View IPsec and IKE security associations for the cluster network
Use the security cluster-network IPsec association endpoints to view IPsec and IKE security associations for cluster network security. Retrieve all associations or specific ones by UUID to monitor and manage your cluster's network security configurations.
Overview
You can use the security cluster-network ipsec association API endpoints to view IPsec and IKE (Internet Key Exchange) security associations for cluster network security. The following operations are supported:
Collection Get: Retrieve all IPsec/IKE associations: GET security/cluster-network/ipsec/associations
Instance Get: Retrieve a specific association by UUID: GET security/cluster-network/ipsec/associations/{uuid}
Retrieving all IPsec and IKE security associations
# The API:
GET /api/security/cluster-network/ipsec/associations
# The call:
curl -X GET "https://<mgmt-ip>/api/security/cluster-network/ipsec/associations?fields=*&return_records=true" -H "accept: application/json"
# The response:
"records": [
"uuid": "a1b2c3d4-1234-5678-9abc-def012345678",
"type": "ipsec",
"node": {
"uuid": "4ea7a442-86d1-11e0-ae1c-123478563412",
"name": "node1"
"policy_name": "policy1",
"local_address": "192.168.1.1",
"remote_address": "192.168.1.2",
"cipher_suite": "suiteb_gcm256",
"lifetime": 28800,
"ipsec": {
"inbound": {
"security_parameter_index": "0x12345678",
"bytes": 1048576,
"packets": 1024
"outbound": {
"security_parameter_index": "0x87654321",
"bytes": 2097152,
"packets": 2048
"action": "esp_transport",
"state": "installed"
"uuid": "b2c3d4e5-2345-6789-abcd-ef0123456789",
"type": "ike",
"node": {
"name": "node1"
"lifetime": 86400,
"ike": {
"initiator_security_parameter_index": "0xaabbccdd",
"responder_security_parameter_index": "0xddccbbaa",
"is_initiator": true,
"version": 2,
"authentication": "cert",
"state": "established"
"num_records": 2,
"href": "/api/security/cluster-network/ipsec/associations"
Retrieving a specific security association by UUID
# The API:
GET /api/security/cluster-network/ipsec/associations/{uuid}
# The call:
curl -X GET "https://<mgmt-ip>/api/security/cluster-network/ipsec/associations/a1b2c3d4-1234-5678-9abc-def012345678" -H "accept: application/json"
# The response:
"type": "ipsec",
"node": {
"name": "node1"
"lifetime": 28800,
"ipsec": {
"inbound": {
"bytes": 1048576,
"packets": 1024
"outbound": {
"bytes": 2097152,
"packets": 2048
