REST API reference
Perform bulk import for CIFS user groups
Import CIFS local users, groups, and group membership information in bulk using the specified Uniform Resource Identifier (URI). You can also retrieve the status of the last import operation and upload this status to a designated URI.
Overview
Bulk import of the CIFS local users, groups and group membership information can be done from the specified Uniform Resource Identifier (URI). This replaces the existing contents of the CIFS local users, groups and group memberships. This API is used to bulk import from the specified URI, get the status of the last import and to upload the import status to the specified URI.
Retrieving import status of the last bulk import
The bulk-import GET endpoint retrieves the status of the last bulk-import operation of the specified SVM.
Retrieving the status of a successful bulk import
# The API:
/api/protocols/cifs/users-and-groups/bulk-import/{svm.uuid}
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/cifs/users-and-groups/bulk-import/6de1d39d-1473-11ec-b0cf-0050568e4acc" -H "accept: application/json"
# The response:
"svm": {
  "uuid": "6de1d39d-1473-11ec-b0cf-0050568e4acc",
  "name": "vs1",
      "href": "/api/svm/svms/6de1d39d-1473-11ec-b0cf-0050568e4acc"
"import_uri": {
  "path": "http://<import_uri>/file.7z"
"state": "success",
"detailed_status": {
  "message": "Operation completed successfully.",
  "code": "0"
"elements_ignored": 0,
"elements_imported": 2,
    "href": "/api/protocols/cifs/users-and-groups/import/6de1d39d-1473-11ec-b0cf-0050568e4acc"
Retrieving the status of a bulk import that failed
# The API:
# The call:
# The response:
"svm": {
  "name": "vs1",
"import_uri": {
"state": "success",
  "message": "Failed parsing line 1 of the input file. Check syntax and contents.",
  "code": "655698"
"elements_imported": 0,
Retrieving bulk import information for CIFS local users, groups, and group memberships
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/protocols/cifs/users-and-groups/bulk-import/6de1d39d-1473-11ec-b0cf-0050568e4acc" -H "accept: application/json" -d '{"import_uri.username":"user1","import_uri.password":"aaaa","decryption_password":"cccc","import_uri.path":"http://example.com/file1.7z"}'
# The response:
"job": {
  "uuid": "e8293262-1af0-11ec-8243-0050568e4acc",
      "href": "/api/cluster/jobs/e8293262-1af0-11ec-8243-0050568e4acc"
Retrieving status upload information of the last import operation for the specified URI
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/protocols/cifs/users-and-groups/bulk-import/6de1d39d-1473-11ec-b0cf-0050568e4acc" -H "accept: application/json" -d '{"status_uri.username":"user1","status_uri.password":"aaaa","status_uri.path":"http://example.com/fileupload.7z"}'
# The response:
"job": {
  "uuid": "e8293262-1af0-11ec-8243-0050568e4acd",
      "href": "/api/cluster/jobs/e8293262-1af0-11ec-8243-0050568e4acd"
