Create an NVMe service
POST /protocols/nvme/services
Introduced In: 9.6
Creates an NVMe service.
Required properties
svm.uuidorsvm.name- The existing SVM in which to create the NVMe service.
Related ONTAP commands
vserver nvme create
Learn more
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
enabled |
boolean |
The administrative state of the NVMe service. The NVMe service can be disabled to block all NVMe connectivity to the SVM. This is optional in POST and PATCH. The default setting is true (enabled) in POST. |
svm |
Example request
"svm": {
"name": "svm1",
Status: 201, Created
num_records |
integer |
The number of records in the response. |
records |
array[nvme_service] |
"num_records": 1,
"records": [
"svm": {
"name": "svm1",
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1115127 |
The cluster lacks a valid NVMe license. |
2621462 |
The supplied SVM does not exist. |
2621507 |
NVMe is not allowed for the specified SVM. |
2621706 |
The specified |
2621707 |
No SVM was specified. Either |
5374893 |
The SVM is stopped. The SVM must be running to create an NVMe service. |
5376452 |
Service POST and DELETE are not supported on ASA r2. |
72089650 |
An NVMe service already exists for the specified SVM. |
72089900 |
An NVMe service cannot be creating in an SVM that is configured for a SAN protocol. |
href |
string |
_links
iops
other |
integer |
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on. |
read |
integer |
Performance metric for read I/O operations. |
total |
integer |
Performance metric aggregated over all types of I/O operations. |
write |
integer |
Performance metric for write I/O operations. |
latency
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput
read |
integer |
total |
integer |
write |
integer |
fc
The NVMe/FC portion of the aggregated metrics.
duration |
string |
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations: |
iops |
The rate of I/O operations observed at the storage object. |
latency |
The round trip latency in microseconds observed at the storage object. |
status |
string |
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput |
The rate of throughput bytes per second observed at the storage object. |
timestamp |
string |
The timestamp of the performance data. |
tcp
The NVMe/TCP portion of the aggregated metrics.
duration |
string |
iops |
latency |
status |
string |
throughput |
timestamp |
string |
metric
Performance numbers, such as IOPS latency and throughput, for SVM protocols.
duration |
string |
iops |
latency |
status |
string |
throughput |
timestamp |
string |
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
latency_raw
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
read |
integer |
total |
integer |
write |
integer |
fc
The NVMe/FC portion of the aggregated statistics.
iops_raw |
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time. |
latency_raw |
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation. |
status |
string |
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput_raw |
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time. |
timestamp |
string |
tcp
The NVMe/TCP portion of the aggregated statistics.
iops_raw |
latency_raw |
status |
string |
throughput_raw |
timestamp |
string |
statistics
These are raw performance numbers, such as IOPS latency and throughput for SVM protocols. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
iops_raw |
latency_raw |
status |
string |
throughput_raw |
timestamp |
string |
svm
name |
string |
uuid |
string |
nvme_service
A Non-Volatile Memory Express (NVMe) service defines the properties of the NVMe controller target for an SVM. There can be at most one NVMe service for an SVM. An SVM's NVMe service must be created before NVMe host initiators can connect to the SVM.
An NVMe service is identified by the UUID of its SVM.
enabled |
boolean |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
