REST API reference
Manage NDMP mode
Manage NDMP mode settings to configure either SVM-scope or node-scope for your ONTAP environment. Note that node-scope mode is deprecated and not supported on AFX and FSx platforms.
You can use this API to manage NDMP mode: SVM-scope or node-scope. NDMP node scope mode is Deprecated. It is not supported on AFX and FSx platforms.
Updates NDMP mode to SVM:
 PATCH "/api/protocols/ndmp" '{"mode":"svm"}'
Updates NDMP mode to node:
 PATCH "/api/protocols/ndmp" '{"mode":"node"}'
