REST API reference
Manage the OIDC authentication configuration for the cluster
Overview
This API is used to manage the OpenID Connect (OIDC) authentication configuration for the cluster. The POST method is used to create a new OIDC configuration, while the GET method is used to retrieve the current OIDC configuration. The PATCH method is used to enable or disable the OIDC feature, and the DELETE method is used to remove an existing OIDC configuration.
Retrieving the OIDC configuration in the cluster
The following output shows the OIDC configuration in the cluster.
# The API:
/api/security/authentication/cluster/oidc
# The call:
curl -X GET "https://<mgmt-ip>/api/security/authentication/cluster/oidc" -H "accept: application/hal+json"
# The response:
"provider": "adfs",
"issuer": "https://example.com/adfs",
"client_id": "client-id-value",
"client_secret_hash": "<HASHED-CLIENT-SECRET>",
"provider_jwks_uri": "https://example.com/adfs/discovery/keys",
"remote_user_claim": "unique_name",
"authorization_endpoint": "https://example.com/adfs/oauth2/authorize/",
"token_endpoint": "https://example.com/adfs/oauth2/token/",
"skip_uri_validation": false,
"enabled": false,
"redirect_ipaddress": "10.10.10.10",
"end_session_endpoint": "https://example.com/adfs/oauth2/logout",
"jwks_refresh_interval": "PT1H",
"outgoing_proxy": "https://johndoe:secretpass@proxy.example.com:8080",
"access_token_issuer": "https://example.com/adfs/services/trust",
        "href": "/api/security/authentication/cluster/oidc"
Creating the OIDC configuration in the cluster
The following output shows how to create the OIDC configuration in the cluster.
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/security/authentication/cluster/oidc" -H "accept: application/hal+json" -H "Content-Type: application/json" -d '{ "provider": "adfs", "issuer": "https://example.com/adfs", "client_id": "client-id-value", "client_secret": "<CLIENT-SECRET>", "provider_jwks_uri": "https://example.com/adfs/discovery/keys", "remote_user_claim": "unique_name", "authorization_endpoint": "https://example.com/adfs/oauth2/authorize/", "token_endpoint": "https://example.com/adfs/oauth2/token/", "skip_uri_validation": false, "redirect_ipaddress": "10.10.10.10", "end_session_endpoint": "https://example.com/adfs/oauth2/logout", "jwks_refresh_interval": "PT1H", "outgoing_proxy": "https://johndoe:secretpass@proxy.example.com:8080", "access_token_issuer": "https://example.com/adfs/services/trust"}'
# The response:
"job": {
  "uuid": "1ffeb651-21bb-11f0-8af9-000c29aa7d15",
      "href": "/api/cluster/jobs/1ffeb651-21bb-11f0-8af9-000c29aa7d15"
Updating the OIDC configuration in the cluster
The following output shows how to update the OIDC configuration in the cluster.
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/security/authentication/cluster/oidc" -H "accept: application/hal+json" -H "Content-Type: application/json" -d '{ "enabled": true }'
# The response:
"job": {
Deleting the OIDC configuration in the cluster
The following output shows how to delete the OIDC configuration in the cluster.
# The API:
# The call:
curl -X DELETE "https://<mgmt-ip>/api/security/authentication/cluster/oidc" -H "accept: application/hal+json"
# The response:
"job": {
