policy |
string |
Policy that determines whether the user data blocks of a volume in a FabricPool will be tiered to the cloud store when they become cold. FabricPool combines flash (performance tier) with a cloud store into a single aggregate. The temperature of a volume block increases if it is accessed frequently and decreases when it is not. all ‐ Allows tiering of both snapshots and active file system user data to the cloud store as soon as possible by ignoring the temperature on the volume blocks. auto ‐ Allows tiering of both snapshot and active file system user data to the cloud store. none ‐ Volume blocks are not tiered to the cloud store. snapshot_only ‐ Allows tiering of only the volume snapshots that are not associated with the active file system. The default tiering policy is "snapshot-only" for a FlexVol volume and "none" for a FlexGroup volume. The default minimum cooling period for the "snapshot-only" tiering policy is 2 days and for the "auto" tiering policy it is 31 days. |
volumes
comment |
string |
A comment for the container volume. |
encryption |
exclude_aggregates |
array[exclude_aggregates] |
A list of aggregates to exclude when determining the placement of the volume. |
flexcache |
The FlexCache origin volume. |
guarantee |
is_s3_arbitrary_part_size_enabled |
boolean |
Specifies whether the volume should allow Amazon S3 multipart uploads with arbitrary part lengths. This is only supported for FlexGroup volumes with advanced granular data. The default value is |
name |
string |
Volume name. The name of volume must start with an alphabetic character (a to z or A to Z) or an underscore (_). The name must be 197 or fewer characters in length for FlexGroup volumes, and 203 or fewer characters in length for all other types of volumes. Volume names must be unique within an SVM. Required on POST. |
nas |
The CIFS share policy and export policies for this volume. |
qos |
s3_bucket |
The S3 bucket |
scale_out |
boolean |
Denotes a Flexgroup. |
smas_protection |
string |
Specifies whether the volume should be protected by SnapMirror active sync for NAS. |
snaplock |
snapshot_directory_access_enabled |
boolean |
If set to true, this field enables the visible ".snapshot" directory from the client. The ".snapshot" directory will be available in every directory on the volume. |
snapshot_locking_enabled |
boolean |
Specifies whether or not snapshot copy locking is enabled on the volume. |
snapshot_policy |
This is a reference to the snapshot policy. |
space |
storage_service |
Determines the placement of the volume that is to be provisioned. |
tiering |
type |
string |
Type of the volume. rw ‐ read-write volume. dp ‐ data-protection volume. |
use_mirrored_aggregates |
boolean |
Specifies whether mirrored aggregates are selected when provisioning the volume. Only mirrored aggregates are used if this parameter is set to true and only unmirrored aggregates are used if this parameter is set to false. The default value is true for a MetroCluster configuration and is false for a non-MetroCluster configuration. |
container
svm |
volumes |
array[volumes] |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
