REST API reference
View and update audit settings
Control logging behaviors in audit log files using these endpoints. Retrieve or update administrative audit settings specifically for GET requests to ensure compliance and monitoring.
Overview
This API controls what is logged to the audit log files. All operations that make changes are always logged and cannot be disabled. The PATCH request updates administrative audit settings for GET requests. All fields are optional for a PATCH request. A GET request retrieves administrative audit settings for GET requests.
Retrieving administrative audit settings for GET requests
The following example shows the administrative audit settings for GET requests.
# The API:
/api/security/audit
# The call:
curl -X GET "https://<cluster-ip>/api/security/audit"
# The response:
"cli": false,
"http": false,
"ontapi": false,
        "href": "/api/security/audit"
Updating administrative audit settings for GET requests
The following example updates the administrative audit settings for GET requests
# The API:
/api/security/audit
# The call:
curl -X PATCH "https://<cluster-ip>/api/security/audit" -d '{"cli": false, "http": true, "ontapi": true}'
