REST API reference
Manage cluster network security certificates
Use the security cluster-network certificate endpoints to view, modify, and manage certificate configurations for cluster network security. These endpoints support operations like retrieving, updating, assigning, and removing certificates for specific nodes, helping to ensure your cluster network maintains robust security protocols.
Overview
You can use the security cluster-network certificate API endpoints to view and modify the certificate configuration for cluster network security. The following operations are supported:
  • GET to retrieve the certificate configuration for cluster network security: GET security/cluster-network/certificates
  • PATCH to update the certificate configuration for cluster network security for a given node: PATCH security/cluster-network/certificates/{node.uuid}
  • POST to specify the certificate configuration for cluster network security for a given node: POST security/cluster-network/certificates
  • DELETE to remove the certificate configuration for cluster network security for a given node: DELETE security/cluster-network/certificates/{node.uuid}
Retrieving all certificate configurations for cluster network security
# The API:
GET /api/security/cluster-network/certificates
# The call:
curl -X GET "https://<mgmt-ip>/api/security/cluster-network/certificates?fields=*&return_records=true" -H "accept: application/json"
# The response:
"records": [
    "node": {
      "uuid": "4ea7a442-86d1-11e0-ae1c-123478563412",
      "name": "node1"
    "certificate": {
      "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
      "name": "cluster_network_cert_1"
        "href": "/api/security/cluster-network/certificates/4ea7a442-86d1-11e0-ae1c-123478563412"
    "node": {
      "uuid": "5fb8b553-97e2-22f1-bf2d-234589674523",
      "name": "node2"
    "certificate": {
      "uuid": "2de9b553-97e2-22f1-bf2d-234589674523",
      "name": "cluster_network_cert_2"
        "href": "/api/security/cluster-network/certificates/5fb8b553-97e2-22f1-bf2d-234589674523"
"num_records": 2,
    "href": "/api/security/cluster-network/certificates"
Assigning a certificate to a node for cluster network security
# The API:
POST /api/security/cluster-network/certificates
# The call:
curl -X POST "https://<mgmt-ip>/api/security/cluster-network/certificates" -H "accept: application/json" -H "Content-Type: application/json" -d '{"node": {"uuid": "4ea7a442-86d1-11e0-ae1c-123478563412"}, "certificate": {"name": "cluster_network_cert_1"}}'
# The response:
"node": {
  "name": "node1"
"certificate": {
Updating the certificate for a specific node
# The API:
PATCH /api/security/cluster-network/certificates/{node.uuid}
# The call:
curl -X PATCH "https://<mgmt-ip>/api/security/cluster-network/certificates/4ea7a442-86d1-11e0-ae1c-123478563412" -H "accept: application/json" -H "Content-Type: application/json" -d '{"certificate": {"name": "cluster_network_cert_new"}}'
# The response:
HTTP/1.1 200 OK
Deleting the certificate configuration for a specific node
# The API:
DELETE /api/security/cluster-network/certificates/{node.uuid}
# The call:
curl -X DELETE "https://<mgmt-ip>/api/security/cluster-network/certificates/4ea7a442-86d1-11e0-ae1c-123478563412" -H "accept: application/json"
# The response:
HTTP/1.1 200 OK
