REST API reference
Security aws-kms endpoint overview
Overview
Amazon Web Services Key Management Services (AWS KMS) is a cloud key management service (KMS) that provides a secure store for secrets. This feature allows ONTAP to securely store its encryption keys using AWS KMS. In order to use AWS KMS with ONTAP, you must first create a Customer Master Key (CMK) in AWS KMS and provide an Access Key ID and Secret Access Key for a user that has appropriate access to the newly created CMK in the AWS KMS."
Enabling AWS KMS for an SVM
The following example shows how to enable AWS KMS at the SVM-scope. Note the return_records=true query parameter is used to obtain the newly created key manager configuration.
# The API:
POST /api/security/aws-kms
# The call:
curl -X POST 'https://<mgmt-ip>/api/security/aws-kms?return_records=true' -H 'accept: application/hal+json' -d '{"svm":{"uuid":"f36ff553-e713-11ea-bd56-005056bb4222" }, "region": "us-east-1", "key_id": "kmip-aws", "access_key_id": "<AWS-ACCESS-KEY-ID>", "secret_access_key": "<AWS-SECRET-ACCESS-KEY>"}'
# The response:
"num_records": 1,
"records": [
    "uuid": "f72098a2-e908-11ea-bd56-005056bb4222",
    "svm": {
        "uuid": "f36ff553-e713-11ea-bd56-005056bb4222",
        "name": "vs0"
        "href": "/api/security/aws-kms/f72098a2-e908-11ea-bd56-005056bb4222"
Retrieving all AWS KMS configurations
The following example shows how to retrieve all AWS KMS configurations.
# The API:
GET /api/security/aws-kms
# The call:
curl -X GET 'https://<mgmt-ip>/api/security/aws-kms?fields=*'
# The response:
"records": [
    "scope": "svm",
    "svm": {
        "name": "vs0"
    "service": "KMS",
    "default_domain": "amazonaws.com",
    "polling_period": 60,
    "timeout": 10,
"num_records": 1,
    "href": "/api/security/aws-kms?fields=*"
Retrieving a specific AWS KMS configuration
The following example shows how to retrieve information for a specific AWS KMS configuration.
# The API:
GET /api/security/aws-kms/{uuid}
# The call:
curl -X GET 'https://<mgmt-ip>/api/security/aws-kms/f72098a2-e908-11ea-bd56-005056bb4222?fields=*'
# The response:
"scope": "svm",
"svm": {
    "name": "vs0"
"service": "KMS",
"timeout": 10,
Retrieving the advanced properties of an AWS configured for a specific SVM
These values are not retrieved by default with the 'fields=*' option. The following example retrieves the advanced properties of a configured AWS for a specific SVM; there is an added computational cost in retrieving their values. The properties are not populated for either a collection GET or an instance GET unless they are explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
# The API:
# The call:
curl -X GET 'https://<mgmt-ip>/api/security/aws-kms/7052c6c0-a503-11ec-a68f-005056ac75a0/?fields=state,amazon_reachability,ekmip_reachability'
# The response:
"uuid": "d70efc34-aa13-11ec-a059-005056ac7c32",
"state": {
  "cluster_state": true,
  "message": "",
  "code": "0"
"amazon_reachability": {
  "reachable": true,
  "message": "",
  "code": "0"
"ekmip_reachability": [
    "reachable": true,
    "message": "",
    "code": "0",
    "node": {
      "uuid": "817f544f-a98d-11ec-ae20-005056ac7c32",
      "name": "node1",
          "href": "/api/cluster/nodes/817f544f-a98d-11ec-ae20-005056ac7c32"
    "reachable": true,
    "message": "",
    "code": "0",
    "node": {
      "uuid": "84b3f5f3-a98d-11ec-9ff4-005056acfbfe",
      "name": "node2",
          "href": "/api/cluster/nodes/84b3f5f3-a98d-11ec-9ff4-005056acfbfe"
    "href": "/api/security/aws-kms/d70efc34-aa13-11ec-a059-005056ac7c32"
Updating the "access_key_id" of a specific AWS KMS configuration
The following example shows how to update the "access_key_id" for a specific AWS KMS configuration.
# The API:
PATCH /api/security/aws-kms/{uuid}
# The call:
curl -X PATCH 'https://<mgmt-ip>/api/security/aws-kms/f72098a2-e908-11ea-bd56-005056bb4222/' -d '{"access_key_id": "<AWS-ACCESS-KEY-ID>", "secret_access_key": "<AWS-SECRET-ACCESS-KEY>"}'
Updating a specific AWS KMS configuration to allow it to use a proxy.
The following example shows how to update a specific AWS KMS configuration to allow the AWS KMS instance to use a proxy.
# The API:
# The call:
curl -X PATCH 'https://<mgmt-ip>/api/security/aws-kms/f72098a2-e908-11ea-bd56-005056bb4222/' -d '{"default_domain": "216.9", "host": "172.20.216.9", "port": 8000, "service": "10", "verify_host": false, "verify_ip": false}'
Deleting a specific AWS KMS configuration
The following example shows how to delete a specific AWS KMS configuration.
# The API:
DELETE /api/security/aws-kms/{uuid}
# The call;
curl -X DELETE 'https://<mgmt-ip>/api/security/aws-kms/f72098a2-e908-11ea-bd56-005056bb4222'
Restoring keys from a KMIP server
The following example shows how to restore keys for a AWS KMS configuration.
# The API:
POST /api/security/aws-kms/{uuid}/restore
# The call:
curl -X POST 'https://<mgmt-ip>/api/security/aws-kms/33820b57-ec90-11ea-875e-005056bbf3f0/restore'
