Manage resource tags
Overview
You can use this endpoint to list all of the resources in the API that have been tagged with a particular tag value and to create new tags on existing resources. Each resource has a limit of 64 tags that cannot be exceeded. See the section labelled Tagging Resources for Tracking Purposes to find out more information about how to tag a resource.
The following examples show some ways that this endpoint can be used.
List all resources that are tagged for the test environment.
# The API:
/api/resource-tags/environment:test/resources
# The call:
curl -X GET "https://<mgmt-ip>/api/resource-tags/environment:test/resources"
# The response:
"records": [
"href": "/api/storage/volumes/558949d1-d4cf-445e-ada5-e340dee6a581",
"href": "/api/resource-tags/environment:test/resources/%2Fapi%2Fstorage%2Fvolumes%2F558949d1-d4cf-445e-ada5-e340dee6a581"
"href": "/api/svm/svms/7f97a0b1-fe4f-11e8-b9c5-005056a76061",
"href": "/api/resource-tags/environment:test/resources/%2Fapi%2Fsvm%2Fsvms%2F7f97a0b1-fe4f-11e8-b9c5-005056a76061"
"href": "/api/cluster",
"href": "/api/resource-tags/environment:test/resources/%2Fapi%2Fcluster"
"num_records": 3,
"href": "/api/resource-tags/environment:test/resources"
List all volumes that have been tagged for the accounting team
# The API:
/api/resource-tags/team:accounting/resources
# The call:
curl -X GET "https://<mgmt-ip>/api/resource-tags/team:accounting/resources?label=storage_volumes"
# The response:
"records": [
"label": "storage_volumes",
"href": "/api/storage/volumes/64750961-fda7-4327-9f16-00034c3f5ad2",
"href": "/api/resource-tags/environment:test/resources/%2Fapi%2Fstorage%2Fvolumes%2F64750961-fda7-4327-9f16-00034c3f5ad2"
"href": "/api/storage/volumes/bee17b91-f90a-4854-b146-8b102a0a9882",
"href": "/api/resource-tags/environment:test/resources/%2Fapi%2Fstorage%2Fvolumes%2Fbee17b91-f90a-4854-b146-8b102a0a9882"
"num_records": 3,
"href": "/api/resource-tags/environment:test/resources?label=storage_volumes"
Create a new tag on a volume
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/resource-tags/team:accounting/resources" -d '{"href": "/api/storage/volumes/f288168e-bd3e-11ed-9516-005056acd4e8"}'
# The response
"num_records": 1,
"records": [
"href": "/api/storage/volumes/f288168e-bd3e-11ed-9516-005056acd4e8",
"href": "/api/resource-tags/team:accounting/resources/%2Fapi%2Fstorage%2Fvolumes%2Ff288168e-bd3e-11ed-9516-005056acd4e8"
Delete a new tag on a volume
# The API:
/resource-tags/{resource_tag.value}/resources/{href}
# The call:
curl -X DELETE "https://<mgmt-ip>/api/resource-tags/team:accounting/resources/%2Fapi%2Fstorage%2Fvolumes%2Ff288168e-bd3e-11ed-9516-005056acd4e8"
