REST API reference
View and update IPsec configuration
Access and modify IPsec configurations to ensure secure data transmission within your network. Retrieve the current IPsec status or update settings as needed using the available operations.
Overview
The following operations are supported:
  • GET to retrieve the IPsec status: GET security/ipsec
  • Patch to update IPsec status: PATCH security/ipsec
