REST API reference
Create the OIDC configuration in the ONTAP cluster
Configures the OIDC settings within the ONTAP cluster, setting up OpenID Connect for secure identity management in your environment.
HTTP method and endpoint
POST /security/authentication/cluster/oidc
Introduced in
ONTAP 9.19
Usage notes
Creates the OIDC configuration in the cluster.
Optional properties
  • skip_uri_validation
  • jwks_refresh_interval
  • outgoing_proxy
  • access_token_issuer
  • security oidc create
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
access_token_issuer
string
The issuer value for the access token when it is different from the OpenID Connect issuer.
authorization_endpoint
string
The URI of the authorization endpoint for the OpenID Connect provider.
client_id
string
The client ID for the application.
client_secret
string
The client secret for the application.
client_secret_hash
string
The hash of the client secret for the application.
end_session_endpoint
string
The URI of the end session endpoint for the OpenID Connect provider.
issuer
string
The URI of the OpenID Connect provider.
string
The refresh interval for the JSON Web Key Set (JWKS), in ISO-8601 format. This can be set to a value from 300 seconds to 2147483647 seconds.
outgoing_proxy
string
Outgoing proxy to access external identity providers (IdPs). If not specified, no proxy is configured.
provider
string
The OpenID Connect provider type.
provider_jwks_uri
string
The URI of the JSON Web Key Set (JWKS) for the OpenID Connect provider.
redirect_ipaddress
string
The IP address to redirect to after authentication.
remote_user_claim
string
The claim used to identify the remote user.
skip_uri_validation
boolean
Indicates whether to skip URI validation.
token_endpoint
string
The URI of the token endpoint for the OpenID Connect provider.
Example request
  "access_token_issuer": "https://example.netapp.com/adfs/services/trust",
  "authorization_endpoint": "https://example.netapp.com/adfs/oauth2/authorize",
  "client_id": "1234567890abcdef",
  "client_secret": "1234567890abcdef1234567890abcdef",
  "client_secret_hash": "1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef",
  "enabled": 1,
  "end_session_endpoint": "https://example.netapp.com/adfs/oauth2/logout",
  "issuer": "https://example.netapp.com/adfs",
  "jwks_refresh_interval": "PT2H",
  "outgoing_proxy": "https://johndoe:secretpass@proxy.example.com:8080",
  "provider": "adfs",
  "provider_jwks_uri": "https://example.netapp.com/adfs/discovery/v2.0/keys",
  "redirect_ipaddress": "10.10.10.10",
  "remote_user_claim": "unique_name",
  "skip_uri_validation": "",
  "token_endpoint": "https://example.netapp.com/adfs/oauth2/token"
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
301465601
Provided client secret is invalid.
301465603
The value specified for client secret is too long. The text must be between 1 and 256 characters.
301465606
Failed to hash the client secret.
301465613
OIDC provider JWKS URI validation failed. Unable to reach the JWKS URI.
301465614
OIDC provider JWKS URI validation failed. Received incorrect response from the JWKS URI.
301465617
Invalid IP address specified for the "redirect_ipaddress". The IP address must be associated with a cluster management or node management LIF.
301465619
Cannot delete the OIDC configuration because OIDC authentication is enabled.
301465620
OAuth 2.0 configuration already exists for this OIDC configuration.
301465621
An error occurred while while creating OAuth 2.0 configuration for this OIDC configuration.
301465623
Cannot configure OIDC because SAML default metadata is configured.
301465624
Cannot configure OIDC because SAML is configured.
301465625
Specified value for the JWKS refresh interval is invalid. The value must be between 300 seconds to 2147483647 seconds.
string
security_oidc
access_token_issuer
string
string
client_id
string
client_secret
string
client_secret_hash
string
string
issuer
string
string
outgoing_proxy
string
provider
string
provider_jwks_uri
string
redirect_ipaddress
string
remote_user_claim
string
skip_uri_validation
boolean
token_endpoint
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
