REST API reference
View administrative audit logs
Access the administrative audit logs to review detailed records of actions performed within your environment. Utilize these APIs to retrieve logs containing essential information like timestamps, node names, and indexes, ensuring thorough tracking and accountability.
Overview
These APIs return audit log records. The GET requests retrieves all audit log records. An audit log record contains information such as timestamp, node name, index and so on.
Example
Retrieving audit log records
The following example shows the audit log records. Note: The index field is used to order the audit log messages before they are displayed. If multiple entries for the same node and timestamp occur simultaneously, the index assigns an order to ensure logical consistency.
# The API:
/api/security/audit/messages
# The call:
curl -X GET "https://<cluster-ip>/api/security/audit/messages"
# The response:
"records": [
    "timestamp": "2019-03-08T11:03:32-05:00",
    "node": {
      "name": "node1",
      "uuid": "bc9af9da-41bb-11e9-a3db-005056bb27cf",
          "href": "/api/cluster/nodes/bc9af9da-41bb-11e9-a3db-005056bb27cf"
    "index": 4294967299,
    "application": "http",
    "location": "172.21.16.89",
    "user": "admin",
    "input": "GET /api/security/audit/destinations/",
    "state": "pending",
    "scope": "cluster",
    "role": "admin"
"num_records": 1,
    "href": "/api/security/audit/messages"
