Manage NVMe subsystem maps
Manage NVMe subsystem maps to establish connections between NVMe namespaces and subsystems. Use these endpoints to create, delete, and discover subsystem maps, granting access to multiple namespaces within your ONTAP environment.
Overview
An NVMe subsystem map is an association of an NVMe namespace with an NVMe subsystem. When an NVMe namespace is mapped to an NVMe subsystem, the NVMe subsystem's hosts are granted access to the NVMe namespace. The relationship between an NVMe subsystem and an NVMe namespace is one subsystem to many namespaces.
The NVMe subsystem map REST API allows you to create, delete and discover NVMe subsystem maps.
Creating an NVMe subsystem map
# The API:
POST /api/protocols/nvme/subsystem-maps
# The call:
curl -X POST 'https://<mgmt-ip>/api/protocols/nvme/subsystem-maps' -H 'Accept: application/hal+json' -d '{ "svm": { "name": "svm1" }, "subsystem": { "name": "subsystem1" }, "namespace": { "name": "/vol/vol1/namespace1" } }'
Retrieving all of the NVMe subsystem maps
# The API:
GET /api/protocols/nvme/subsystem-maps
# The call:
curl -X GET 'https://<mgmt-ip>/api/protocols/nvme/subsystem-maps' -H 'Accept: application/hal+json'
# The response:
"records": [
"svm": {
"uuid": "0e91b214-fe40-11e8-91a0-005056a79967",
"name": "svm1",
"href": "/api/svm/svms/0e91b214-fe40-11e8-91a0-005056a79967"
"subsystem": {
"uuid": "580a6b1e-fe43-11e8-91a0-005056a79967",
"name": "subsystem1",
"href": "/api/protocols/nvme/subsystems/580a6b1e-fe43-11e8-91a0-005056a79967"
"namespace": {
"uuid": "3ccdedc6-2519-4206-bc1f-b0f4adab6f89",
"name": "/vol/vol1/namespace1",
"href": "/api/storage/namespaces/3ccdedc6-2519-4206-bc1f-b0f4adab6f89"
"href": "/api/protocols/nvme/subsystem-maps/580a6b1e-fe43-11e8-91a0-005056a79967/3ccdedc6-2519-4206-bc1f-b0f4adab6f89"
"num_records": 1,
"href": "/api/protocols/nvme/subsystem-maps"
Retrieving a specific NVMe subsystem map
The NVMe subsystem map is identified by the UUID of the NVMe subsystem followed by the UUID of the NVMe namespace.
# The API:
GET /api/protocols/nvme/subsystem-maps/{subsystem.uuid}/{namespace.uuid}
# The call:
curl -X GET 'https://<mgmt-ip>/api/protocols/nvme/subsystem-maps/580a6b1e-fe43-11e8-91a0-005056a79967/3ccdedc6-2519-4206-bc1f-b0f4adab6f89' -H 'Accept: application/hal+json'
# The response:
"svm": {
"name": "svm1",
"subsystem": {
"namespace": {
"node": {
"name": "node1",
"uuid": "012b4508-67d6-4788-8c2d-801f254ce976",
"href": "/api/cluster/nodes/012b4508-67d6-4788-8c2d-801f254ce976"
"nsid": "00000001h",
Deleting an NVMe subsystem map
# The API:
DELETE /api/protocols/nvme/subsystem-maps/{subsystem.uuid}/{namespace.uuid}
# The call:
curl -X DELETE 'https://<mgmt-ip>/api/protocols/nvme/subsystem-maps/580a6b1e-fe43-11e8-91a0-005056a79967/3ccdedc6-2519-4206-bc1f-b0f4adab6f89' -H 'Accept: application/hal+json'
